POV-Ray : Newsgroups : povray.off-topic : Mac Plus vs AMD Dual Core Server Time
7 Jul 2026 23:54:12 EDT (-0400)
  Mac Plus vs AMD Dual Core (Message 41 to 50 of 170)
Subject: Re: Mac Plus vs AMD Dual Core
Date: 15 Oct 2007 03:31:38
Message: <4713175a@news.povray.org>
> Not really, no.
> Just chromatagrams. I gather that they're quite large... (Well, the data
> is almost always very noisy.)
Exactly, almost every company has their requirements for something more than
just plain text.  Whether it's specialist scientific diagrams, photos, fancy
graphics or whatever.  Not many companies just produce reports and things in
plain-text.
> My point is not so much that we should go back to using 32K machines, but
> rather that we should go back to the days of programs only using more than
> 32K if they *need* it for something. ;-)
If I load up a blank Word or Excel document, it uses 0.5% of my physical
RAM... I can cope with that as being essentially "zero"...
What I'm struggling to cope with at the moment is my CFD simulation that
keeps running out of RAM :-)
Date: 16 Oct 2007 13:33:42
Message: <4714f5f6@news.povray.org>
> than just plain text.  Whether it's specialist scientific diagrams,
> photos, fancy graphics or whatever.  Not many companies just produce
> reports and things in plain-text.
My point here is not "word processors shouldn't allow you to include
graphics". My point is "running a word processor should not require
several hundred MB of RAM" [unless you're actually loading something large].
>> but rather that we should go back to the days of programs only using
>> more than 32K if they *need* it for something. ;-)
What I'm struggling with is that opening Firefox takes about 25 seconds
because first the OS has to page enough stuff out to disk to make space
to load the program image into physical RAM.
Seriously. It sounds like nothing, but do you have any idea how
*annoying* it is when it takes 10 seconds to switch between windows? My
lowly Amiga with 2 MB of RAM could do all that *instantaneously* 20
years ago... WTF?
Date: 16 Oct 2007 15:23:44
Message: <47150fc0$1@news.povray.org>
> large].
FWIW, I agree; further, though, if you are loading something large, a
word processor is often times the wrong application to be using for it.
For example, developing course materials for training, the group I
started in nearly 5 years ago all used MS Word with master documents.
Horrible, horrible idea - when Word didn't crash, it was painfully slow,
even with 2 GB of memory in the machines (Running 2KPro or XP).
Using the right tool for the job is very important.
Jim
Date: 16 Oct 2007 15:25:45
Message: <47151038@news.povray.org>
  Strange OS you have. I have never experienced that in normal usage.
The only situation I have experienced that is when a buggy software
(sometimes my own, during its development) goes wild and starts eating
memory like mad (because of a bug), causing the OS to swap everything.
Date: 16 Oct 2007 16:22:35
Message: <47151d8b@news.povray.org>
M$ Windows NT, 128 MB RAM.
Add more RAM and Firefox works just great. (The PC I'm sitting at now
has 3 GB and Firefox starts almost instantly.)
Date: 17 Oct 2007 03:08:34
Message: <4715b4f2$1@news.povray.org>
> large].
They don't!  If I open a blank Word document, that's 10 MB.  Even if I open
one of our spec documents that is 79 pages long with diagrams on most pages
and company logos etc, Word uses up 33 MB.  It's not exactly causing even a
slight impact on the 2048 MB I have.  Of course if I tried to import lots of
multi-mega-pixel photos on every page it might start to use more RAM, but
that is expected.
> Seriously. It sounds like nothing, but do you have any idea how *annoying*
> it is when it takes 10 seconds to switch between windows? My lowly Amiga
> with 2 MB of RAM could do all that *instantaneously* 20 years ago... WTF?
But what happened on your Amiga when you tried to use 2.5 MB of RAM when you
only had 2 installed?  Seriously, if you are going to regularly try to use
more RAM than you have installed then you must expect page-file swapping -
and it's not fast.  You can set the page-file size to zero in Windows, then
it will behave more like your Amiga used to.
Date: 17 Oct 2007 16:27:48
Message: <47167044$1@news.povray.org>
>> large].
...which begs the question, "what are you using 10 MB for?"
There used to be word processors that would run inside less than 60 KB
of RAM. Sure, nobody could argue they had the same features. And sure, I
can see how adding lots more features would require quite a bit more
RAM. But 10,000 KB? That's not "quite a bit more". That's 170 *times*
more! What's it *doing* with it??
>> My lowly Amiga with 2 MB of RAM could do all that *instantaneously* 20
>> years ago... WTF?
> you only had 2 installed?  Seriously, if you are going to regularly try
> to use more RAM than you have installed then you must expect page-file
> swapping - and it's not fast.  You can set the page-file size to zero in
> Windows, then it will behave more like your Amiga used to.
...the point being that software for the Amiga was designed to not
*require* more than 2 MB in the first place. (Because if it did, you
just massively reduced your potential market.) Back then, software only
used memory if it was absolutely, unavoidably necessary. Which is kind
of my point...
(To actually answer your question, if you ask AmigaOS for 2.5 MB of RAM
when only 2 MB of physical RAM exists, you get a message that amounts to
"no, go away". One of the ways they kept the Amiga cheap was by not
including the hardware necessary for implementing virtual memory...)
Date: 17 Oct 2007 17:07:04
Message: <47167978@news.povray.org>
  Using the available memory in modern computers for eyecandy and useful
stuff as well (such as spellchecking, etc). Also WYSIWYG tends to consume
some memory.
  In some cases "eyecandy" is actually not useless, as it can make things
clearer and easier and more intuitive to use.
Date: 17 Oct 2007 17:10:12
Message: <47167a34@news.povray.org>
> some memory.
Hmm. Word's default dictionary might be 9 MB or so. (And it must load
that if it does the "spell as you type" thing.) That leaves the rest as
a larger executable (to implement more functionality) and a little more
space... for... who knows?
I won't argue with that. One could describe any GUI as "candy" (since,
after all, it's perfectly *possible* to operate a computer that doesn't
even have a graphics cability - and this requires vastly less memory),
yet it clearly makes [almost] everything much easier.
Date: 17 Oct 2007 21:08:21
Message: <4716b205@news.povray.org>
Orchid XP v7 wrote:
> ....which begs the question, "what are you using 10 MB for?"
It doesn't beg the question. It raises the question. </peeve>
All the COM stuff, perhaps?  Exporting the functionality of Word so you
don't have to write your own mail merge and spell checker for every program?
The CPU didn't even support it, just like pre-386 days.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
