POV-Ray : Newsgroups : povray.off-topic : missing disk space on server, need help Server Time
3 Aug 2026 03:52:09 EDT (-0400)
  missing disk space on server, need help (Message 41 to 50 of 58)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: missing disk space on server, need help
Date: 13 Nov 2007 13:11:48
Message: <4739e8e4$1@news.povray.org>
Darren New wrote:
> Orchid XP v7 wrote:
>> The allocation engine allocates a full block to a file, and does not
>> allocate any additional ones until the present ones are full.
> How do you know?
Well, put it this way: This is a trivial algorithm, and there is
absolutely no *reason* why it would do anything different, so...
Date: 13 Nov 2007 19:21:11
Message: <473a3f77@news.povray.org>
Jim Henderson nous apporta ses lumieres en ce 2007/11/12 19:37:
> On Mon, 12 Nov 2007 19:20:08 -0500, Alain wrote:
>> Ever heard of "sparse" files?
> Yes.  Old hand at NetWare; didn't know that Windows filesystems supported
> sparse files.
> Jim
Was even supported under DOS 3, maybe earlier.
Always try to be modest, and be proud of it!
Date: 13 Nov 2007 19:26:43
Message: <473a40c3$1@news.povray.org>
Nicolas Alvarez nous apporta ses lumieres en ce 2007/11/13 12:41:
> Darren New escribió:
>> Unlike UNIX, it's not just a matter of seeking around. You have to
>> open the file as a sparse file, then you have to say "hey, this area
>> is sparse" rather than (say) just writing all zeros to the blocks or
>> something.
> Not really... Cross-platform programs that don't use any
> Windows-specific API manage to create sparse files here. That's why
> download managers that download in chunks give the option to
> pre-allocate: sparse files that are filled randomly get fragmented quite
> badly.
And can have TONS of slack space! Just imagine a file whose records are about 64
bytes each, and only having less than 0.01% of them actualy used... with
clusters of 4Kb. You are stuck with many clusters containing only 1 record, at
some random location in the cluster.
Moonies: Only really happy shit happens.
Date: 13 Nov 2007 19:39:43
Message: <473a43cf@news.povray.org>
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/12 13:58:
> Darren New wrote:
>> M_a_r_c wrote:
>>> "Nicolas Alvarez" <nic### [at] gmailisthebestcom> a écrit
>>> dans le message de news: 473472c5$1@news.povray.org...
>>>> Fa3ien escribió:
>>>>> I've run a defrag, which freed 250 Mb.
>>>> Defrags free disk space??
>>> I am not an expert but maybe if it optimizes disk occupation by
>>> filling blocks instead of letting empty portions of blocks.
>> More precisely, if you have a fragmented file taking 3 blocks and
>> filling them each only 10%, defragging that file will free two blocks.
> More precisely, how would this situation arrise in the first place?
How can you assume that it only allocate a single block? NTFS allocate some
cluster when you create a new file in an attempt to reduce fragmentation that
appens when several files are created at once and randomly filled. Once the file
is closed, the unused clusters are liberated. It does the same when all the
file's alocated space is filled ant it need some more disk space. That
prealocated space must reside in successive clusters.
Fix reason firmly in her seat, and call to her tribunal every fact, every
opinion. Question with boldness even the existence of a God; because, if
there be one, he must more approve of the homage of reason, than that of
blindfolded fear.
Thomas Jefferson
Date: 13 Nov 2007 19:56:17
Message: <473a47b1$1@news.povray.org>
>> quite badly.
> about 64 bytes each, and only having less than 0.01% of them actualy
> used... with clusters of 4Kb. You are stuck with many clusters
> containing only 1 record, at some random location in the cluster.
Of course. The file usage on disk grows while it gets downloaded. But in
the end, it will eventually be totally downloaded and extremely
fragmented. So in those cases it's a good idea to pre-allocate. If you
will have lots of "unused records" for long periods, then yes it's a
good idea to let it use sparse files.
Date: 13 Nov 2007 21:30:26
Message: <473a5dc2$1@news.povray.org>
>> something.
I think if you write to it, regardless of what you write, you get
allocated space. UNIX *used* to see an all-zeros buffer and say "Gee, we
don't need to write that."  You didn't have to seek over the sparse
space to make it sparse, IIRC.
I think the calls I'm thinking of are for making an existing data area
sparse, too; i.e., throwing away the beginning of a log file without
changing offsets of existing records. And you may even need to open the
file in "sparse" mode.
Or, I could be completely wrong. This one I never actually did. :-)
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 13 Nov 2007 21:31:13
Message: <473a5df1$1@news.povray.org>
>> supported sparse files.
>> Jim
What, on FAT?  Nah.  Would have to be some other format, cause FAT
doesn't have the data structures for that.
CP/M did, actually, now that I think of it. :-)
Date: 13 Nov 2007 21:32:09
Message: <473a5e29$1@news.povray.org>
>> I mean, 43 fragments for a 1K ntuser.dat?
> That's probably mis-reporting the size. NTUSER.DAT has the whole user
> registry hive. It's 6MB on my machine, no way it can be 1K on yours.
Yah, OK. Looking at it with DIR is 15 meg or so here.  I *thought* that
was kind of funky.
Date: 13 Nov 2007 21:33:33
Message: <473a5e7d@news.povray.org>
Orchid XP v7 wrote:
>> How do you know?
I thought Microsoft was generally considered a good reason to do
anything trivial wrong. ;-)
Date: 13 Nov 2007 21:39:25
Message: <473a5fdd$1@news.povray.org>
>>> something.
Right, as far as I know, if you write 0s without using any special
Windows API, the 0s actually get written (that's the pre-allocation
download programs do).
