POV-Ray : Newsgroups : povray.off-topic : An Exceptionally Simple Theory of Everything Server Time
9 Jun 2026 15:59:40 EDT (-0400)
  An Exceptionally Simple Theory of Everything (Message 9 to 18 of 28)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: An Exceptionally Simple Theory of Everything
Date: 17 Nov 2007 17:00:42
Message: <473f648a$1@news.povray.org>
Warp wrote:
>   One thing I have never really understood is why they are so vehemently
> trying to find a "unified theory of everything".
As Mueen stated, it's probably to predict what currently can't be
predicted. He was talking about the properties of particles which still
have yet to be discovered, but the implications could reach farther. In
fact, if we could determine *all* the factors present during the Big
Bang, we will be one step closer to predicting future events. Of course,
to accurately model the Universe we must use other parallel universes
for computational purposes. I don't think we will ever reach such an
advanced state (assuming such a thing is possible). We will most likely
wipe ourselves out long before making such progress.
>   This may be a far-fetched analogy, but we have theories and models of
> how car engines should be built, and we have theories and models of how
> skyscrapers should be built. Neither model can be used to describe the
> other situation, but so what? That doesn't cause any problems. If you
> are building a car engine, use the car engine model. If you are building
> a skyscraper, use the skyscraper model. Where's the problem? Why would
> we even need a "unified model" which describes both car engines and
> skyscrapers at the same time? There's no need, and it would only completely
> unnecessarily complicate things.
In light of our current state of knowledge regarding basic physics, your
assumption makes sense. But what if we do find a unified theory of all
existence which makes us reconsider our severely limited knowledge of
low-level physics? We might find that the approach to engineering a
skyscraper and our approach to engineering a car engine becomes, er,
more unified :)
>   Is it just a question of coolness, or is there some practical issue
> in play here?
There are always practical issues regarding the advancement of knowledge.
Sam
Date: 17 Nov 2007 19:14:00
Message: <473f83c8$1@news.povray.org>
> in play here?
I think it's more a combination of two things:
One - that the two theories are incompatible. Relativity requires
continuous functions. Quantum disallows continuous functions. If space
(including gravity etc) is smoothly continuous at the smallest levels,
quantum theory would give the wrong answer. If space were discontinuous
at the smallest levels, relativity would give the wrong answers, even at
the big sizes. So, basically, people *know* that one of them is "wrong",
even though both are giving the right answers to the precision with
which they can be measured. And QED at least has been measured and
matches predictions to something like 15 decimal places, which is an
incredible precision.
Two - figuring out the combination might lead to all kinds of new
discoveries. Just as an example, in 1890 or so, people thought they knew
all about how light worked, and so on, except for one or two little
anomalies, like black-body radiation and the photoelectric effect at low
light levels. It took a whole new shift to quantum calculations to be
able to understand those effects. That resulted in lasers,
semiconductors, understanding genetics at the individual protein level,
and so on.
If you can unify the operations of gravity and quantum interactions, you
might be able to make electrogravitics, anti-gravity, gravity-powered
light bulbs, stuff like that. Who knows? If you could get quantum
miracles(*) to work reliably over space-like distances, you could get
teleportation, time travel, stuff like that.
Plus, it might explain *why* quantum stuff is random, and whether
there's any underlying unmeasurable rules, and so on, even if you can't
manipulate it.
(*) AKA very low probability quantum teleportation events, like in
tunnel diodes only long distances.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 18 Nov 2007 00:04:23
Message: <473fc7d7@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> gravity-powered light bulbs
  That sounds like a perpetual motion machine. Unlikely. :P
Date: 18 Nov 2007 00:37:04
Message: <473fcf80$1@news.povray.org>
I guess it depends on what causes gravity. Maybe gravity isn't constant.
I read one fictional story where the physicists discovered that gravity
is caused by the spontaneous destruction of mass and created by the
spontaneous creation of mass.  So places where there was lots of mass
had more gravity, because it was more likely there would be a subatomic
particle disappearing, and why the rest of the universe had a nice
sparse sprinkling of random hydrogen atoms. :-)
Or maybe gravity-powered light bulbs would just be a more direct way
than, say, tidal bore generators; a gravity-powered bulb might make the
earth lighter or orbit slower or something.  Or maybe it would only work
if the bulb was moving up or down. :-)
Gravity is pretty weak anyway. It takes the whole earth to hold you
down, and just a little layer of electrons to hold you up.  I read if
you took all the electrons off a 1cm cube of aluminum, and held them 1
meter away, the force between the two would match the weight of a cube
of iron 76 miles on a side. Vast difference in power, which is one of
the reasons it's so hard to do quantum gravity experiments.
Plus, of course, maybe conservation of energy isn't true. That's the
sort of thing a ToE has the chance to support or disprove. :-)
Date: 18 Nov 2007 15:52:14
Message: <4740a5fe$1@news.povray.org>
	Unless our Theory of Everything provides exceptions to the 2nd Law of
Thermodynamics based on certain rare circumstances.
	Those Laws are just a result of our observations, and can change. I'm
sure in the early 19th century, people would have scoffed at particles
with mass diffracting.
Why do the Alphabet song and Twinkle, Twinkle Little Star have the same
tune?
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 18 Nov 2007 19:40:01
Message: <4740db61$1@news.povray.org>
I'm told by other physicists that the zero-point energy might actually
be tappable, or at least that there's no entropic reason it couldn't be.
Date: 18 Nov 2007 19:54:13
Message: <4740deb5@news.povray.org>
  Does that mean we might get a real-life gravity gun (aka. zero-point
energy field manipulator) someday?-)
Date: 19 Nov 2007 06:03:12
Message: <47416d70$1@news.povray.org>
andrel wrote:
> Whether there is a practical advantage will only show after unification.
> But of course the main problem is that it is bloody annoying at parties.
Not as annoying as having all your underwear teleported two feet away
when somebody fires up the Bambleweeny 57 sub-meson brain and plugs in
the atomic vector plotter. Oh, wait, physicists don't get invited to
those sorts of parties...
Date: 19 Nov 2007 06:51:00
Message: <op.t11e7eyac3xi7v@news.povray.org>
And lo on Sat, 17 Nov 2007 10:44:57 -0000, Warp <war### [at] tagpovrayorg> did
spake, saying:
>   We have models which describe how things work at quantum scale, and we
> have models which describe how things work at macroscale (including high
> speeds and high masses). Neither model describes well the other, but why
> is this such a big deal? Why can't we have two (or more) models at the
> same time?
Darren's is the best explanation, both theories start with different
assumptions about the same thing; yet both are accurate. Problem two is
when you get a theory A object behaving like a theory B object, because of
problem 1 you can't mix-and-match the equations and all you get out of
them is infinities (unless you're fine with physical infinities).
> completely
Except both skyscrapers and car engines use the same material science and
physics and start with the same assumptions, they're just applied in
different ways. A car-engine designer can use the same science to build a
skyscraper, he doesn't need to switch equations, just take some extra
things into consideration.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 19 Nov 2007 17:09:23
Message: <47420AA0.8020204@hotmail.com>
Bill Pragnell wrote:
>> unification. But of course the main problem is that it is bloody
1) I am indeed never invited
2) I don't drink tea
3) I am not a woman
not necessarily in that order.
