POV-Ray : Newsgroups : povray.newusers : bicubic patch editor Server Time
14 Sep 2025 17:02:59 EDT (-0400)
  bicubic patch editor (Message 21 to 30 of 38)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: bicubic patch editor
Date: 1 Apr 2025 14:15:00
Message: <web.67ec2c1041fe044a911b6e125979125@news.povray.org>
"gulino" <nomail@nomail> wrote:
> but I have a error in
> Grass (x, y,z)*GrassHeight}
> "Expected '.', * found instead"
Yeah - inbuilt pigment functions return a full rgbft vector, so you have to
specify which vector component you want to use in the crippled user-defined
scalar function you're writing.
So, just do:
Grass (x, y,z).red*GrassHeight
- BW
Date: 1 Apr 2025 14:45:00
Message: <web.67ec336341fe044264ac0beab67afd2@news.povray.org>
> So, just do:
> - BW
#declare PlainAndGrass = function {Plain (x, y, z, 2.3, 7.0, 5.0, -2, 1, 3.0) +
Grass (x, y,z).red*GrassHeight}
"Invalid number of parameters 9 supplied, 3 required"
Date: 1 Apr 2025 15:00:00
Message: <web.67ec36cc41fe044a911b6e125979125@news.povray.org>
{sigh}
Since you're supplying the other 6 parameters as numeric values in your function
declaration, you don't need to supply them as actual parameters when you call
the function.
try:
#declare PlainAndGrass = function {Plain (x, y, z) +
If you want to keep it like it is in the final function, rewrite Plain using
(x, y, z, P0, P1, P2, P3, P4, P5) in both parentheses and curly braces.
But just try x,y, z for now.
- BW
Date: 1 Apr 2025 15:25:00
Message: <web.67ec3c8c41fe044264ac0beab67afd2@news.povray.org>
> {sigh}
> the function.
> try:
> - BW
#declare Plain = function {f_ridged_mf(x,y,z, 2.3, 7.0, 5.0, -2, 1, 3.0) }
#declare Grass = function {pigment {bumps}
#declare GrassHeight = 10;
"Invalid number of parameters, 3 suplied, 8 required"
what
Date: 1 Apr 2025 15:50:00
Message: <web.67ec42ff41fe0445e04e68c25979125@news.povray.org>
Then like I said, try:
#declare Plain = function {f_ridged_mf(x,y,z, P0, P1, P2, P3, P4, P5) }
#declare Grass = function {pigment {bumps}} // <--- you need a closing curly
brace
Then declare Pattern = pigment {function {PlainAndGrass (x, y, z, P0, P1, P2,
P3, P4, P5)}}
(Thanks for your patience. ;) This is easier when I'm home and can provide
functional, tested code that I can run through the parser.)
- BW
Date: 2 Apr 2025 06:45:00
Message: <web.67ed14ac41fe0441f9dae3025979125@news.povray.org>
I got derailed last night, but did not forget.
Tested, working code:
#version 3.8;
global_settings {
 assumed_gamma 1.0
#include "functions.inc"
#declare E = 0.00001;
#declare Location = <0, 500, -1000>;
 location Location
 up y
 look_at <0, 0, 0>
sky_sphere {pigment {rgb 1}}
light_source {<3000, 2000, -2000> rgb 1}
#declare Line = 0.01;
#declare E = 0.0000001;
#declare Plain = function (x, y, z, P0, P1, P2, P3, P4, P5) {f_ridged_mf (x,y,z,
#declare PlainAndGrass = function (x, y, z, P0, P1, P2, P3, P4, P5) {Plain (x,
y, z, P0, P1, P2, P3, P4, P5) +
height_field {
   function 1000, 2000 {PlainAndGrass (x,y,z, 2.3, 7.0, 5.0, -2, 1, 3.0) }
   smooth
       color rgb <0.3, 0.5, 0.0>
    translate <-0.5, 0, -0.5>
    scale <1000, 100, 1300>
Download 'landscape.png' (258 KB)
Preview of image 'landscape.png'
Date: 2 Apr 2025 09:40:00
Message: <web.67ed3dd841fe044264ac0beab67afd2@news.povray.org>
Thanks for the help but what exactly is this? I was aiming to make a grass
texture like this
Download 'plainpov.png' (238 KB)
Preview of image 'plainpov.png'
Date: 2 Apr 2025 09:50:00
Message: <web.67ed403941fe044721a48e56cde94f1@news.povray.org>
hi,
> texture like this
individual grass blades (meshes) "planted" is one option, if you search for
"grass macro" or variations on this site, there'll be plenty of "hits", some
going back _years_ :-).  see for instance this thread:
<https://news.povray.org/povray.binaries.images/thread/%3C46972e23%40news.povray.org%3E/>.
 hth.
regards, jr.
Date: 2 Apr 2025 10:05:00
Message: <web.67ed434141fe04425b4de9225979125@news.povray.org>
> texture like this
I'm just getting the functions to work without any errors.
Scale the functions so that they make something along the lines of what you
want.
Do that by multiplying or dividing the x, y, and z in the function call.
You may find Mike Williams' isosurface tutorial helpful with regard to working
with functions in POV-Ray.
https://wiki.povray.org/content/User:BillW
Also, as jr said, if you can't get the function or the normal method to work,
then you can use a set of macros to model actual blades of grass to better give
you what you're looking for.
Also, like jr said, you have 30 years of people writing and posting scenes here.
Search for "grass", "landscape", "heightfield", etc and see what pops up.
Use the website search feature, but also use a search engine to see what people
have done and have posted elsewhere.
- BW
Date: 2 Apr 2025 11:25:00
Message: <web.67ed55bb41fe044264ac0beab67afd2@news.povray.org>
What you think? Looks grass?
Download 'plainpov (2).png' (108 KB)
Preview of image 'plainpov (2).png'
