POV-Ray : Newsgroups : povray.off-topic : ODBC Server Time
10 Feb 2026 14:23:57 EST (-0500)
  ODBC (Message 1 to 10 of 98)
Subject: ODBC
Date: 13 Dec 2007 08:05:47
Message: <47612e2b$1@news.povray.org>
Does anybody here know anything about ODBC?
http://blog.orphi.me.uk/
Subject: Re: ODBC
Date: 13 Dec 2007 08:19:20
Message: <47613158$1@news.povray.org>
run away run away
Subject: Re: ODBC
Date: 13 Dec 2007 08:20:55
Message: <476131b7@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:47612e2b$1@news.povray.org...
Open Database Connectivity.
A standard API for connecting to various forms of data sources. Generally
slower than OleDB, but easier to find drivers for more esoteric systems.
Was there anything specific you wanted to know?
Subject: Re: ODBC
Date: 13 Dec 2007 08:24:51
Message: <476132a3$1@news.povray.org>
There appear to be ODBC drivers for accessing CSV files and so forth.
So does that mean I can perform arbitrary SQL queries on a CSV file?
Subject: Re: ODBC
Date: 13 Dec 2007 08:25:06
Message: <476132b2@news.povray.org>
Tom Austin wrote:
> run away run away
So-noted.
Subject: Re: ODBC
Date: 13 Dec 2007 08:50:02
Message: <web.4761380e56f11385e2b2e7080@news.povray.org>
I know a bit. There are probably others here who know more.  A more specific
context would probably be helpful.  Are you looking to learn more about the
subject in general? Is there a specific problem you need to solve?
A reasonably short and to the point intro can be found here:
http://www.unixodbc.org/doc/ProgrammerManual/Tutorial/
Best Regards,
Mike C.
Subject: Re: ODBC
Date: 13 Dec 2007 09:20:43
Message: <47613fbb@news.povray.org>
news:476132a3$1@news.povray.org...
Yup. Excel spreadsheets, xml files, assorted databases, active directory,
etc...
Probably. How complex a statement depends on the capabilities of the driver
in question. If it has a manula/help file, read it.
Subject: Re: ODBC
Date: 13 Dec 2007 09:30:40
Message: <47614210$1@news.povray.org>
> etc...
...right. So you're saying the type of queries I can do can vary by ODBC
driver?
I guess I was assuming that an ODBC driver is like a graphics driver -
either you have graphics or you don't. (Oh, and some of the more exotic
features might not be available, like 3D acceleration or hardware overlays.)
Basically I want to develop a program that talks to a database. I was
going to use ODBC to do this. But I don't have a database set up right
now, so I was wondering if I could test it with a simple text file until
I get round to setting up a real database. [Obviously a CSV file isn't
going to even approach the speed of a half decent database engine. But I
can test whether data goes in and data comes out.]
Alternatively, does anybody know how to configure PostgreSQL? Because I
can't get the damn thing to work properly...
Subject: Re: ODBC
Date: 13 Dec 2007 11:09:09
Message: <47615925$1@news.povray.org>
47614210$1@news.povray.org...
> now, so I was wondering if I could test it with a simple text file until I
> get round to setting up a real database. [Obviously a CSV file isn't going
> to even approach the speed of a half decent database engine. But I can
You can do some limited database work with text files (or Excel files etc.),
but that will mostly be limited to actions that can be done without
requiring indexes, i.e. SELECT and INSERT statements rather than UPDATE and
DELETE for instance. For testing a database, you'll need a database. MS
Access will do, and MySQL takes a couple of minutes to install on a PC.
G.
Subject: Re: ODBC
Date: 13 Dec 2007 11:16:49
Message: <47615af1$1@news.povray.org>
PostreSQL also takes a couple of minutes to set up. Unforuntately, I
can't make it do anything once it's installed.
MySQL isn't transactional = I'm not really interested.
Maybe I'll just use M$ Access. [Obviously that means I can only use
computers which have M$ Access.]
