POV-Ray : Newsgroups : povray.off-topic : Mac Plus vs AMD Dual Core Server Time
7 Jul 2026 22:20:26 EDT (-0400)
  Mac Plus vs AMD Dual Core (Message 31 to 40 of 170)
Subject: Re: Mac Plus vs AMD Dual Core
Date: 11 Oct 2007 03:37:57
Message: <470dd2d5@news.povray.org>
>>   Ok, fine: Try running a web browser in both systems.
> Also done that.
> Running IBrowse on my 20 MHz Amiga is... not amusing. If you thought IE
> was slow on a 133 MHz laptop, think again! :-S
Don't forget that displaying a webpage usually involves a huge number of
inverse fourier transformations :-)
Date: 11 Oct 2007 16:39:42
Message: <470e8a0e$1@news.povray.org>
>> Also done that.
>> IE was slow on a 133 MHz laptop, think again! :-S
...wuh?
Date: 11 Oct 2007 16:41:18
Message: <470e8a6e$1@news.povray.org>
Darren New wrote:
>>> There's a lot more to office computing, and always has been, than
>>> just word processing and spreadsheets.
>> Not in my office.
> Don't you complain that NT4 doesn't support USB?
Yes, that's me.
> And don't you run lab
> equipment and everything as a normal part of your office environment?
No. Our normal *lab* environment. ;-) The *office* just runs Word and
Access. (And the guys in the lab insist on using Excel a lot...)
Date: 11 Oct 2007 17:15:49
Message: <470e9285@news.povray.org>
> ...wuh?
  I can't believe you don't know what he is referring to.
Date: 12 Oct 2007 10:21:22
Message: <470f82e2$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote
> >> And if a compiler already generates optimum code, you obviously can't
> >> improve on it.
> > Since *humans* write compilers, your argument is self defeating.
> Only if you assume all humans are equal, and/or your compiler is your
> biggest and most complicated piece of code.
Doesn't matter. Absolute faith in compilers isn't warrented in any case.
> > be achived with careful low level coding. "Hello World" windows
application
> > in Delphi, for instance, takes several hundered kilobytes. Don't tell me
> > that an assembler version can not be more optimized.
> Sure. But the fact that small programs are bloated doesn't mean large
> programs can effectively be cut down.
If you write effectively to mean economically, I agree. Of course one can
not, in that sense, effectively go against the grain. The industry has
chosen a particular path, and all of us pretty much follow it.
> The comments on the web page are pretty amusing too. Nobody seems to
> notice much that large programs don't take up more memory than small
> programs. Features you never use never get loaded and don't occupy memory.
That begs the question of why those features are there to begin with. More
importantly, OS's memory management brings yet another level of layering
into the picture. Ideally, only the application programmer is in a position
to make informed calls about such matters. Compilers, OS, virtual
machines... etc are making decisions without having an "understanding" of
the intent, and are a source of inefficiency. Yet, that's a price we pay for
modern, bloated, multitasking OSs. Add to this AV software that can take up
to half of your raw processing power. I'm not saying we should go back, but
pointing out that much of the performance gained through hardware is
"wasted" through these channels.
Date: 12 Oct 2007 11:04:26
Message: <470f8cfa@news.povray.org>
And I expect the guys in the office often want to include fancy graphics
into their Word documents, perhaps just company logos on a letter, or
photos/diagrams in a report.  All of which rapidly use up memory and which
would slow down hugely on a very slow machine.
Sure, they could use a plain text editor on an ancient machine with 32K of
RAM, but it's not going to look very professional.
Date: 12 Oct 2007 11:20:17
Message: <470f90b1@news.povray.org>
news:470e9285@news.povray.org...
>> > of
>> ...wuh?
JPEGs, I presume.
Date: 12 Oct 2007 13:09:27
Message: <470faa47$1@news.povray.org>
Brian Elliott wrote:
> JPEGs, I presume.
Oh, yeah. I forgot that normal web pages have images on them...
Date: 12 Oct 2007 13:11:36
Message: <470faac8$1@news.povray.org>
Not really, no.
Just chromatagrams. I gather that they're quite large... (Well, the data
is almost always very noisy.)
> which would slow down hugely on a very slow machine.
> of RAM, but it's not going to look very professional.
My point is not so much that we should go back to using 32K machines,
but rather that we should go back to the days of programs only using
more than 32K if they *need* it for something. ;-)
Date: 13 Oct 2007 00:04:51
Message: <471043e3$1@news.povray.org>
Nah. Nothing absolute about it.
Firstly, it doesn't.  "Begs the question" doesn't mean what you think it
does. ;-)
Secondly, while it's true that 90% of the time you use only 10% of the
features, it's a different 10% for everyone. Which leads to some rather
dumb arguments on this list too about compatibility and such.
> into the picture.
Well, yeah, that's kind of what I was talking about.
I'll disagree. I think many programs are in the middle - too high-level
to be hand-coded efficiently, but too low-level to let software improve
on what the programmer asked for.
Consider, for example, an SQL interpreter that can look at the balance
of values in the tables being joined and decide, on a day by day basis,
the order in which to join them. Sure, obviously, someone coded this
behavior, but it wasn't the application programmer.
Partly, yes, but you can also, for example, save memory and disk I/O by
using shared libraries that the application programmer can't possibly
predict at compile time whether they'll already be cached in memory or
sharable with another application, for example.
Not nearly as much care is taken with modern OSes, I'll grant. It used
to be the OS would lay out on disk your files, accomidating rotational
latency and even how long it took to process the interrupt for the next
sector to be loaded. Nowadays, you can't even figure out how many actual
cylinders the disk has.
> Add to this AV software that can take up to half of your raw processing power.
Well, yes.
And using languages like C means you need address translation and memory
protection on your hardware in order to support multi-user machines,
which is also a drain on speed.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
