POV-Ray : Newsgroups : povray.off-topic : Mac Plus vs AMD Dual Core Server Time
7 Jul 2026 19:06:29 EDT (-0400)
  Mac Plus vs AMD Dual Core (Message 141 to 150 of 170)
Subject: Re: Mac Plus vs AMD Dual Core
Date: 2 Nov 2007 15:02:50
Message: <472b826a@news.povray.org>
scott <sco### [at] laptopcom> wrote:
> Allowing users to modify settings and install anything usually leads to an
> unstable environment and many many IT support calls.
  That's because they use the wrong OS, where users can screw up the
system by installing and changing settings...
Date: 2 Nov 2007 18:53:12
Message: <472bb868@news.povray.org>
And what system lets you install applications and change settings that
*doesn't* let you screw things up?  Last time I ran rpm as a normal
user, it not only didn't work, it gave a really stupid error message.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 2 Nov 2007 21:00:10
Message: <472bd62a@news.povray.org>
  MacOS X?
  Most unix programs can be installed locally. If some can't, they are
stupid.
Date: 3 Nov 2007 16:56:37
Message: <472cee95$1@news.povray.org>
On Fri, 02 Nov 2007 10:56:44 +0100, scott wrote:
>> That was now about 10 years ago (doesn't seem possible it was that long
>> ago).  But desktop lockdown and software installation policies are very
>> common in corporate IT policies these days, especially with all the
>> crapware/malware/spyware that's in the Windows world.
> Yep, and the policy works too.  Where I used to work everyone was using
> Win95 (to start with, they slowly changed to XP when I was leaving) and
> I don't think we ever saw a blue-screen.  This was because we were only
> allowed to use approved software, and IT had tested to death anything
> that was to be used on the system to make sure it was compatible with
> everything. Add to that the fact that they routinely wiped the HDs, it
> meant a very stable computing environment virtually transparent to the
> user (unless you wanted to install some application that was not in the
> list).
Oh yes, for the company I worked for before coming to Novell, we used
Novell's ZENworks for application distribution and desktop policy
management.  There was a team of half a dozen engineers who would test
applications like mad to make sure the install wouldn't break something
else.  Compatibility testing was a huge component of that process - will
app A break app B?
> an unstable environment and many many IT support calls.
Yep.  BTDTGTTS.
Jim
Date: 3 Nov 2007 16:57:27
Message: <472ceec7$1@news.povray.org>
"You must be root"?
Jim
Date: 3 Nov 2007 16:58:19
Message: <472ceefb$1@news.povray.org>
>   MacOS X?
Bwah!  Yeah, riiiight.
It is impossible to make something foolproof because fools are so
ingenious...
Jim
Date: 4 Nov 2007 11:58:09
Message: <472dfa21@news.povray.org>
>> an
All modern desktop OSs can be configured to stop users changing settings
etc, can't they?  Even Win95 allowed this which seemed to work very
successfully in my previous company, where 10's thousands of people were
using it.
But yes, if your OS doesn't allow this, then you are certainly using the
wrong OS in your business.
Date: 4 Nov 2007 12:00:28
Message: <472dfaac@news.povray.org>
> Well, you must have some serious amounts of RAM to play with is all I can
> say... ;-)
I think the problem here is that you have a seriously *limited* amount of
RAM to play with compared to what most other people have :-p  And you try to
run programs that are not designed to run on 5-year-old hardware, then
complain when they use too much RAM...
Date: 4 Nov 2007 12:29:27
Message: <472e0177$1@news.povray.org>
>   MacOS X?
OK, fair enough.  Altho I'd be surprised if you could install
applications without screwing up your system. See the new Mac OsX trojan
floating around.
> stupid.
I don't know how to do this from an RPM.
Date: 4 Nov 2007 12:30:30
Message: <472e01b6$1@news.povray.org>
> "You must be root"?
No, actually. Something like "could not aquire package directory lock".
If it said "you must be root" I wouldn't have had to try several times
and wander around looking for where said lock might be in order to
install the software.
