POV-Ray : Newsgroups : povray.off-topic : Plans Server Time
15 Jun 2026 05:53:14 EDT (-0400)
  Plans (Message 16 to 25 of 35)
Subject: Re: Plans
Date: 6 Nov 2007 10:13:32
Message: <4730849c$1@news.povray.org>
Invisible wrote:
> Also, next to the stairs, I found this:
>   OVERALL RISE OF STAIR 3825mm
>   EACH RISE: 165mm (x23)
>   EACH GOING: 250mm.
>   BALUSTRADE TO BE TOP FIXED.
>   DESIGN TO COMPLY WITH B.REGS
>   PART K & M.
> I just love the way they quote the size of a flight of stairs in
> millimeters! I mean, it rises 12 feet up, and we care about 25mm?
Hey, I just noticed. The individual stairs are numbered. As in, from 1
to 23. Wow!
There's also a small barely-readable table that says
    C   ARCHIVE STORE / INST. ROOMS RESETOUT  01.10.07  SH   DS
    B   DOOR REFS ADDED. DIMS UPDATED         28.08.07  SH   DS
    A   ISSUED FOR COMMENT                    15.08.07  SH   DS
   REV  DESCRIPTION                           DATE      DWN  CKD
I notice that in the middle of the building there's a line of what look
like H-section girders. Each one has a dashed line going through it,
ending in a unique letter on the outside of the building.
(To give you some idea, the lines C, D, E and F are all parallel and
equidistant. However, F and G are *not* parallel. The exterior walls on
particular, this means that the corridore to my office and my server
room has non-parallel walls. Let's hope I don't need to wheel anything
large through there!)
There's also lots of little enigmatic annotations such as
   BELOW GROUND
   DRANAGE CONNECTION
   FOR WHB
and
   STUB STACK
and
   sinks/washers
   see fittings
and
   RWP
   INTO
   BG.
Ooo, I just found a small space that looks like this:
   |   RISER   |
Hahahah! Some poor **** is going to have great fun building THAT...
There's also lots of circles with numbers in them. Or bisected circles
with pairs of numbers in them.
I'm sure all this means something to the guys drawing the plans. ;-)
Subject: Re: Plans
Date: 6 Nov 2007 11:16:01
Message: <47309341@news.povray.org>
>   |   RISER   |
What the...
Subject: Re: Plans
Date: 6 Nov 2007 11:16:46
Message: <4730936e@news.povray.org>
You should ask for 3D plans in .pov format. Or make them?
Subject: Re: Plans
Date: 6 Nov 2007 11:22:29
Message: <473094c5$1@news.povray.org>
OMFG... POV-Ray FTW!! :-D
Subject: Re: Plans
Date: 6 Nov 2007 11:58:26
Message: <47309d32@news.povray.org>
>>   | 87°    94°|
>>   |   RISER   |
>>   | 90°       |
> What the...
Should probably be more like:
+--..__
|87     ''--.._
|            94|
|90            |
...still not too fun to build.
Tim Cook
Version: 3.12
Subject: Re: Plans
Date: 6 Nov 2007 12:23:52
Message: <op.t1drxlx8c3xi7v@news.povray.org>
And lo on Tue, 06 Nov 2007 11:40:26 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> I'm just sitting here looking over the plans for our new building at
> work. It looks roughly like a tangled maze of lines, encrusted with text.
> Some of the text is in fact almost unreadable because it's so tiny. Even
> when printed out, I can bearly read it. I had a look at the PDF file,
> and it says the document dimensions are "23.39 x 33.11 inches". A quick
> trip to Google tells me that's 594.106 x 840.994 mm. (Wow, that sounds
> pretty big!) A quick check on Wikipedia tells me that's exactly A1. (!!)
> So, where the plan says "1:50 scale", it's really "1:400" when printed
> on A4 instead of A1.
Taking into account that the software may have 'fixed' it to print within
your printer margins.
> The drawing contains a number of items of interesting text. For example,
> this is "DWG NO 2222.173". It is described as "GROUND FLOOR PLAN, OFFICE
> B SETTING OUT".
>    EACH GOING: 250mm.
>    PART K & M.
Yes if you want it to be 12 feet up when it races the top.
> I have no idea what "BALUSTRADE" is. (Assuming I've even read it right
> from the tiny writing on the printout.)
It's that bit that stops you from falling off the side of the stairs.
> Similarly, ever head of "BRISE SOLEIL"? Because apparently this building
> will have *lots* of those.
Sun-shade.
> But most of all, it's just numbers. *Millions* of numbers. Almost every
> line has a second line next to it with some numbers. Many of the corners
> there are dashed lines *everywhere*.
> (I just reliased... Every single doorway in the place has a unique ID
> written on it. Wow.)
Yup
> There are also all sorts of symbols that look like they probably mean
> something to a building engineer. Means nothing to me though! Heh.
Yup again
> It's certainly interesting anyway...
Looking at building plans is always fun.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Subject: Re: Plans
Date: 6 Nov 2007 13:24:01
Message: <4730b141$1@news.povray.org>
> spake, saying:
>> Even when printed out, I can bearly read it. I had a look at the PDF
>> file, and it says the document dimensions are "23.39 x 33.11 inches".
>> A quick trip to Google tells me that's 594.106 x 840.994 mm. (Wow,
>> that sounds pretty big!) A quick check on Wikipedia tells me that's
>> exactly A1. (!!)
> within your printer margins.
True...
Perhaps that's why part of the building is missing? Or maybe it's just
that this particular drawing only includes that part, I'm not sure.
I'm glad someone else thinks so.
I have no idea what half the stuff means, but I'm nosey anyway! ;-)
Subject: Re: Plans
Date: 6 Nov 2007 13:24:50
Message: <4730b172@news.povray.org>
>>>   | 87°    94°|
>>>   |   RISER   |
>>>   | 90°       |
>> What the...
> +--..__
> |87     ''--.._
> |            94|
> |90            |
That's a tilt of a tad more than 4°, but essentially yes. ;-)
(On the paper it sure looks like a perfect square. But there we are.)
Subject: Re: Plans
Date: 6 Nov 2007 13:29:56
Message: <4730b2a4$1@news.povray.org>
>> That's because people who build the stairs works with that order
>> of tolerance (mm).
> So... what the hell do you do if you build some stairs, and the sement
> sinks by 0.4 mm while drying? (A perfectly likely outcome.) Then each
> step might be 0.4 mm out...! No noes! o_O
Who secures stairs in place by resting them on unset concrete? :-S
Subject: Re: Plans
Date: 6 Nov 2007 13:31:20
Message: <4730b2f8$1@news.povray.org>
>>> of tolerance (mm).
I was thinking more that the *stairs* are made of concrete...
