POV-Ray : Newsgroups : povray.off-topic : missing disk space on server, need help Server Time
1 Nov 2026 01:34:14 EDT (-0400)
  missing disk space on server, need help (Message 21 to 58 of 58)
<<< Previous 20 Messages Goto Initial 50 Messages
Subject: Re: missing disk space on server, need help
Date: 9 Nov 2007 17:15:52
Message: <4734dc18@news.povray.org>
Fa3ien escribió:
> Nicolas Alvarez a écrit :
>> Fa3ien escribió:
>>> I've run a defrag, which freed 250 Mb.
>> Defrags free disk space??
> Theorically, it shouldn't, I'm surprised too.  The fact
> is that Windows seen more free space after defrag.
> chkdsk freed the rest !
Ah that's why. Defrag does *some* disk checking before starting. I doubt
it does a full chkdsk, or it would have (seemed to) solve your problem.
Date: 9 Nov 2007 21:54:05
Message: <47351d4d@news.povray.org>
Nicolas Alvarez nous apporta ses lumieres en ce 2007/11/09 09:46:
The OS want to assign a minimum contiguous space to any new or altered file. Any
free space lower than that thresshold is wasted, and often not reported.
Defragmenting consolidate that wasted space at the same tima it put fragmented
files back together.
Experience hath shewn, that even under the best forms of government those
entrusted with power have, in time, and by slow operations, perverted it
into tyranny.
Thomas Jefferson
Subject: Re: missing disk space on server, need help (SOLVED with chkdsk)
Date: 9 Nov 2007 22:01:08
Message: <47351ef4$1@news.povray.org>
Fa3ien nous apporta ses lumieres en ce 2007/11/09 15:11:
> Orchid XP v7 a écrit :
>> Fa3ien wrote:
>>> In short, a good'ol chkdsk /f solved the problem.
>>> I didn't knew that so much empty space could be
>>> erroneously marked as allocated...
>> Woah! o_O
>> That's one unhappy filesystem... heh. Glad it's all fixed now though.
>> (Although you probably ought to find out *why* it did this in the
>> first place...)
> I'll check regularly to see if it happens again... Maybe it's related
> to the problems I had with Raid in may. I currently run the server
> without Raid1, because the bad experience showed me that no raid (with
> a daily backup, anyway) is less of a potential hassle than shitty SIS
> software Raid (which is more insecure because it doesn't inform you
> correctly of the real array state).
> Fabien.
Faulty raid! Ugly. UGLY! *UGLY!!!!!*
Ready to bet that is was the reason of your vanishing space.
An organizer for the "Million Agoraphobics March" expressed disappointment in
the turnout for last weekend's event.
Date: 11 Nov 2007 18:26:48
Message: <47378fb8$1@news.povray.org>
M_a_r_c wrote:
> "Nicolas Alvarez" <nic### [at] gmailisthebestcom> a écrit dans le
> message de news: 473472c5$1@news.povray.org...
> I am not an expert but maybe if it optimizes disk occupation by filling
> blocks instead of letting empty portions of blocks.
More precisely, if you have a fragmented file taking 3 blocks and
filling them each only 10%, defragging that file will free two blocks.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 11 Nov 2007 18:29:01
Message: <4737903d$1@news.povray.org>
Fa3ien wrote:
> WHERE IS THE REST ? (there should be 60 Gb free !)
Besides chkdsk, I was going to suggest making sure nobody has an open,
deleted file that's real big, like some logfile output that someone
deleted the file name but didn't close the program yet that has it open.
Date: 12 Nov 2007 13:43:35
Message: <47389ed7$1@news.povray.org>
I don't think that can happen with "standard" files in NTFS or FAT - why
would the OS write to a partial block but not the entire block?  Doesn't
make sense to me...
Jim
Date: 12 Nov 2007 13:58:37
Message: <4738a25d$1@news.povray.org>
Darren New wrote:
>> le message de news: 473472c5$1@news.povray.org...
>> filling blocks instead of letting empty portions of blocks.
More precisely, how would this situation arrise in the first place?
The allocation engine allocates a full block to a file, and does not
allocate any additional ones until the present ones are full.
As noted elsewhere, in this case it's likely that the defrag partially
corrected the freelists or something. (Remember, the filesystem was
corrupted.)
Date: 12 Nov 2007 19:20:08
Message: <4738edb8$1@news.povray.org>
Jim Henderson nous apporta ses lumieres en ce 2007/11/12 13:43:
> make sense to me...
> Jim
Ever heard of "sparse" files?
To define recursion, we must first define recursion.
Date: 12 Nov 2007 19:37:46
Message: <4738f1da$1@news.povray.org>
Yes.  Old hand at NetWare; didn't know that Windows filesystems supported
sparse files.
Jim
Date: 12 Nov 2007 23:38:06
Message: <47392a2e$1@news.povray.org>
I don't know about FAT, but I was surprised when I saw a log file that
actually consumed more clusters than there were lines in the file. WTF?
