POV-Ray : Newsgroups : povray.object-collection : Descriptions Server Time
30 Apr 2024 20:22:35 EDT (-0400)
  Descriptions (Message 1 to 4 of 4)
Subject: Descriptions
Date: 23 Jun 2008 14:50:04
Message: <web.485ff022d15f754e1729cc4e0@news.povray.org>
700 characters is a bit small for a description. Is there any way you can bump
this up to around 2000 or so? Also, you need to separate the "Standards
Compliance Ratings" section from the description with some white space. I would
also suggest using a bold heading for the section titles.
-Mike
Subject: Re: Descriptions
Date: 23 Jun 2008 15:16:48
Message: <485ff6a0$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.485ff022d15f754e1729cc4e0@news.povray.org...
> bump
> would
> -Mike
The description is intended to be quite small. You can add more detail by
uploading an HTML file with the same name as the contribution, at which
point a 'More Detail' link will automatically appear next to the name of the
object in the search results. I'd be happy to upload such a file for any
existing entries.
For example, the 'Netball' entry includes a very simple HTML file called
'netball.html' that lists all of the settings that can be used with the
macro. The 'netball.html' file is at
http://lib.povray.org/collection/netball/chrisb%201.0/netball.html. Feel
free to take a copy and hack it around in a text editor to suit your needs
if you want. Note that all file names get translated to lowercase when you
upload them and the server is case sensitive, so, if you incorporate images
you'll need to consistently use lowercase in the IMG tag.
Chris B.
Date: 23 Jun 2008 16:05:02
Message: <web.4860013bb2ee3bc11729cc4e0@news.povray.org>
> existing entries.
Well, pumping things up to about a 1000 or so wouldn't hurt things too much, I
think. Unformatted text transfers pretty quickly, and it's kind of hard to list
the different types of objects if your object is a collection of several.
-Mike
Date: 23 Jun 2008 16:13:01
Message: <486003cd@news.povray.org>
> would
Hmm. In both IE and Firefox on Windows XP I get a thin yellow line, and a
thin white line below the input field before the blue box containing the
Description title starts and there's a thin blue margin above the text. The
section headings are defined as bold in the CSS and display in bold in both
browsers.
If you're getting any different it may be worth posting a small image of
that little section of the screen in povray.binaries.images and indicating
what are you running.
Chris B.
