POV-Ray : Newsgroups : povray.off-topic : Motherboard question Server Time
2 Mar 2026 16:23:12 EST (-0500)
  Motherboard question (Message 1 to 10 of 11)
Subject: Motherboard question
Date: 7 Nov 2007 08:35:43
Message: <4731bf2f@news.povray.org>
My motherboard was sent to a repair four weeks ago and it's still at the
fabricant. I called the shop where I bought it, and they offered me a
replacement (because it has taken so long by now) - however, this
motherboard can no longer be bought, so I need to get a different model
instead, which he said I should find.
My question is - how big is the impact of inserting a new motherboard in an
existing computer? Will the computer start up like nothing has changed or is
a re-install of Windows necessary? I'm very reluctant to the latter, so I
might wait a bit longer if that is the case.
The other question - how do I find a motherboard compatible with all my
other hardware? I guess processor and graphics card is the only real issue?
The motherboard in question is a Asus A8N-SLI SE / nForce4 SLI / Sata 300.
So which newer model supports all the same things that this one does?
It really annoys me having to deal with all this when I just want my
computer to work again. :(
Rune
Subject: Re: Motherboard question
Date: 7 Nov 2007 09:57:01
Message: <4731d23d$1@news.povray.org>
> Rune
My understanding is that MS OEM software is tied to the motherboard.
It's their way of defining a computer so that you can change things like
the hard drive and what not.
So, if they send you a new motherboard (or even an exact model
replacement) MS can stick it to you.
As far as the drivers and stuff - I don't know.  If it is a very similar
motherboard you might be OK, but I always default to reinstalling myself
just to make things cleaner.
Good Luck!
Tom
Date: 7 Nov 2007 09:58:51
Message: <4731d2ab@news.povray.org>
> Rune
As far as I know, you might need some chipset drivers, but not a full
reinstall (unless there is some retarded "activation" and "anti-piracy"
thing that doesn't work as it should, and locks you out for changing the
hardware).
Also, I think RAM could be another compatibility factor. *Many* years
ago, I wanted to put more RAM on my old computer, and the memory stick
we bought wasn't compatible because it lacked dunno-what-feature that
lets the mobo detect the RAM speed or something, and ended up with twice
the RAM (= a whole 256MB) running at 100MHz. Computer ran faster without
it... back to the shop...
Maybe nowadays there isn't such problem with RAM, but better ask :)
Date: 7 Nov 2007 10:45:19
Message: <4731dd8f$1@news.povray.org>
> an existing computer? Will the computer start up like nothing has changed
> or is a re-install of Windows necessary? I'm very reluctant to the latter,
> so I might wait a bit longer if that is the case.
So long as all the hardware components are actually compatible (and you have
drivers for them just incase), windows will likely just do a load of "found
new hardware" prompts and then work ok after a few minutes (or hours....)
Date: 7 Nov 2007 10:56:32
Message: <4731e030$1@news.povray.org>
Ny opinion is that it would probably be more work than to just wait -
but then again, I guess it depends on just how long they're going to
make you wait for it.
If you have drivers for the new hardware, you'll probably be able to get
it to work. (The fun part is usually removing the existing drivers first.)
So long as the new board supports the same CPU and RAM type (the
graphics card is presumably just PCI-Express?)
Date: 7 Nov 2007 11:10:23
Message: <4731e36f$1@news.povray.org>
Activation-bullshit set apart, Windows will complain a lot (missing peripherals,
bad drivers, 1451 new hardware detected...).  Horrible.
Fabien.
Date: 7 Nov 2007 14:37:20
Message: <op.t1fsshhpcs6ysw@e6600>
On Wed, 07 Nov 2007 14:35:41 +0100, Rune <aut### [at] runevisioncom> wrot
e:
> in an existing computer? Will the computer start up like nothing has
> changed or is a re-install of Windows necessary? I'm very reluctant to
> the latter, so I might wait a bit longer if that is the case.
Having replaced faulty motherboards in I-don't-know-how-many computers,
I
will share my experience (I am assuming you have WinXP):
- If the new MB has the exact same chipset as the old one, chances are
good that Windows will start normally. Some new devices will be detected
and you might even have to install/reinstall a few drivers.
- If the new MB has a different chipset, the odds are worse. If Windows
starts, there will be a lot of new devices found, but no big worries. If
Windows does not start (BSOD with error 0x0000007B is common) you might
get it up and running again by doing a repair install. Following a repai
r
install, you will need to install some drivers as well as all Windows
updates.
- In some rare cases, the hardware is so different that even a repair
install can not salvage your Windows installation. A full reinstall will
be needed.
Regardless of how you get it up and running again, you will need to
reactivate Windows.
y
> issue?
Also memory type, number of memory slots, number of PCI slots etc.
> 300.
I do not know if the situation is different where you live (Norway?), bu
t
over here (Sweden) there are very few MBs still available for socket 939
It has been almost completely phased out.
Possible alternatives (these can still be found in online stores):
ASUS A8V-VM SE
Downsides: Micro-ATX format, so only two memory slots and two PCI slots.
Only two SATA channels. No Gbit LAN (only 10/100). No SLI.
http://www.asus.com/products.aspx?l1=3&l2=15&l3=260&l4=0&model=
1524&modelmenu=2
ASRock 939NF6G-VSTA
Downsides: Micro-ATX format, so only two PCI slots (four memory slots
though). Only one ATA133 connector. No Gbit LAN (only 10/100). No SLI.
http://www.asrock.com/mb/overview.asp?Model=939NF6G-VSTA
FE
Date: 7 Nov 2007 21:18:56
Message: <47327210$1@news.povray.org>
There is really only one way to find out.
John
Date: 8 Nov 2007 04:29:46
Message: <4732d70a$1@news.povray.org>
So I guess there comes a time when every man has to ask himself... Do I
feel lucky?... Well do ya, punk?
Date: 8 Nov 2007 19:24:32
Message: <4733a8c0$1@news.povray.org>
> repair install, you will need to install some drivers as well as all
> Windows updates.
Google around for the story about how a recent windows update installed
stuff without registering it properly, so after a repair install,
windows update doesn't work right any more. There's instructions on
fixing it out there too.
Just FYI.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
