POV-Ray : Newsgroups : povray.newusers : trouble using povray through php Server Time
31 May 2025 04:31:35 EDT (-0400)
  trouble using povray through php (Message 1 to 5 of 5)
Subject: trouble using povray through php
Date: 11 Jul 2018 08:55:01
Message: <web.5b45fd86c58a6d1e4c516b590@news.povray.org>
Hello, all.
Sorry if the subjet was allready treated I haven't seen one answer. I'm trying
to use povray to generate .png with editable parameters on a web page. I made a
formular sheet and generate .pov files. after this generation i execute a
command like :" /usr/bin/povray +I"example.pov" +FN +W1600 +H1200
+O"/home/emilien/most-3-d-customizer/files/example.png" +Q9 +AM2 +A0.5 "
povray starts  with all parameter that seems correct and finish by
==== [Parsing...] ==========================================================
Error opening terminal: unknown.
My configuration is : debian9 web server + php7 + povray3.7
Is there anyone can help me ?  Thanks in advance
Imkael
Subject: Re: trouble using povray through php
Date: 11 Jul 2018 09:05:02
Message: <5b46007e$1@news.povray.org>
Am 11.07.2018 um 14:52 schrieb imkael:
> Hello, all.
Adding the `-D` command-line parameter might help. Without this
parameter, POV-Ray will try to display a preview, which - depending on
the settings with which it was compiled - might require POV-Ray to run
in a terminal session.
Date: 11 Jul 2018 09:20:00
Message: <web.5b4602f819321f6f635cc5ad0@news.povray.org>
hi,
"imkael" <roc### [at] gmailcom> wrote:
> ... after this generation i execute a
have you tried a command like "sh /usr/bin/povray ..."?
the error message makes me think povray isn't run from a shell, and thus no
std{in,out,err}.
disclaimer: I don't use Debian.
regards, jr.
Date: 11 Jul 2018 09:20:01
Message: <web.5b46032719321f6f4c516b590@news.povray.org>
> > Hello, all.
thanks a lot it works just fine. I've been searching for one week!! thanks a lot
again clipka .
Date: 11 Jul 2018 09:45:00
Message: <web.5b46095a19321f6f4c516b590@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> std{in,out,err}.
> regards, jr.
thanks for your answer but i've tried a few days ago and it doesn't work. The
Clipka answer work well. Thanks anyway
Regards ,Imkael
