POV-Ray : Newsgroups : povray.newusers : Assigning sphere colours using rgb Server Time
29 Apr 2024 14:37:00 EDT (-0400)
  Assigning sphere colours using rgb (Message 1 to 5 of 5)
Subject: Assigning sphere colours using rgb
Date: 22 Aug 2017 18:10:01
Message: <web.599cab5be8844a66c326978c0@news.povray.org>
I am trying to plot spheres with positions and colours taken from a text file.
This message (
http://news.povray.org/povray.general/thread/%3Cweb.4f05a8fc1cabb177be8719c80@news.povray.org%3E/
) has helped with the initial plotting, but I cannot get the colours to render.
What am I doing wrong please?
Example code
global_settings {
 assumed_gamma 1.0
 ambient_light White
light_source { <50,50,-50> color White }
  sky <0, 0, -1>
  look_at <0, 0, 0>
  location <-25, 10,-25>
plane { <0,0,-1>, 0
  pigment { color White }
#fopen FileHandle1 "coords1.txt" read
#while (defined(FileHandle1))
     #read (FileHandle1, v1, v2, v3, v4, v5, v6)
     sphere { <v1, v2, v3>,    2
      texture { pigment{ rgb <v4, v5, v6> }
                finish { reflection 1  }}}
And the coords1.txt file
10,0,-10,0,178,238,
-10,10,-10,238,174,238,
-10,-10,-10,176,196,222,
(I got the rgb colours from using `col2rgb(c("deepskyblue2", "plum2",
"lightsteelblue"))` in the R software)
Subject: Re: Assigning sphere colours using rgb
Date: 22 Aug 2017 19:32:06
Message: <599cbef6@news.povray.org>
> This message (
> Example code
> global_settings {
>   assumed_gamma 1.0
>   ambient_light White
> camera {
>    sky <0, 0, -1>
>    look_at <0, 0, 0>
> plane { <0,0,-1>, 0
> #end
> 10,0,-10,0,178,238,
This one show as cyant
Those two show as pure white.
In a radiosity scene, they'll have a huge impact on any neibouring tints.
In POV-Ray, all colours are in the 0..1 range. Anything larger than that
gets shown as if they where set at 1.
If you see those on a slightly reflective surface, then, you'll be able
to see the actual colours. Try a plane with this texture:
texture{pigment{rgb 0} finish{reflection 1/200 diffuse 0 ambient 0}}
What you need is to divide your 0..255 range values by 255 as follow:
texture { pigment{ rgb <v4/255, v5/255, v6/255> }
OR, use this shorter form :
texture { pigment{ rgb <v4, v5, v6>/255 }
As those are probably gamma precomputed, using srgb is probably beter :
texture { pigment{ srgb <v4, v5, v6>/255 }
Date: 23 Aug 2017 10:00:00
Message: <web.599d89b160abce79c326978c0@news.povray.org>
Thanks Alain, also for the extra info
david
> > This message (
> > Example code
> > global_settings {
> >   assumed_gamma 1.0
> >   ambient_light White
> > camera {
> >    sky <0, 0, -1>
> >    look_at <0, 0, 0>
> > plane { <0,0,-1>, 0
> > #end
> > 10,0,-10,0,178,238,
> Alain
Date: 27 Aug 2017 09:31:40
Message: <59a2c9bc$1@news.povray.org>
>> text file.
>> to render.
>> global_settings {
>>   assumed_gamma 1.0
>>   ambient_light White
If you intend to do a "2D like" picture with exact match of the colour,
you should use also "assumed_gamma srgb" in global settings and "finish
{ ambient 1 diffuse 0 reflection 0}".
no need of light source in such settings.
And do not forget to start with a #version 3.7;
Date: 27 Aug 2017 10:15:20
Message: <59a2d3f8@news.povray.org>
Am 27.08.2017 um 15:31 schrieb Le_Forgeron:
>>> global_settings {
>>>   assumed_gamma 1.0
>>>   ambient_light White
`assumed_gamma srgb` is never a good idea. If you're using `srgb` for
the pigment and `File_Gamma=srgb` you should be fine in terms of input
colour = output colour. If you're only using `emission` or `ambient`,
the `assumed_gamma` setting should actually be irrelevant.
> and "finish
with v3.7 you should better use
    finish { ambient 0 emission 1 diffuse 0 reflection 0}
