POV-Ray : Newsgroups : povray.off-topic : Life Sucked at My School This Week Server Time
9 Jun 2026 21:22:46 EDT (-0400)
  Life Sucked at My School This Week (Message 31 to 40 of 58)
Subject: Re: Life Sucked at My School This Week
Date: 21 Oct 2007 11:35:03
Message: <471b71a7$1@news.povray.org>
Orchid XP v7 wrote:
> Actually, anyone who's ever played with one of these will confirm a very
> disturbing fact: Almost *everything* is slightly radioactive! Seriously.
> Everything I put near the thing registered very slightly. Including my
> lunch...
In the USA, it's illegal to build a nuclear reactor out of quarried
rock, as the rock is more radioactive than the reactor is allowed to
leak. Seems kind of silly to me.
M_a_r_c wrote:
 > One of the biggest lies from French authorities : "the Tchernobyl
cloud did
 > not pass the French boundaries"
As I understand it, the disaster got noticed because the workers in the
Swedish nuclear reactors were arriving more radioactive than they were
leaving.
On the other hand, some level of radiation is actually even necessary
for good health. So it's all in the dosage, really.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 21 Oct 2007 11:43:57
Message: <471b73bd@news.povray.org>
"Michael Raiford" <mra### [at] hotmailcom> wrote in message
news:471b6742@news.povray.org...
> > - Apparently if you mix amonia and some other compound together, the
> > resulting mixture explodes when it dries out. We smeared it over a
> > cardboard box in the garden. For some reason, it only ever exploded at
> > night... A succession of small pops and bangs.
> sounds like nitrogen triiodide. Contact explosive... supposedly fun
stuff..
Crackle powder (I think). We had great fun with that at university. Scatterd
some across the cmp sci main office floor. Was a thick pile carpet. For some
reason we weren't popular the next morning... *g*
Date: 21 Oct 2007 11:45:43
Message: <471b7427@news.povray.org>
"Brian Elliott" <NotForSpam@AskIfUWant> wrote in message
news:471b6c5d$1@news.povray.org...
> Selecting from tables, their column definitions and table data are only a
> small part of getting the data and structure out:  I have to get the
entire
> application out.  I would also have to make SQL to recreate:
> Table type (heap, index-organised, cluster, partition) Definitions of all
> indexes and constraints on each table, foreign-key constraints to other
> tables, tablespace and storage info, remembering again to do the same for
> each of its indexes.
> Triggers on the tables -- PL/SQL code that fires before/after an
> insert/update/delete.
> Sequences, including the number they are now at. (So new sequences are
> created from that starting point instead of starting at one)
> Views -- named SQL that can be selected and joined as one uses a table in
> most places.
> The program code stored in PL/SQL functions, procedures and packages.
> Jobs.  Ugh, I know the least about these.  I'm sure OEM will have job
> schedules registered in the database engine.
Dunnon about Oracle, but in MS SQL, all of those are stored in tables as
well and are scriptable, providing you know the right tables.
Date: 21 Oct 2007 11:54:38
Message: <471b763e$1@news.povray.org>
And to the extent they aren't, you don't have a relational database. Of
course, now with some places doing things like storing non-SQL compiled
code in the database, it's more difficult to make valid backups just by
copying data without copying structure.
Date: 21 Oct 2007 12:14:24
Message: <471b7ae0@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:471b7099$1@news.povray.org...
> Michael Raiford wrote:
>> school campus heard the resulting bang.
> I had friends who worked at a science museum (the Franklin Institute)
> giving lectures and such. One day Tony filled a 3-foot weather balloon
> with hydrogen and oxygen, and put it on a long thread so it floated near
> the top of the lecture hall. (Picture a stadium-seating huge room like you
> see college lectures being given in in movies.) Then he points the
> parabolic heat lamp at it and turns off all the switches.
> Kurt goes in, turns on all the lights, starts his lecture on liquid air. I
> walk in, and Tony is in the back of the room, going "SHhh! Shhh!"
> About five minutes into the lecture, there's a kaBOOM that literally
> cracks some of the windows.  Kurt jumps about three feet, looks around,
> waves to Tony, and goes back to lecturing.
> (This is the same Tony that couldn't figure out where the cardboard
> canister he'd stuffed home-made high explosives into went after he touched
> it off and blew a 3-foot deep crater in the dirt.)