> make sense to me...
Open the file, write a little bit, close it. Open it again, append a
little, close it. Repeat.  Possibly it requires other people to also
have the file open at the same time, as for reading or something?
NTFS isn't very good at avoiding fragmentation, methinks.
Date: 12 Nov 2007 23:39:44
Message: <47392a90$1@news.povray.org>
> sparse files.
Yah, it does. Well, NTFS does, at least. Indeed, fundamental parts of
the system (like the USN journal) rely on the fact that you can delete
blocks off the start of a file and recover the space used therein.
Unlike UNIX, it's not just a matter of seeking around. You have to open
the file as a sparse file, then you have to say "hey, this area is
sparse" rather than (say) just writing all zeros to the blocks or something.
Date: 12 Nov 2007 23:40:08
Message: <47392aa8$1@news.povray.org>
How do you know?
Date: 13 Nov 2007 01:28:12
Message: <473943fc$1@news.povray.org>
>> supported sparse files.
> something.
Ah, I see - learned something new today. :-)
Jim
Date: 13 Nov 2007 01:29:27
Message: <47394447$1@news.povray.org>
Don't think so.  Sparse files I could see, but a proper sparse file
wouldn't shrink during a defrag, either, based on my own experiences,
because the "empty" space is as important as the real data is to the
application.
Jim
Date: 13 Nov 2007 11:32:13
Message: <4739d18d$1@news.povray.org>
> Don't think so.
I don't know. All I can say is that I've seen files with 2K length
spread over half a dozen blocks as reported by defrag. :-)  I'm not sure
what causes it.
Try running the defrag GUI version, look at the report, and see if
things like your registry hives or event logs are fragmented and how
much. In my expereince, it's not uncommon.
> application.
Yah. Sparse files are already deallocated, so you can't really
deallocate more.
Date: 13 Nov 2007 11:37:36
Message: <4739d2d0$1@news.povray.org>
> what causes it.
I mean, 43 fragments for a 1K ntuser.dat?  15 fragments for a 1K
default.log? In a 4K cluster size?  Clearly, there has to be fragmented
files with not-fully-packed blocks, if defrag is to be believed.
Maybe that's the problem tho - the layout is right, the reporting is funky.
Download 'image1.gif' (14 KB)
Preview of image 'image1.gif'
Date: 13 Nov 2007 12:39:58
Message: <4739e16e$1@news.povray.org>
> something.
Not really... Cross-platform programs that don't use any
Windows-specific API manage to create sparse files here. That's why
download managers that download in chunks give the option to
pre-allocate: sparse files that are filled randomly get fragmented quite
badly.
Date: 13 Nov 2007 12:42:00
Message: <4739e1e8@news.povray.org>
That's probably mis-reporting the size. NTUSER.DAT has the whole user
registry hive. It's 6MB on my machine, no way it can be 1K on yours.
Date: 13 Nov 2007 13:04:37
Message: <4739e735$1@news.povray.org>
>> Don't think so.
> what causes it.
At a guess, corruption. :-)
Hmmm, well, the only Windows I have installed is in VMware with virtual
disks, so I'm unlikely to run across this, I think.
>> application.
> deallocate more.
Yep.
Jim
Date: 13 Nov 2007 13:06:13
Message: <4739e795$1@news.povray.org>
Weird.  Though based on my experiences with Active Directory, I'm not
inclined to believe what any Microsoft utility tells me.  I've seen two
different hardware diagnostics point fingers at each other, but with
Windows 2000 Server, I had a first - two programs that were intended to
tell me the health of my domain that couldn't agree with each other.
Both from the same vendor.
> funky.
Could be.
Jim
Date: 13 Nov 2007 13:11:48
Message: <4739e8e4$1@news.povray.org>
> How do you know?
Well, put it this way: This is a trivial algorithm, and there is
absolutely no *reason* why it would do anything different, so...
Date: 13 Nov 2007 19:21:11
Message: <473a3f77@news.povray.org>
Jim Henderson nous apporta ses lumieres en ce 2007/11/12 19:37:
> sparse files.
> Jim
Was even supported under DOS 3, maybe earlier.
Always try to be modest, and be proud of it!
Date: 13 Nov 2007 19:26:43
Message: <473a40c3$1@news.povray.org>
Nicolas Alvarez nous apporta ses lumieres en ce 2007/11/13 12:41:
>> open the file as a sparse file, then you have to say "hey, this area
>> is sparse" rather than (say) just writing all zeros to the blocks or
>> something.
> badly.
And can have TONS of slack space! Just imagine a file whose records are about 64
bytes each, and only having less than 0.01% of them actualy used... with
clusters of 4Kb. You are stuck with many clusters containing only 1 record, at
some random location in the cluster.
Moonies: Only really happy shit happens.
Date: 13 Nov 2007 19:39:43
Message: <473a43cf@news.povray.org>
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/12 13:58:
> Darren New wrote:
>>> dans le message de news: 473472c5$1@news.povray.org...
