POV-Ray : Newsgroups : povray.off-topic : Mac Plus vs AMD Dual Core Server Time
27 Jun 2026 19:42:55 EDT (-0400)
  Mac Plus vs AMD Dual Core (Message 81 to 90 of 170)
Subject: Re: Mac Plus vs AMD Dual Core
Date: 24 Oct 2007 15:03:44
Message: <471f970f@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Oh, and Warp, they aren't "unsigned integers" and "signed integers" in
> C. They're "ints", not "integers".  ;-) That's the root of the problem.
> Mixing signed integers and unsigned integers are fine. It's just C's
> weird conversion rules for ints that are problematic. ;-)  </nit>
  So the implicit conversion rules of C for signed and unsigned integers
are weird? Care to suggest better conversion rules?
Date: 24 Oct 2007 15:13:58
Message: <471f9976@news.povray.org>
> There's the problem right there.  As one professor I knew put it, "There
> are two kinds of languages. The ones that support unbounded arithmetic
> types, and the ones that don't know they need to support unbounded
> arithmetic types."
  Having automatic unbounded arithmetic types is fine as long as you don't
care about efficiency.
  Integral types which support unlimited precision can *not* be as efficient
as CPU-register-sized integers unless you explicitly tell to the compiler
that "this variable will always stay within these limits", in which case
you are already stuck with the same limitation as the C integral variables.
If you don't tell the compiler those limits and it has to make sure that
in case of overflow it switches to unlimited precision, then those integral
types simply cannot be as fast as the bounded ones. It's just physically
impossible. If nothing else, the compiler will have to add an overflow
check after each single operation done with those integers, thus adding
clock cycles and code size (filling code caches faster).
  I'm also sure that being forced to prepare for unlimited precision math
makes many compiler optimizations impossible (which would be possible with
register-sized integers).
  (Also, in the general case a compiler cannot deduce by examining a piece
of code that a variable will never have a value outside certain boundaries.
I'm certain this kind of check would be equivalent to the halting problem.)
Date: 24 Oct 2007 15:14:18
Message: <471f998a$1@news.povray.org>
Aw quit yer complainin' and write your own microscopic software if you
wants it.  That's the proper *nix-user attitude.  XD
Tim Cook
Version: 3.12
Date: 24 Oct 2007 15:21:15
Message: <471f9b2b@news.povray.org>
  That's right. Open Office is open source, so it's a good start. Go and
optimize it until it's small enough for your taste.
Date: 24 Oct 2007 15:22:25
Message: <471f9b71$1@news.povray.org>
Arguably it would be faster to start again from scratch rather than try
and learn the OO codebase... :-S
Date: 24 Oct 2007 15:44:53
Message: <471fa0b5$1@news.povray.org>
On Wed, 24 Oct 2007 18:57:07 +0100, Orchid XP v7 wrote:
> Indeed no - their job is to research new techniques for slowing software
> down as much as possible to boost sales of expensive new hardware.
> (Presumably this is why the hardware vendors love them so much...)
That's been my working theory for years.  Goes something like this:
NetWare:  Solid, stable, reliable OS.  No possibility for hardware
upgrades (until 4.x came out) or extended support contracts, because it
just worked.
Windows:  Higher hardware requirements, not as stable as NetWare, so
requires ongoing maintenance, support, and you hope that they'll fix the
bugs in the current version in the next version so you have an upgrade
opportunity.  Of course, with the new version comes higher hardware
requirements, so the vendor gets to make their hardware sales quotas, and
you'll want support as well, so a reseller can also sell a support
contract with the hardware and SW installation.
Things have changed a bit over the last few years, of course, but I never
wondered why resellers didn't push NetWare over Windows, and I still
don't.  There's no money in it for them.
I've always said that Microsoft was the king of making software that was
"just good enough".  IOW, it's good enough that most people are not
willing to go to the expense of switching, even though there's plenty to
complain about.  They then managed to find the right upgrade price point
that played to the business people - the point at which it's too
expensive *immediately* to switch to something better as opposed to just
getting the upgrades and praying.  Businesses that tend to look more than
a quarter or two out on their financial planning tend to be more likely
to switch; businesses where turnover is fairly high and people are only
concerned about the next couple of quarters' worth of spending are less
likely to switch.
Jim
Date: 24 Oct 2007 15:47:30
Message: <471fa152@news.povray.org>
On Wed, 24 Oct 2007 11:26:11 -0700, Darren New wrote:
> Jim Henderson wrote:
>> To someone with a little background in C
> arithmetic types."
Yep, I can see that - the need for arbitrary-size variables (and the
supporting math libraries) has become much more important.
That said, though, I'm talking about a product developed over 10 years
ago, and from having seen bits of the source code and knowing many of the
developers, that would've been the "language of choice" at the time.
> I can't tell you how many tools I went through looking for one that
> would handle a file >4G for restartable downloads. I finally had to
> install bittorrent at both ends just to move the file across the
> network.  In spite of the fact that FTP uses ASCII representations for
> all numbers, and hence has no inherent limitation in the protocol.
I see that problem all the time myself as well - I make downloads
available for a limited audience using a tool that has problems with IE7
(of all things) because they're too big - FF doesn't have a problem with
them, and many of the download managers we suggest also work fine (I use
wget and never have a problem with > 4 GB file sizes).
Jim
Date: 24 Oct 2007 15:51:18
Message: <471fa236$1@news.povray.org>
Doubt it, otherwise new coders coming into the project would never get
started (into any project, for that matter).
I got access to the code for one of the products I used to support, and
it was several million lines of code.  The engineering manager who
granted me the access said they *normally* spend at least 6 solid months
of examining and learning the code before they're allowed to commit
changes.
And that's a minimum of 8 hours a day of doing code review...for 6
months...
Jim
Date: 24 Oct 2007 16:14:49
Message: <471fa7b9$1@news.povray.org>
I always wondered about this... How *do* you get started on a new
project with millions of lines of code and no documentation?
(I've looked at a couple of such projects, but failed to learn anything
of use. I just couldn't figure out what the heck any of it is...)
Date: 24 Oct 2007 16:32:58
Message: <471fabfa@news.povray.org>
"Orchid XP v7" <voi### [at] devnull> wrote in message
news:471fa7b9$1@news.povray.org...
Usually with the help of someone who knows the codebase and quite a bit of
time. I've done it a couple times. Doesn't really get easier.