Two of my favourite things were tins of sodium hydroxide and rolls of
aluminium foil.  Put together in water, they produced plenty of hydrogen,
which I and a mate filled many balloons and garbage bags with.  Had to be
careful, as it is highly exothermic and the mix can easily boil.  We used to
tie sparklers to the necks, light them, and float them off.  The balloon
would explode just as the sparkler got near the end of its burn.  Looked
good at night.
I also used to make bangs with two large bolts, one large hexagonal nut and
a lot of match-heads.  Half-screw one bolt into the nut, scrape the
phosphorous from several matches into the well, screw in the other bolt,
then throw it at a concrete surface or hit it end-on with a hammer.  Four or
five heads was enough to make a bang.  Twenty matches was enough to make an
air-splitting gunshot explosion.  On that occasion, one bolt completely
stripped out of the thread and went so far from the point of impact that we
never found it.
We were smart enough to duck behind a pile of rocks while it was still in
midair.
And one strange thing:  Back when the flints on the sides of matchboxes were
made more substantially than they are today.  Peel them off the sides of the
matchbox.  Strip as much cardboard off their backs as you can, to get the
brown flint/phosphor patch on the thinnest paper layer possible.  Place it
face-down on a cold tin lid.  Burn it.  It fizzes a bit like a match head,
but the flame is smoky and smelly.  Blow off any ash. You find an orangeish
semi-liquid condensate on the lid.  Dip a forefinger tip in it, then rub
your thumb and forefinger together.  White smoke rises from your fingers.
In the dark, it glows when you do this.
Brian
Date: 21 Oct 2007 13:07:07
Message: <471b873b$1@news.povray.org>
And I thought you were such a *good* little girl... :-0
Date: 21 Oct 2007 13:12:03
Message: <471b8863$1@news.povray.org>
> sounds like nitrogen triiodide. Contact explosive... supposedly fun stuff..
Yeah - I recall iodine being involved...
>> - There's a trick you can do with (IIRC) hydrogen chloride. It absorbs
>> water quite well. So if you will a bottle with hydrogen chloride and
>> then put a tube into a tub of water, you get a little fountain inside
>> the bottle as the pressure drops. For added amusement, add some
>> indicator to the water. (I recall the blue liquid emerging in the
>> bottle as a bright yellow fountain.)
> I think I need a diagram to understand this one. the description of the
> set up is a bit unclear.. Hmm.
Take a bottle of HCl gas with a cork and a straw. Insert the straw into
a tub of water. The HCl is adsorbed by the water, causing the water to
be sucked into the bottle forming a little fountain. If you add a pH
indicator, you'll see the water go from 7 to (roughly) 3.
> Actually, I don't know if its the same for the UK, but in the US,
> potassium permaganate is apparently (according to Wikipedia) considered
> a drug precursor and is apparently difficult to get without going
> through all sorts of DEA procedures and forms.
Apparently in the USA, so is LiOH... (How random is that? Drop some
lithium into a vat of water and you have a controlled substance. Heh!)
Doesn't appear to be a problem in the UK.
Date: 21 Oct 2007 13:12:57
Message: <471b8899$1@news.povray.org>
"Oh well - a little water never hurt anyone."
"Yeah, but a lot can KILL ya!"
Date: 21 Oct 2007 13:15:37
Message: <471b8939$1@news.povray.org>
> were made more substantially than they are today.  Peel them off the
> sides of the matchbox.  Strip as much cardboard off their backs as you
> can, to get the brown flint/phosphor patch on the thinnest paper layer
> possible.  Place it face-down on a cold tin lid.  Burn it.  It fizzes a
> bit like a match head, but the flame is smoky and smelly.  Blow off any
> ash. You find an orangeish semi-liquid condensate on the lid.  Dip a
> forefinger tip in it, then rub your thumb and forefinger together.
> White smoke rises from your fingers. In the dark, it glows when you do
> this.
I'm begining quite concerned about the people I'm hanging round with... o_O
Date: 21 Oct 2007 14:00:10
Message: <471b93aa@news.povray.org>
"Orchid XP v7" <voi### [at] devnull> wrote in message
news:471b873b$1@news.povray.org...
Scatterd
some
I wasn't the brains behind this one. Besides, I didn't have access to the
chem lab.
Most of the honours class was in on the prank.
