POV-Ray : Newsgroups : povray.off-topic : Can someone research a stupid bug report for me? Server Time
4 Jul 2026 14:47:24 EDT (-0400)
  Can someone research a stupid bug report for me? (Message 21 to 26 of 26)
Subject: Re: Can someone research a stupid bug report for me?
Date: 21 Sep 2007 07:55:56
Message: <46f3b14c@news.povray.org>
andrel wrote:
> Greg M. Johnson wrote:
>> Warp wrote:
>>> 1812433253
>> Fascinating.  Makes me want to make up my own from now on.
>> Is something like newrand()=  mod (1000* sin( (0.5+0.5*newrand())*pi ) ,
>> 1)
>> less "predictable?  Can you think of something better?
> yes.
> weakpoints are that it takes longer to compute than a standard random
> number generator but more importantly, is does not have a flat
> distribution. It is not as bad as I expected (see attached greg1.png)
> but not good enough. I think it is because if your number is close to 1,
> the next will also be. And you can get there by accident, so that is
> probably why there is that peak close to 1. Removing the pi from your
> equation helps a lot. I don't feel like doing a more complete analysis
> now.
Wow, thanks!
And thanks for the pointer to the Mersenne
Date: 21 Sep 2007 11:24:28
Message: <46f3e22b@news.povray.org>
Orchid XP v3 <voi### [at] devnull> wrote:
> OOC, are the coeficients for POV-Ray's generator from a book or where
> they just chosen arbitrarily?
  Unlikely to be arbitrary because, IIRC, the period is 2^32. (In other
words, it goes through the entire range of 32-bit values before repeating.)
Date: 22 Sep 2007 03:06:46
Message: <46f4bf06$1@news.povray.org>
Right. There's some kind of algorithm for picking LCG coefficients such
that they have this property. (I have no idea what the algorithm is.)
So even though you get uniformly distrubuted numbers in 0 .. 1, POV-Ray
is actually generating integers and converting them? Presumably that
means no two random numbers can differ by less than 2^-32?
http://blog.orphi.me.uk/
Date: 22 Sep 2007 05:23:18
Message: <46f4df06@news.povray.org>
  That's correct.
  There are also other side-effects. For example, you can have two
random seeds, each one creating random numbers independently of each
other, and suddenly one of them may start giving the exact same values
the other one gave when it started.
  This is because every seed is just going through the exact same
sequence of numbers, simply starting at different places. Advance
one seed enough and it will eventually reach the starting point of
the other seed.
Date: 22 Sep 2007 06:11:11
Message: <46f4ea3f$1@news.povray.org>
>> POV-Ray is actually generating integers and converting them?
>> Presumably that means no two random numbers can differ by less than
>> 2^-32?
>  That's correct.
> the other seed.
And I presume it's a bad idea to choose different LCG coefficients for each
seed?
Rune
http://runevision.com
Date: 22 Sep 2007 07:29:40
Message: <46f4fca4@news.povray.org>
> seed?
  Not really, if each one has the same quality. POV-Ray just doesn't do
that.
