POV-Ray : Newsgroups : povray.newusers : Transparent Round_Box has many artifacts Server Time
3 Aug 2025 12:11:43 EDT (-0400)
  Transparent Round_Box has many artifacts (Message 1 to 10 of 14)
Subject: Transparent Round_Box has many artifacts
Date: 23 Feb 2024 04:40:00
Message: <web.65d86792b02b090b9901d2cada2676d5@news.povray.org>
I tried to create a transparent cylinder with spherical ends. I used Round_Box,
but I get many strange artifacts. I am not sure why. Can anybody explain why or
how I can produce this object in another way?
This is what I have done:
#version 3.7;
#include "shapes.inc"
global_settings {
 assumed_gamma 0.4
background { colour srgbt <0.0, 0.0, 0.0, 1.0> }
  location <0, 5, 0>
  look_at  <0, -1, 0>
#declare pA = <-1.5,  0, -0.5>;  // A corner
#declare pB = <+1.5, -1, +0.5>;  // The opposite corner
#declare EdgeAndcornerRadius = 0.5;
#declare UseMerge = false;
object {
  Round_Box(pA, pB, EdgeAndcornerRadius, UseMerge)
    pigment { color srgbt <0.0, 0.0, 0.0, 0.5> }
  finish {
    ambient .1
    diffuse .3
    specular 1
    roughness .01
    metallic
    reflection {
      .75
      metallic
light_source { <-2, 4, 4> color White}
Download 'player.png' (15 KB)
Preview of image 'player.png'
Subject: Re: Transparent Round_Box has many artifacts
Date: 23 Feb 2024 06:35:00
Message: <web.65d8828711ba5a471f9dae3025979125@news.povray.org>
use:
#declare UseMerge = true;
or
The Round_Box macro is going to make 8 cylinders and 8 spheres.  You only need 1
cylinder and 2 spheres, so just do that using merge {}
- BE
Date: 23 Feb 2024 11:03:11
Message: <65d8c1bf$1@news.povray.org>
> #version 3.7;
> global_settings {
>   assumed_gamma 0.4
> camera {
>    location <0, 5, 0>
>    look_at  <0, -1, 0>
> object {
>    texture {
>    finish {
>      ambient .1
>      diffuse .3
>      specular 1
>      roughness .01
>      metallic
>      reflection {
>        .75
>        metallic
Instead of Round_Box, you should use the Round_Cylinder for what you
want to do here.
As Bald Eagle mentioned, you need to use
With UseMerge = false, the inner surfaces are still there. Perfect when
the object is opaque, bad for any transparent object. merge remove the
internal surfaces.
Unless you start with a colour from a colour picker or an external
source, you should use rgbt instead of srgbt.
Why use assumed_gamma 0.4 ?
To have consistent results, you should use assumed_gamma 1.
Round_Cylinder(EndA, EndB, Radius, EdgeRadius, UseMerge)
Date: 23 Feb 2024 16:41:59
Message: <65d91127$1@news.povray.org>
Round_Cylinder() doesn't solve the problem; I tried it with UseMerge =
true, and that caused the object to vanish entirely.  But using UseMerge
= true with Round_Box() got rid of the artifacts.
I have created a set of macros that avoids redundant spheres and cylinders:
  https://github.com/CousinRicky/POV-RoundEdge/releases
Macros RE_Box() and RE_Cylinder will both work for this object, using
UseMerge = true.
I don't normally give advice that asked (I prefer to let new users deal
with problems one at a time), but Alain is correct about assumed_gamma 1.
However, I disagree with a blanket statement about rgbt vs. srgbt.  For
your particular example, it makes no difference, but the truth is that
srgbt is more likely to give you the colors that you expect, regardless
of your assumed_gamma setting. This is a whole bed of weeds that you
need to understand before taking advice blindly.
Date: 23 Feb 2024 16:53:29
Message: <65d913d9$1@news.povray.org>
*wasn't asked.
Date: 23 Feb 2024 19:05:00
Message: <web.65d9318711ba5a471f9dae3025979125@news.povray.org>
YESSSS!!!!
Can we rehash gamma and srgb conversion again?   *PLEASE*?
That's totally one of my favorite topics!
Date: 24 Feb 2024 09:05:00
Message: <web.65d9f75911ba5a479b4924336e066e29@news.povray.org>
Personally, I would rather dance on a bed of hot coals instead; it would
probably be less painful, and far less confusing...
Date: 24 Feb 2024 14:40:00
Message: <web.65da453411ba5a4777ee2d97da2676d5@news.povray.org>
> UseMerge = true.
Thanks! RE_Cylinder works fine.
https://ceving.github.io/breakout/Player.png
There are some minor artifacts on both ends, but maybe they are normal, I don't
know.
I used the gamma value just as a brightness slider. The images were too dark
with 1.
Date: 24 Feb 2024 17:30:00
Message: <web.65da6cc111ba5a471f9dae3025979125@news.povray.org>
> with 1.
Well yeah, you had a black background.
use
sky_sphere {pigment {rgb 1}}
and see the dramatic difference.
Date: 25 Feb 2024 12:35:13
Message: <65db7a51$1@news.povray.org>
> know.
Do you really have to use a macro for such a simple object ?
Back to basics csg : a simple merge { sphere{} sphere{} cylinder{} } is
more than enough, but maybe I've missed something?
Kurtz le pirate
Compagnie de la Banquise
