POV-Ray : Newsgroups : povray.off-topic : Small CSS question Server Time
17 May 2026 10:58:42 EDT (-0400)
  Small CSS question (Message 9 to 18 of 38)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Small CSS question
Date: 6 Nov 2007 11:58:45
Message: <47309d45$1@news.povray.org>
Nicolas Alvarez wrote:
>> There's a couple of other settings that do more or less the same thing
>> too. (display:table, etc.) But none does what I actually want. :-(
> And even if they did what you want, you may like to know display:table,
> table-cell, table-row, etc; aren't supported by Microshaft Internet
> Exploder.
...and I care because? ;-) ;-)
Date: 6 Nov 2007 12:05:38
Message: <47309ee2$1@news.povray.org>
>>> thing too. (display:table, etc.) But none does what I actually want. :-(
>> display:table, table-cell, table-row, etc; aren't supported by
>> Microshaft Internet Exploder.
I dunno, some weird people care. And people who make pages that
unfortunately *should* work for everybody. For example, an e-commerce
page that doesn't work on IE means less people wasting money^W^W buying
there.
But even then, it's always fun to have at least a feature or two that
require a correctly-working browser :) "If you have IE, you can still
buy but the site will look ugly; blame Microsoft for that."
Date: 6 Nov 2007 12:10:30
Message: <op.t1drbcl8c3xi7v@news.povray.org>
And lo on Tue, 06 Nov 2007 15:59:06 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> I have the following HTML:
>    <span>A<span>B<span>C</span>D</span>E</span>
> I've set up some CSS to put borders round span elements. It's supposed
> to display as follows:
>    |A|B|C|D|E|
> However, no matter what I do, it actually renders like this:
>    |A|B|C|D|E|F|
> Any idea how I fix this?
What's wrong with this?
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd">
<html>
<style>
span.outer {border: red 1px solid; padding: 20px;}
span.inner {border: red 1px solid; padding: 10px;}
span.centre {border: red 1px solid; padding: 0px;}
</style>
<span class="outer">A<span class="inner">B<span
class="centre">C</span>D</span>E</span>
</html>
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 6 Nov 2007 12:24:43
Message: <op.t1dry0xyc3xi7v@news.povray.org>
spake, saying:
>    |A|B|C|D|E|
>    |A|B|C|D|E|F|
<html>
<style>
</style>
</html>
Phil Cook
Date: 6 Nov 2007 13:21:39
Message: <4730b0b3$1@news.povray.org>
> <html>
> <style>
> </style>
> </html>
Apart from there being an echo in here, that only allows a fixed amount
of nesting. I want to allow arbitrary nesting.
(This is basically for printing out expressions containing insane
numbers of brackets. I want to use borders to help untangle the mess in
some kind of visually-sane way...)
Date: 6 Nov 2007 22:26:52
Message: <4731307c@news.povray.org>
Try making it using the table tools in google docs. THEN look at the HTML
they come up with.
Date: 6 Nov 2007 22:56:34
Message: <47313772$1@news.povray.org>
> they come up with.
Tables would be overkill and *wrong* for this.
http://www.hotdesign.com/seybold/
Date: 7 Nov 2007 04:06:29
Message: <op.t1ezimvmc3xi7v@news.povray.org>
And lo on Tue, 06 Nov 2007 18:21:42 -0000, Orchid XP v7 <voi### [at] devnull>
did spake, saying:
>> <html>
>> <style>
>>  </style>
>> </html>
I saw spans used that you said produced a fixed height block, I saw divs
used with and without floats; I didn't see this suggestion.
> that only allows a fixed amount of nesting. I want to allow arbitrary
> nesting.
Which you didn't mention.
n
count the number of brackets and times by two then set the padding that
way so
(A(B(C)D)E) is 6 then replace every ( with a padding=n-(i*2) i++
<html>
<style>
span {border: red 1px solid;}
</style>
<span style="padding:6px">A
<span style="padding:4px">B
<span style="padding:2px">C
</span>
D</span>
E</span>
</html>
I'm sure you can get one of the languages you use to do something like
that.
Phil Cook
Date: 7 Nov 2007 04:36:18
Message: <47318712$1@news.povray.org>
> did spake, saying:
>> nesting.
Oh alright then. ;-)
>> in some kind of visually-sane way...)
> way so
> <html>
> <style>
> </style>
> </span>
> D</span>
> E</span>
> </html>
> that.
Well, that'll work... but surely there's some W3C compliant way of doing
this transparently without such low-level hacks?
(I still don't understand why having a large box inside doesn't cause
the containing box to enlarge itself...)
Date: 7 Nov 2007 05:22:24
Message: <op.t1e200osc3xi7v@news.povray.org>
And lo on Wed, 07 Nov 2007 09:36:17 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> did spake, saying:
<snip>
>> that.
This is a W3C compliant way - HTML+CSS, what's not compliant about it? The
only thing you can moan about is the use of style in a strict.
It does if you use a block rather then an inline element.
Phil Cook
