POV-Ray : Newsgroups : povray.newusers : image map and batch render Server Time
14 Sep 2025 12:29:04 EDT (-0400)
  image map and batch render (Message 1 to 7 of 7)
Subject: image map and batch render
Date: 4 Mar 2022 09:35:00
Message: <web.622221a363092888b54f4c53223435db@news.povray.org>
Platfor: in 10
Version: 3.7
Hi  all!
I have 1500 stl files to convert to jpg images. I used stl2inc to create the
files and renamed the objects inside the .inc definitions to the same, to make
the povray script easier.
1) I am using a bmp image of a piece of wood (attached) to imagemap onto a block
for the base of the scene (.pov also attached). This results in a
blurry/stretched image - how can this be fixed?
2) How can I run the same .pov scene file on each .inc file? My idea is: use
python to create .pov files by changing the #define foo.inc line for each inc
file, creating a batch of .pov files that can then be run in Windows batch. Is
there a better way?
Thanks!
Download 'cutterscene2.rar.dat' (2946 KB)
Subject: Re: image map and batch render
Date: 4 Mar 2022 11:05:00
Message: <web.622237d9d7f80b35ed36e5cb6cde94f1@news.povray.org>
hi,
"Peter.bates" <Pet### [at] livecoza> wrote:
> Platfor: in 10
> Version: 3.7
> Hi  all!
(guessing) make sure aspect ratio + scaling .. are in harmony.
> there a better way?
you could use the command-line "constant" to supply (part of) a filename.
<https://wiki.povray.org/content/Reference:Scene_Parsing_Options>
(though you'll need to find the right combination of quotes + apostrophes around
the value(s).  sorry, not using MS Win)
regards, jr.
Date: 4 Mar 2022 14:00:00
Message: <web.622260bed7f80b351f9dae3025979125@news.povray.org>
> Platfor: in 10
> Version: 3.7
> Hi  all!
Your image is 977x1526.
POV-Ray will import this and map it to a 1-POV-unit square.
So what you need to do is scale that texture to resize back to the right aspect
ratio.   (Just like jr said)
> there a better way?
If you name all of your files in sequential numerical order, you can use the
animation feature, and use the frame number or the clock value to choose the
right file.  Just concatenate everything into a string and use that for the
filename.
- Bill
Date: 5 Mar 2022 04:27:34
Message: <62232d06$1@news.povray.org>
> filename.
As Bill say, animation feature is a key.
-> Name yours file sequential : File1.inc, File2.inc, ... File1500.inc
-> In your SDL code, build the file name string :
   #declare fileName = concat("File",str(frame_number,0,0),".inc");
-> Include the file :
   #include fileName
-> Of corse, turn on animation and set
   Initial_Frame=1 and Final_Frame=1500
<https://wiki.povray.org/content/Reference:Animation_Options#Internal_Animation_Loop>
Kurtz le pirate
Compagnie de la Banquise
Date: 5 Mar 2022 12:27:14
Message: <62239d72$1@news.povray.org>
>> filename.
>     #include fileName
In this case, it's usually better to use constant file name length. So...
#declare fileName = concat("File",str(frame_number,-4,0),".inc");
The -4 means at least four digits and left padded with zeros.
The zero mean no decimal part.
File0001.inc, File0002.inc, ... File1500.inc
Date: 28 Mar 2022 15:00:00
Message: <web.624204e6d7f80b35b78ae31df712fc00@news.povray.org>
> >> filename.
> >     #include fileName
 Here something if the files you want to include aren't ordered as above or even
named the same. Make a file containing all the filenames you want. Then read
that file up to the current frame in the animation. That will be the your
include file.
I have winXP and I use this dos bat file to copy all the files in a directory.
REM make the file 'AAA_List.txt'  of 'txt' files from the directory where it
this is located
dir *.txt /A:-D/B/O:N > AAA_List.txt
just save in the directory where the files are and run
then I use POV win editor to add a quotes before and after the file name & a
comma at the end of each line
Date: 29 Mar 2022 13:20:51
Message: <62433ff3$1@news.povray.org>
> include file.
> this is located
This .bat file will work from MS DOS 3 up to Windows 11 and probably
beyond. MS DOS did not support folders before version 3.