How can you assume that it only allocate a single block? NTFS allocate some
cluster when you create a new file in an attempt to reduce fragmentation that
appens when several files are created at once and randomly filled. Once the file
is closed, the unused clusters are liberated. It does the same when all the
file's alocated space is filled ant it need some more disk space. That
prealocated space must reside in successive clusters.
Fix reason firmly in her seat, and call to her tribunal every fact, every
opinion. Question with boldness even the existence of a God; because, if
there be one, he must more approve of the homage of reason, than that of
blindfolded fear.
Thomas Jefferson
Date: 13 Nov 2007 19:56:17
Message: <473a47b1$1@news.povray.org>
>> quite badly.
> about 64 bytes each, and only having less than 0.01% of them actualy
> used... with clusters of 4Kb. You are stuck with many clusters
> containing only 1 record, at some random location in the cluster.
Of course. The file usage on disk grows while it gets downloaded. But in
the end, it will eventually be totally downloaded and extremely
fragmented. So in those cases it's a good idea to pre-allocate. If you
will have lots of "unused records" for long periods, then yes it's a
good idea to let it use sparse files.
Date: 13 Nov 2007 21:30:26
Message: <473a5dc2$1@news.povray.org>
>> something.
I think if you write to it, regardless of what you write, you get
allocated space. UNIX *used* to see an all-zeros buffer and say "Gee, we
don't need to write that."  You didn't have to seek over the sparse
space to make it sparse, IIRC.
I think the calls I'm thinking of are for making an existing data area
sparse, too; i.e., throwing away the beginning of a log file without
changing offsets of existing records. And you may even need to open the
file in "sparse" mode.
Or, I could be completely wrong. This one I never actually did. :-)
Date: 13 Nov 2007 21:31:13
Message: <473a5df1$1@news.povray.org>
>> Jim
What, on FAT?  Nah.  Would have to be some other format, cause FAT
doesn't have the data structures for that.
CP/M did, actually, now that I think of it. :-)
Date: 13 Nov 2007 21:32:09
Message: <473a5e29$1@news.povray.org>
Yah, OK. Looking at it with DIR is 15 meg or so here.  I *thought* that
was kind of funky.
Date: 13 Nov 2007 21:33:33
Message: <473a5e7d@news.povray.org>
Orchid XP v7 wrote:
>> How do you know?
I thought Microsoft was generally considered a good reason to do
anything trivial wrong. ;-)
Date: 13 Nov 2007 21:39:25
Message: <473a5fdd$1@news.povray.org>
>>> something.
Right, as far as I know, if you write 0s without using any special
Windows API, the 0s actually get written (that's the pre-allocation
download programs do).
Date: 13 Nov 2007 22:27:56
Message: <473a6b3c$1@news.povray.org>
Actually, looking it up on MSDN, it seems more complicated than I
thought. :-)  But not something I feel like persuing.
Date: 13 Nov 2007 22:28:34
Message: <473a6b62$1@news.povray.org>
>> Jim
Um, not according to wikipedia:
http://en.wikipedia.org/wiki/Comparison_of_file_systems
Sparse files are supported on NTFS but not any variation of FAT.  Then
again, that table doesn't show NWFS or NSS as supporting sparse files
(which they both do), but lists them as "unknown".
Jim
Date: 13 Nov 2007 23:11:52
Message: <473a7588@news.povray.org>
"Then edit"? :)
Date: 14 Nov 2007 03:10:01
Message: <op.t1rvmyqics6ysw@e6600>
> was kind of funky.
Note that there is an ellipsis there. Most likely the full name was
"ntuser.dat.LOG".
FE
Date: 14 Nov 2007 13:02:08
Message: <473b3820@news.povray.org>
>>> user registry hive. It's 6MB on my machine, no way it can be 1K on
>>> yours.
>> that was kind of funky.
> "ntuser.dat.LOG".
The .LOG is a constant 32KB. Still doesn't match the 1KB he saw.
Date: 14 Nov 2007 13:20:45
Message: <op.t1snwuotcs6ysw@e6600>
On Wed, 14 Nov 2007 19:04:07 +0100, Nicolas Alvarez
>>>> yours.
>> "ntuser.dat.LOG".
At this particular point in time, that file is exactly 1 kB for this user
account on my machine. The size can vary over time, but 1 kB seems to be a
minimum.
FE
Date: 15 Nov 2007 15:21:17
Message: <473caa3d$1@news.povray.org>
> "ntuser.dat.LOG".
Good call. Yes. ntuser.dat.LOG is 1K, 4K on disk, and shows as having 32
fragments today. Considering 1K of data would (AFAIK) fit in the file
table itself, it shouldn't even have *one* fragment. I suspect there's
something funky, like a whole bunch of contiguous "fragments" listed or
some such.
Date: 16 Nov 2007 15:24:57
Message: <473dfc99$1@news.povray.org>
> "Then edit"? :)
Again, the time factor.  But at least on that topic I *can* claim some
expertise.
Jim
