POV-Ray : Newsgroups : povray.off-topic : Bigger plans! Server Time
17 May 2026 10:59:31 EDT (-0400)
  Bigger plans! (Message 31 to 40 of 45)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Bigger plans!
Date: 12 Nov 2007 03:57:05
Message: <47381561$1@news.povray.org>
>> Roughly double your standard 13A cable would do...  Look at the cable
>> going to the starter motor on your car, that's usually 100A or so.
> 1. A car runs on 12V electrics, not 250V. Does that make a difference?
No, the wire has to be the right thickness for the *current*, voltage
doesn't make any difference to its current carrying capability.  That's why
the power grid is at a stupidly high voltage, so that current is lower (for
the same power) and hence the cables can be thinner and less power wasted by
heat.
> 2. Is maximum load proportional to diameter or cross section area? (The
> latter is quadratically propertional to diameter.)
Cross-sectional area.  IIRC the definition of resistance is something like
material_resistivity*length/x-sec_area.  If the resistance of a cable is too
high, then it will get too hot and melt.  Heat dissipated is I^2*R...
> Apparently the planners have access to an A0 printer. I don't even want to
> imagine what that must cost... ;-)
Not *that* much, they just print on a roll of paper and work like an
inkjet - just a bit wider :-)
Date: 12 Nov 2007 03:58:21
Message: <473815ad@news.povray.org>
>>> Like I said, when they hook up the external generator, it comes with a
>>> cable well over 10 cm thick (!)
>> A lot of that thickness will be insulation, shielding and armor.
> Probably.
It will probably be 3-phase as well if you are running large bits of lab
equipment...
Date: 12 Nov 2007 06:29:26
Message: <47383916$1@news.povray.org>
>> Yeah, but that's little compensation if as a result businesses stop using
>> you and you fold
> I don't think you understand what I mean by "absurd amounts of money". ;-)
> [As in, like, if companies *did* stop using us, we'd *still* have so much
> money it wouldn't even matter...]
But what are you going to do with all the money if nobody uses you anymore
because of your reputation of shoddy back-up plans?  How long will that
money last paying everyones salaries? ;-)
Date: 12 Nov 2007 08:07:22
Message: <4738500a$1@news.povray.org>
>>> using you and you fold
>> much money it wouldn't even matter...]
> anymore because of your reputation of shoddy back-up plans?  How long
> will that money last paying everyones salaries? ;-)
Well, it's not really my field, but presumably the people responsible
for this stuff have looked into it quite thoroughly. ;-)
FWIW, we had a freezer fault over the weekend... Interesting coincidence.
Date: 12 Nov 2007 08:09:33
Message: <4738508d$1@news.povray.org>
Phil Cook wrote:
> And lo on Fri, 09 Nov 2007 16:08:36 -0000, Invisible <voi### [at] devnull> did
> spake, saying:
>> Well, I'm sure somebody will have looked at that and decided it's not
>> worth it. (I would think that for more than 3 seconds of cover, you'd
>> need a battery larger than our entire office...)
> You'd think.
Well, 6 mass spectrometers using 450 V electrics... That's gotta eat
juice like candy. If you just wanted to power the freezers, that's
probably quite reasonably - the compressor doesn't even have a 100% duty
cycle, and it's only a small electric motor after all.
Date: 12 Nov 2007 08:45:30
Message: <473858fa$1@news.povray.org>
> Well, it's not really my field, but presumably the people responsible for
Yeh you'd hope so.  Presumably if the penalty amount is high enough, CAT
would hire a helicopter or something to get you the generator on time (if it
came to that) :-)
Date: 12 Nov 2007 09:05:13
Message: <47385d99$1@news.povray.org>
>> Probably.
> equipment...
Never ceases to amaze me how thick 3-phase power cables appear, yet cut
one open, and the wires encased in the cable aren't *that* thick, but
there's a ton of "wadding" around the actual wires inside the cable.
Extra fun when attempting to unplug a 3-phase device for the first time.
I had no idea it had to twist-on.
Date: 12 Nov 2007 09:18:21
Message: <473860ad$1@news.povray.org>
> there's a ton of "wadding" around the actual wires inside the cable. Extra
> fun when attempting to unplug a 3-phase device for the first time. I had
Yeh, we had this oven that was 3-phase, but only something like 23A.
However, like you say, the cable was about 10x wider than a normal 13A mains
cable, so cross-section 100x bigger.  I didn't see inside the cable, but I
guess it was mostly shielding, armour and insulation...
Date: 12 Nov 2007 13:59:30
Message: <4738a292$1@news.povray.org>
>> Cross section area.
> Also depends on AC vs DC.
At 50 Hz, does it matter?
Date: 12 Nov 2007 19:00:47
Message: <4738e92f$1@news.povray.org>
scott nous apporta ses lumieres en ce 2007/11/12 09:18:
>> cut one open, and the wires encased in the cable aren't *that* thick,
>> but there's a ton of "wadding" around the actual wires inside the
>> cable. Extra fun when attempting to unplug a 3-phase device for the
>> first time. I had no idea it had to twist-on.
> mains cable, so cross-section 100x bigger.  I didn't see inside the
> cable, but I guess it was mostly shielding, armour and insulation...
Each individual live whire is isulated, then there is a metal mesh protection,
then an outer protective layer. Then, there is a ground (not isolated) and
possibly a neutral whire. The neutral is also isolated and protected by a metal
mesh. The whole thing is paded with ropes, encassed in an additional isolating
layer, then 1 to 5 metal mesh armouring, plus, possibly a metal sheet shelding,
all wrapt in an outer PVC or polypropylen outer shell.
It all adds up.
When the bosses talk about improving productivity, they are never talking about
themselves.
