POV-Ray : Newsgroups : povray.object-collection : Problems with bubble.inc Server Time
31 Mar 2026 02:26:28 EDT (-0400)
  Problems with bubble.inc (Message 1 to 4 of 4)
Subject: Problems with bubble.inc
Date: 2 Mar 2014 07:55:01
Message: <web.5313297c1f0c1bb0eaaefd950@news.povray.org>
I need some nice bubbles for a nearly finished illustration, so I've checked out
the "Carbonated fluid bubble generator" from the objects collection.
I just dumped a camera and two area lights and a background into the scene (see
below) and added the lines with the example from the .inc file.
However, I can't find a single bubble in the rendered image (tried to fiddle
around with the camera position and lights abit, but still I don't see
anything).
Any suggestions, what could be the problem?
Thanks a lot,
Simone
// perspective (default) camera
  location  <0.0, 2.0, -8.0>
  look_at   <0.0, 0.0,  0.0>
// An area light (creates soft shadows)
// WARNING: This special light can significantly slow down rendering times!
light_source {
  0*x                 // light's position (translated below)
  color rgb 1.0       // light's color
  area_light
  <8, 0, 0> <0, 0, 8> // lights spread out across this distance (x * z)
  4, 4                // total number of lights in grid (4x*4z = 16 lights)
  adaptive 0          // 0,1,2,3...
  jitter              // adds random softening of light
  circular            // make the shape of the light circular
  orient              // orient light
  translate <40, 80, -40>   // <x y z> position of light
light_source {
  area_light
  translate <40, 80, 40>   // <x y z> position of light
 // set a color of the background (sky)
background { color rgb <0.4, 0.4, 0.4> }
#include "bubble.inc"
// Example from bubble.inc file
#declare bblTexture = texture {finish {ambient 0.3 diffuse 0.1 reflection 0.25
specular 1 roughness 0.001} pigment {color rgbf <1,1,1,0.7>}}
#declare bubbleGenerator =
mBubbleGenerator(0,0.9,0,0,6.5,0,2.4,2.7,0.0005,0.0006,70,bblTexture)
Subject: Re: Problems with bubble.inc
Date: 2 Mar 2014 08:04:35
Message: <53132c63$1@news.povray.org>
> camera {
> light_source {
>    area_light
> light_source {
>    area_light
Hello,
The last line of your code declare only the object, you must call the
object, add the following to your code:
object {bubbleGenerator}
Lionel.
Do not judge my words, judge my actions.
http://www.avast.com
Date: 2 Mar 2014 08:15:01
Message: <web.53132dfa8dbb84aeeaaefd950@news.povray.org>
> Hello,
> Lionel.
 active.
Ah, I see. Now it works! Thank you very much, Lionel!
Simone
Date: 3 Mar 2014 07:55:01
Message: <web.53147b0b8dbb84aec2d977c20@news.povray.org>
The #declare is not really necessary (even though the author of the bubbles code
suggests it.) You can instead just place this in your scene:
.... with no object{...} wrapper. This is because, inside the bubble #macro, the
bubbles are in a union{...}. So the macro itself is like an already- #declared
'object', waiting to be used. (However, if you want to translate or scale the
bubbles in your scene, then an object wrapper would be necessary.)
I had not worked with this macro before; it's very interesting and produces a
nice result. But the two values fBblHeightRngS and fBblHeightRngE seem to be
somewhat non-intuitive.
