POV-Ray : Newsgroups : povray.off-topic : Haskell raving Server Time
2 Jul 2026 05:07:07 EDT (-0400)
  Haskell raving (Message 13 to 22 of 92)
Subject: Re: Haskell raving
Date: 31 Oct 2007 13:25:00
Message: <web.4728c74c7b4224e7773c9a3e0@news.povray.org>
> Tim Attwood <tim### [at] comcastnet> wrote:
> > readFile "filename" >>= process
>   Btw, how do you actually read the contents of the file in haskell with
> a command like that? What is the unit type? Can you read, for example,
> one byte at a time? What if you would want to parse an ascii-formatted
> input file, for example? How is it done exactly?
http://haskell.org/ghc/docs/latest/html/libraries/base/Prelude.html#v%3AreadFile
readFile returns a String.  But don't despair:  it won't fill the whole memory
with a giant string for large files!  Lazyness means values are only evaluated
once needed.  If you just take the whole contents, yes, you'll be sorry.
Otherwise, you can use a function like "take 5 string" and it'll only take the
first five characters (a string is merely a list of characters in Haskell).
You may process it with folds or other higher-order functions.
To ilustrate lazyness in a simple REPL example:
ones = 1:ones
take 5 ones
take 5 (map (*2) ones)
ones is of course an infinite, recursively-defined list.  If you just evaluate
it at the prompt, the REPL will begin filling your screen with ones or worse
(like filling your memory).  The same for simply doing map (*2) ones which will
try to double every 1 in ones.
But lazyness means we can restrict the evaluated value to just a few members
from this infinite data structure, which is what we do by taking one a few.
So, with lazyness, size really doesn't matter.
Of course, there are other useful IO functions out there that offer more control
over opening/closing file handles etc.
Date: 31 Oct 2007 14:58:57
Message: <4728de81@news.povray.org>
That didn't really answer the question of whether it is able to drop
the parts which are no longer used.
Date: 31 Oct 2007 16:05:26
Message: <4728ee16@news.povray.org>
Tim Attwood wrote:
>>> When memory comes into play you might need destructive
>>> updates to arrays, etc.
>> Which is only a problem if your compiler isn't smart enough, or disallows
>> providing the appropriate hints. :-)
> The point is that there is no way for a compiler to decide.
...which is why you have the hints... ;-)
Date: 31 Oct 2007 16:08:56
Message: <4728eee8$1@news.povray.org>
somebody wrote:
> The simple fact is any argument for Haskell and against other languages will
> be valid when - scratch that - *if*  people start writing killer
> applications, a killer OSs, APIs and killer games in Haskell.
> Ah, I stand corrected, here's a killer game:
> http://www.geocities.jp/takascience/haskell/monadius_en.html   <g>
> from
> http://www.haskell.org/haskellwiki/Applications (2nd on list)
> I cannot imagine what Haskell will bring us in another 20 years. "A
> scientist's toy box" is aptly where Haskell belongs.
Hmm... You're not going to talk about Haskell Quake then?
http://www.haskell.org/haskellwiki/Frag
Hardly "killer" (unless you'll pardon the pun), but at least a little
more exciting...
One could legitimately level the claim that only real large-scale
programs written in functional languages so far have been... compilers
for more functional languages.
Still, I gather that Xilinix's current toolchain for FPGAs is based on
Haskell technology. A few other blue-chip peeps are using it. Again, not
really "killer" - for that, you must look to Erlang. *sigh*
Date: 31 Oct 2007 16:15:52
Message: <4728f088$1@news.povray.org>
Warp wrote:
>   However, I'm wondering what happens with huge files (which won't fit
> in memory) and which you read thoroughly. It could be, for example, a
> video file (which could be, for example, 3 gigabytes big, while your
> computer has only eg. 1 gigabyte of RAM).
>   The usual way of doing this is to read a bunch of data from the file
> (for example some megabytes), process it, discard it, read a new bunch
> of data from the file, etc.
>   What I'm wondering is what a language like haskell will do in this case,
> even though it has lazy evaluation. In fact, lazy evaluation is of no
> help here because you are, after all, reading the entire file. If you
> use the completely abstract way you could end up having the haskell
> program trying to read the entire file into memory, thus running out of it.
Not so.
>   You have to somehow be able to tell it that you are only going to need
> small bunches at a time, and after they have been processed, they can be
> discarded. I wonder if there's a really abstract way of saying this in
> haskell, or whether you need to go to ugly low-level specifics.
