POV-Ray : Newsgroups : povray.newusers : angle of incidence of rays of light Server Time
10 Oct 2025 00:49:29 EDT (-0400)
  angle of incidence of rays of light (Message 1 to 7 of 7)
Subject: angle of incidence of rays of light
Date: 23 Sep 2018 09:25:01
Message: <web.5ba79315ca7dd69ce66e1eb00@news.povray.org>
I have a material that creates a shadow of varying density, depending on the
angle to the direction of the light rays.
Is it possible to specify a variable transmission of light through the surface,
depending on the angle of light rays incidence?
Subject: Re: angle of incidence of rays of light
Date: 23 Sep 2018 10:18:59
Message: <5ba7a0d3$1@news.povray.org>
sure povray does that ... check out ior to characterize the interior of
your material. have a look in the docs Reference->Scene File
Extras->Include Files you'll see ior mentioned in a couple of places.
look in glass.inc and you'll see how to put together a material
definition. transmit and filter in pigment is worth looking at...povray
has subsurface light transport too
Date: 23 Sep 2018 10:24:46
Message: <5ba7a22e$1@news.povray.org>
>> on the
>> surface,
oh objects can also have interior media too...start at
Reference->Special Effects->Media
Date: 23 Sep 2018 11:44:49
Message: <5ba7b4f1$1@news.povray.org>
Am 23.09.2018 um 15:20 schrieb ttyUSB0:
That's actually normal behaviour for pretty much all transparent
real-life materials; usually, the difference in shadow is due to
specular reflection at the surfaces that "steals" part of the light; in
real life, specular reflection is stronger at shallow angles, as
expressed by Fresnel's law.
As Jim already hinted at, POV-Ray can take into account Fresnel's law
for /some/ effects, if you specify an index of refraction.
However, it doesn't normally do so for shadows; to make POV-Ray do so,
you have to:
- Specify the object's refractive index (via `ior` in an `interior` block).
- Set up the material to respect fresnel's law for reflection (using
`reflection { fresnel on }` in a finish block).
- Set up the material to account for reflected light in computing
transmission (using `conserve_energy` in a finish block).
- Use photon mapping to coax POV-Ray into actually computing advanced
transmission effects for shadows.
An alternative is to use the `aoi` (angle of incidence) pattern for the
pigment, varying the `trans` component of the colour according to the angle.
Date: 28 Sep 2018 03:20:00
Message: <web.5badd56347fdf4edb540a4420@news.povray.org>
Thank you, clipka and Jim.
I want to model not a three-dimensional, but a flat object. Like polygon, or
mesh/mesh2.
Directive
pigment{aoi}
works well, surface color depends of angle of incidence, but shadow is always
the same.
I cant found, how to make my surface cast semi-transparent shadows.
Keywords 'transmit' and 'filter' works only with 'color'. How to make texture
transparent?
Date: 28 Sep 2018 04:00:01
Message: <web.5badde7747fdf4edb540a4420@news.povray.org>
"ttyUSB0" <nomail@nomail> wrote:
I have read the manual carefully.. :)
This code does something similar to what I need:
polygon {4, <-w/2, -h/2>, <w/2, -h/2>, <w/2, h/2>, <-w/2, h/2>
    pigment{
        aoi
        color_map {
            [0.71 color Blue transmit 0.1]
            [0.99 color Red transmit 0.9]
    rotate 15*x
    no_image
Shadow now depends on rotation angle.
Date: 29 Sep 2018 12:34:51
Message: <5bafa9ab$1@news.povray.org>
> mesh/mesh2.
> Directive
> pigment{aoi}
> the same.
> transparent?
You can add «transmit Value» or «filter Value» after the pigment.
You can also use rgbt, rgbf or rgbft to definne your pigment :
rgb<R, G, B>
rgbt<R, G, B, Transmit>
rgbf<R, G, B, Filter>
rgbft<R, G, B, Filter, Transmit>
When using filter and transmit, always make sure that (filter +
transmit) <= 1
The «color» or «colour» keyword is always optional unless you use this
obsolete construction :
colour red RedValue green GreenValue blue BlueValue
