POV-Ray : Newsgroups : povray.off-topic : Plans Server Time
9 Jun 2026 15:43:05 EDT (-0400)
  Plans (Message 11 to 20 of 35)
Subject: Re: Plans
Date: 6 Nov 2007 09:36:34
Message: <47307bf2$1@news.povray.org>
Fa3ien wrote:
>> (I just reliased... Every single doorway in the place has a unique ID
>> written on it. Wow.)
> That's pretty normal. The drawing is probably linked to some spreadsheet
> saying how much doors of what type are needed.
I wonder if that's what "FD30SC" means? (Every door seems to have this
written next to it, in addition to a unique number of the form "DB7".)
Subject: Re: Plans
Date: 6 Nov 2007 09:38:05
Message: <47307c4d@news.povray.org>
Vincent Le Chevalier wrote:
> It's all French words :-) That said, Wikipedia can help:
> http://en.wikipedia.org/wiki/Brise_soleil
> http://en.wikipedia.org/wiki/Baluster (read the first paragraph and not
> just the title)
Ah... So that useless bit that sticks out of the front of the building
is meant to be a sun shade?
[Interesting how all the buildings constructed so far have an identical
projection, despite facing different directions. I mean, surely the sun
can only rise from one direction... And sides, it's far too tiny to
shade anything except the top of the roof.]
Subject: Re: Plans
Date: 6 Nov 2007 09:56:39
Message: <473080a7$1@news.povray.org>
FD = Framed Door ? (such conventions are hardly universal)
30 = maybe 30 minutes fireproof ? on the leaf is 30 inches wide ?
SC = Single C???... ?
Sometimes there's an explanation on the edge (along with the meaning of hatches).
Fabien.
Subject: Re: Plans
Date: 6 Nov 2007 10:01:57
Message: <473081e5$1@news.povray.org>
for example, we name our doors like :
PSF-93-10
09F 2.20
(both symbols grouped in an hexagon)
which means :
Porte Simple Feu (Single door, fire resistant)
93 cm leaf in a 10 cm wall
the lower symbol is the room to which the door gives access
09 (underground, 00 is ground, 01 1st level...)
F : zone F (fire detection zone)
2.20 : hierarchic geographical numbering within a zone
Subject: Re: Plans
Date: 6 Nov 2007 10:05:57
Message: <473082d5@news.povray.org>
> hatches).
Not this time there isn't.
It's probably a catelogue number, and if you had their catelogue you
could look it up.
(I recall apparently there was a long debate about whether the doors
would be stained wood, or whether they would be painted black. The
designers were concerned that wood would clash with the white walls and
black skirting boards. [I kid you not!] IIRC, they eventually decided on
stained wood doors with black door frames...)
Subject: Re: Plans
Date: 6 Nov 2007 10:13:32
Message: <4730849c$1@news.povray.org>
Invisible wrote:
> Also, next to the stairs, I found this:
>   OVERALL RISE OF STAIR 3825mm
>   EACH RISE: 165mm (x23)
>   EACH GOING: 250mm.
>   BALUSTRADE TO BE TOP FIXED.
>   DESIGN TO COMPLY WITH B.REGS
>   PART K & M.
> I just love the way they quote the size of a flight of stairs in
> millimeters! I mean, it rises 12 feet up, and we care about 25mm?
Hey, I just noticed. The individual stairs are numbered. As in, from 1
to 23. Wow!
There's also a small barely-readable table that says
    C   ARCHIVE STORE / INST. ROOMS RESETOUT  01.10.07  SH   DS
    B   DOOR REFS ADDED. DIMS UPDATED         28.08.07  SH   DS
    A   ISSUED FOR COMMENT                    15.08.07  SH   DS
   REV  DESCRIPTION                           DATE      DWN  CKD
I notice that in the middle of the building there's a line of what look
like H-section girders. Each one has a dashed line going through it,
ending in a unique letter on the outside of the building.
(To give you some idea, the lines C, D, E and F are all parallel and
equidistant. However, F and G are *not* parallel. The exterior walls on
particular, this means that the corridore to my office and my server
room has non-parallel walls. Let's hope I don't need to wheel anything
large through there!)
There's also lots of little enigmatic annotations such as
   BELOW GROUND
   DRANAGE CONNECTION
   FOR WHB
and
   STUB STACK
and
   sinks/washers
   see fittings
and
   RWP
   INTO
   BG.
Ooo, I just found a small space that looks like this:
   |   RISER   |
Hahahah! Some poor **** is going to have great fun building THAT...
There's also lots of circles with numbers in them. Or bisected circles
with pairs of numbers in them.
I'm sure all this means something to the guys drawing the plans. ;-)
Subject: Re: Plans
Date: 6 Nov 2007 11:16:01
Message: <47309341@news.povray.org>
>   |   RISER   |
What the...
Subject: Re: Plans
Date: 6 Nov 2007 11:16:46
Message: <4730936e@news.povray.org>
You should ask for 3D plans in .pov format. Or make them?
Subject: Re: Plans
Date: 6 Nov 2007 11:22:29
Message: <473094c5$1@news.povray.org>
OMFG... POV-Ray FTW!! :-D
Subject: Re: Plans
Date: 6 Nov 2007 11:58:26
Message: <47309d32@news.povray.org>
>>   | 87°    94°|
>>   |   RISER   |
>>   | 90°       |
> What the...
Should probably be more like:
+--..__
|87     ''--.._
|            94|
|90            |
...still not too fun to build.
Tim Cook
Version: 3.12