There is. It's called a garbage collector. ;-)
Simply let lazy evaluation read the file as required, and the GC can
delete the data you've already processed transparently behind you.
In this way, linearly processing a file in constant RAM usage is pretty
trivial in Haskell.
Now, *random* access... *that* presents a bit more of a problem. (For
the love of God, don't accidentally hang on to pointers you don't need
any more! You could end up loading the entire file into RAM - and,
obviously, that would be "bad".)
Date: 31 Oct 2007 16:17:28
Message: <4728f0e8@news.povray.org>
Garbage collection.
In Haskell, a "string" is a linked-list of characters. Let go of the
pointer to the start of the list and all elements up to the first one
you've still got a pointer to will be collected and freed.
Date: 31 Oct 2007 16:28:34
Message: <4728f382$1@news.povray.org>
First of all, reading binary data in Haskell is currently "messy".
Haskell tends to assume that files contain plain ASCII. (If you want to
be technical, it usually reads 8 bits at a time, and interprets these
literally as a Unicode code-point.)
That aside, the readFile function gives you (conceptually) a giant
string representing the entire contents of the file. In typical Haskell
fasion, this doesn't get actually created until you "look at it".
If you wanted to parse a text file, you'd likely read the whole file
into a string (conceptually) and then pass that over to your parser. The
parser just knows how to parse strings; it doesn't have to care that
*this* string is being transparently read from a file first.
Similarly, if you had a function that takes a string and returns the
decrypted form of that string, you could apply that to the thing
returned from readFile and then pass the answer to your parser. The
result is that the decryption function only decrypts data as the parser
tries to demand it (due to lazy evaluation). All that stuff that Java
does with layering stream filters is just function calls in Haskell.
Now, the flip side to all this is that lazy file reading can bite you.
For example, one guy wrote some program that would crash with an OS
error complaining about too many open file handles. Letting go of a
pointer to a file handle causes the file to be closed WHEN THE GC RUNS,
however exhausting the OS handles limit does not trigger the GC...
There is a certain faction of the Haskell community that considers
readFile and its ilk to be "evil" and who say you should do things the
manual way. For example, check this out:
   main = do
     data <- readFile "foo.txt"
     deleteFile "foo.txt"
     writeFile "bar.txt" data
This doesn't work at all. If you run this, the behaviour is technically
undefined, but generally you will get some kind of OS error. Put simply,
the first line doesn't *really* read any data - but then you try to
delete the file (which hasn't actually been read yet, only opened), and
then write the data to another file (which causes it to actually be
read). Usually deleting the file is where it will bomb out - the OS will
usually complain that you can't delete an open file...
Somebody did suggest a file that lazily reads directory structures, and
allows you to lazily modify them. The general reply was "OMG, NO!!"
As you might expect, Haskell provides primitives for doing file I/O the
"normal" way. In other words,
   openFile
   hCloseFile
   hReadLine
   hPutStrLn
   hFlush
   etc.
For interactive stuff at a minimum, it's usually critical to control
exactly *when* I/O happens. And the only way to do this is... to specify
exactly when I/O happens. No way round it.
Date: 31 Oct 2007 16:46:56
Message: <4728f7d0$1@news.povray.org>
>>> disallows providing the appropriate hints. :-)
> ....which is why you have the hints... ;-)
Or iterative optimizations, like big SQL servers do.  The program runs
profiled a few times, and tells the linker/compiler which versions run
faster etc.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 31 Oct 2007 16:49:24
Message: <4728f864$1@news.povray.org>
Mmm... big SQL servers do this because which method is faster *strongly*
depends on the exact data being queried. It's just not possible to make
reasonable decisions at design-time, it must be at run-time.
I'm not sure all programs face quite such colossal challenges as an SQL
system... ;-)
Date: 31 Oct 2007 17:17:47
Message: <4728ff0b@news.povray.org>
The answer is yes, mostly.
Data is automatically destroyed as it goes out of scope. So if you
have a process that works one line at a time, then one line at a time
will be disposed, if you have a process that works on single chars
then one char at a time is disposed.
In general, Haskel takes some input to a function,
produces some new data output in fresh memory,
and then disposes of the input,
and frees that memory if no other function references it,
eventually GC reclaims the memory. (or you can
manually trigger a GC if you want).
File IO is imperative, so it can be treated in manners
typical of other languages. You don't need to bind >>=
files to processes, it's perfectly OK to read one line
at a time and do something with it until the EOF is reached.
