POV-Ray : Newsgroups : povray.newusers : Odd transformation of cylinders Server Time
10 Oct 2025 00:51:02 EDT (-0400)
  Odd transformation of cylinders (Message 1 to 6 of 6)
Subject: Odd transformation of cylinders
Date: 11 Aug 2020 01:35:00
Message: <web.5f322ce4e7e86bcf88e55160@news.povray.org>
I'm not "new" to POV-Ray but returning to it after a number of years. But this
problem I've run into is definitely in newbie territory.
I'm building up a basic scene currently using only spheres and cylinders. The
spheres are acting as I'd expect, but the cylinders are having an odd
transformation applied to them that I have to undo. They're all being rotated
-45 degrees around the X axis, and translated down by whatever their radius is.
For example:
  location <0, 0, -10>
  look_at  <0, 0,  0>
cylinder {
  <0 0 -1.25>
  <0 0 1.25>
  1
This isn't the full scene; I've omitted lighting and textures for brevity. I'd
expect to be looking at this cylinder end-on, but it's actually rotated -45
degrees and moved down -1, so I'm looking at the top side. I have to bring it
back to where I expect with the following:
  rotate <+45 0 0>
  translate <0 0 +1>
My 0.5 radius cylinders need translating up +0.5 on the Z axis, and all
cylinders need a +45 degree correction on the X axis.
Neither the tutorial nor the reference section on the cylinder give me any clue
as to why this weird transformation is being applied to all my cylinders, and I
don't remember having this problem last time I built a scene about seven years
ago. Is there something obvious I'm missing?
Thanks!
Subject: Re: Odd transformation of cylinders
Date: 11 Aug 2020 02:38:25
Message: <5f323ce1@news.povray.org>
Op 11/08/2020 om 07:30 schreef Cyningstan:
> For example:
> camera {
>    look_at  <0, 0,  0>
> cylinder {
>    <0 0 -1.25>
>    <0 0 1.25>
>    1
Not sure if this is the cause, but I am missing the ",". To be
unambiguous, you should write:
cylinder {
   <0, 0, -1.25>,
   <0, 0, 1.25>,
   1
>    rotate <+45 0 0>
>    translate <0 0 +1>
Same here:
rotate <45, 0, 0>
translate <0, 0, 1>
> Thanks!
Date: 11 Aug 2020 04:20:01
Message: <web.5f32545b60013892f88e55160@news.povray.org>
Thanks, Thomas! You're absolutely right, it was the missing commas. I made the
mistake in one place and then copied and adapted it all over the place without
noticing.
Date: 11 Aug 2020 04:30:37
Message: <5f32572d@news.povray.org>
Op 11/08/2020 om 10:18 schreef Cyningstan:
> noticing.
Excellent! I have a dim memory of an explanation some time ago by Alain
Martel about /why/ omitting the commas is ambiguous. I cannot find it
presently.
Date: 11 Aug 2020 12:23:45
Message: <5f32c611$1@news.povray.org>
> For example:
> cylinder {
>    <0 0 -1.25>
>    <0 0 1.25>
>    1
This get interpreted as :
cylinder{<0, 0-1.25> <0,0,1.25> 1}
You can ignore the comas, but only in unambiguous cases. Whenever you
have a negative value, the coma is mandatory in front of it.
There was a time, prior to version 3.0, where the space was a hard
separator and when your way of defining the vector was interpreted as
<0,0,-1.25>. It's been over 30 years that it's no longer the case.
Date: 16 Aug 2020 13:35:00
Message: <web.5f396dbc600138921420b9440@news.povray.org>
We've all done something like this at one time or another.
Those commas hide sometimes!
Have fun!
