POV-Ray : Newsgroups : povray.off-topic : Power Server Time
11 Jul 2026 10:52:58 EDT (-0400)
  Power (Message 71 to 80 of 133)
Subject: Re: Power
Date: 4 Sep 2007 21:51:57
Message: <46de0bbd@news.povray.org>
Dre wrote:
> No it doesn't!
> What kind of engine do you run in your car???  a nitro engine???
> Any car engine is capable of idling far below 1000rpm.  Most idle aroun
> 600-800rpm depending on auto or manual gearbox...
I've seen several engines that idle at more than 1000rpm.  I even saw
one go as high as 1 800 (though I'm pretty sure there was something
wrong with it).
...Ben Chambers
www.pacificwebguy.com
Subject: Re: Power
Date: 4 Sep 2007 22:22:04
Message: <46de12cc$1@news.povray.org>
Orchid XP v3 wrote:
> AFAIK, the retina sees the "integral" of incident light over time,
Errr, not even close. Indeed, if something is completely still, you
can't see it at all. That's why your eyes are always moving (saccades).
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Subject: Re: Power
Date: 4 Sep 2007 22:54:26
Message: <46de1a62$1@news.povray.org>
Chambers wrote:
> Dre wrote:
>> No it doesn't!
>> aroun 600-800rpm depending on auto or manual gearbox...
> wrong with it).
My 4 stroke, 49.9 cc moped engine idles at 1800 to 2200. That is, if the
manual is to be trusted, since in all three places it lists an ideal
idle speed it has a different number. But, there is a difference between
cars, and chainsaw motors with wheels.
Subject: Re: Power
Date: 4 Sep 2007 23:53:25
Message: <46de2835@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> wrote in message
news:46de0bbd@news.povray.org...
> Dre wrote:
>> No it doesn't!
> I've seen several engines that idle at more than 1000rpm.  I even saw one
> go as high as 1 800 (though I'm pretty sure there was something wrong with
> it).
> ...Ben Chambers
Well car engines tend to idle higher when they are cold as the ecu tells
them to (engines dont like being cold).  An engine at operating temp
shouldn't need to idle above 1000rpm, thats just a waste of fuel.
1800rpm is way too high for idle and as you say, there was something wrong
with it.
I was just pointing out to Orchid that his engine *doesn't* idle at
*several* thousand rpm, thats a gross exaggeration.
Cheers Dre
Subject: Re: Power
Date: 4 Sep 2007 23:54:50
Message: <46de288a@news.povray.org>
"Sabrina Kilian" <"ykgp at vtSPAM.edu"> wrote in message
news:46de1a62$1@news.povray.org...
> Chambers wrote:
>> Dre wrote:
>>> No it doesn't!
>> wrong with it).
Exactly, my model nitro engines need idle (2.5cc) idle around 2000-3000rpm
otherwise they stall, but they are a little different to a car engine, size
and rotating mass tend to have a lot to do with that :)
Cheers Dre
Subject: Re: Power
Date: 5 Sep 2007 01:25:49
Message: <46de3ddd$1@news.povray.org>
*That's* how an SEP field works.  I always wondered. ;-)
Jim
Subject: Re: Power
Date: 5 Sep 2007 01:57:17
Message: <46de453d@news.povray.org>
> I don't know anyone who gets that kind of standby time.  My phone (which
> is fairly new) only gets about a day, maybe two of standby time.
Oh wow, that would annoy the hell out of me if I had to charge my phone
every 24-48 hours...  Mine usually lasts about 5 days with a few texts and
short calls per day.  I do make sure that bluetooth is turned off when I'm
not actively using it though, maybe that makes a difference?
I know my mum had to charge her old phone every 24 hours or it would die,
but she got a new battery for it and it went back to lasting for ages again
.. but yours is new.. hmmm, what make/model is it?
Subject: Re: Power
Date: 5 Sep 2007 02:03:50
Message: <46de46c6@news.povray.org>
>> Hard to see how you could deliberately make the system less efficient
>> without just plonking a huge 50W resistor in series (which would totally
>> screw up the quality of the sound).
> And why would that be?
Because if you put a resistance in there large enough to causes a
significant change in efficiency it would create a low pass filter with the
capacitance of the cable.  Also the resistor would heat up, so if you
listened to loud music, after a while it would start to get quieter, and
your speakers would start to get warmer...  Doesn't seem like a good idea if
you are striving for optimum sound quality...
Subject: Re: Power
Date: 5 Sep 2007 03:20:03
Message: <46de58a3@news.povray.org>
>> What sound does your motor make? Can you find the base frequency on your
>> keyboard?
> Surely that's just the resonant modes of the exhaust system and the
> chasis?
Ermm, rev your engine, notice how the pitch of the sound corresponds to the
rpms?  Some part of the sound will be due to resonances in the system, but
there will be a obvious frequency component (and harmonics) that are equal
to the rpm (that obviously change with engine speed).
Actually Formula 1 teams use this exact method to check what RPM their
competitors' cars are achieving.  From the RPM trace they can estimate the
power output of the engine (given they know the speed of the car, and that
all F1 cars weigh the same).
Subject: Re: Power
Date: 5 Sep 2007 05:54:00
Message: <46de7cb8@news.povray.org>
46de288a@news.povray.org...
>but they are a little different to a car engine, size and rotating mass
And number of cylinders as well
Marc
