POV-Ray : Newsgroups : povray.newusers : Convert a solid to something pov-ray can read Server Time
2 May 2025 07:13:34 EDT (-0400)
  Convert a solid to something pov-ray can read (Message 1 to 10 of 22)
Subject: Convert a solid to something pov-ray can read
Date: 15 Sep 2016 20:35:05
Message: <web.57db3deb40043d07f17efbc0@news.povray.org>
Hi All,
I'm trying to render a scene in pov ray of a real life mineral ore body. The ore
body has been made and is a complicated wireframe modeled in a mining software
in .dxf format. What is the best way to convert this to something pov-ray can
read, where I can then use the program to adjust the textures, colors and the
usual stuff once its placed where I want it.
Ive downloaded 'PoseRay' by FlyerX and had played with this for a while but I'm
wondering if there is something that can make it a little easier to import.
It doesn't have to be .dxf, if someone knows and easier format that pov-ray
likes while retaining its detail, I'm willing to try this too.
Apologies for the repeat question, but I've tried multiple links provided on the
'resources: Conversion utilities' page and many appear to be not in use anymore.
Subject: Re: Convert a solid to something pov-ray can read
Date: 16 Sep 2016 02:50:24
Message: <57db9630$1@news.povray.org>
On 16/09/2016 01:33, SecondCup wrote:
> Hi All,
If your mining software can export a mesh-based format like .obj, .stl,
.slp, .vrml then there's software to convert to POV format.
Date: 16 Sep 2016 05:54:08
Message: <57dbc140$1@news.povray.org>
Am 16.09.2016 um 08:50 schrieb scott:
> ..slp, .vrml then there's software to convert to POV format.
... and direct OBJ import into POV-Ray is on its way.
Date: 19 Sep 2016 13:10:00
Message: <web.57e01b70b7609bb865efcef0@news.povray.org>
> > Hi All,
Thanks Scott.
I'm not sure how familiar you are with PoseRay but it renders the wireframe
(whether a .dxf or .obj) as a kind of a snapshot of the solid as it is on the
screen at the time of rendering. Then when you run the .pov, it produces a black
and white shaded image of the solid and exports it as a .png too. When run in
pov-ray, its a badly pixelated shaded surface
In summary, its not producing the wireframe as a true solid the way it is when
viewed as a .dxf or .obj in other software. I'm probably not explaining my self
very well, but I can provide all the files if you want
Date: 19 Sep 2016 14:13:02
Message: <57e02aae$1@news.povray.org>
On 9/19/2016 6:09 PM, SecondCup wrote:
> Thanks Scott.
Just a thought. A wireframe is not a solid it is just the edges as far
as I understand it.
When I use PoseRay. I do not allow it to render the scene but export the
geometry and material then import it into Bishop3D* to work on it and
view it in openGL.
Bishop3D is a modeller for PovRay which is now free but only works with
PovRay Ver 3.6
Also you would need to use an older version of PoseRay ver 3.12.2.456 or
Bishop3D will not be able to import it.
Regards
Date: 20 Sep 2016 02:52:39
Message: <57e0dcb7$1@news.povray.org>
>>> Hi All,
> Thanks Scott.
If I understand you correctly (I may be wrong) I think that what you
need to do is 'export' your .dxf or .obj to POV-Ray using Poseray. This
generates a couple of files (MyObject_POV_geom.inc and
MyObject_POV_mat.inc) containing a mesh2{} file that describes the
original geometry and textures, and which you can then render in POV-Ray
as an object{}. You may probably need to edit the material file.
Date: 20 Sep 2016 08:52:58
Message: <57e1312a$1@news.povray.org>
On 09/15/2016 08:33 PM, SecondCup wrote:
> Hi All,
I'm not aware of a direct path to povray from dxf. If the mining
software can output obj(povray import just added to 3.7.1) or something
PoseRay can handle that is probably the easiest path into POV-Ray as
others have suggested. The latter the better path, if you are getting
materials/textures from which you'd like to start.
Though I've not used them, I know of FreeCAD and OpenSCAD. At least from
their docs it looks like there is perhaps path for the mesh data:
dxf -> openscad -> off -> freecad -> povray
There is too the MeshLab tool I've played with a little, which can
import/export many mesh formats as well as process them in various ways
- but it doesn't import or export from the POV-Ray native mesh formats.
Bill P.
Date: 21 Sep 2016 15:00:00
Message: <web.57e2d78bb7609bb7f17efbc0@news.povray.org>
> > Hi All,
> Bill P.
Hi all,
Ive found a great online conversion program called AccuTrans. Its converts to
..pov and other formats for seamless importing.
Date: 21 Sep 2016 15:14:07
Message: <57e2dbff$1@news.povray.org>
On 9/21/2016 7:55 PM, SecondCup wrote:
> Hi all,
> ...pov and other formats for seamless importing.
I've just had a look at the file formats. It supports Pov ver 3.0
That is quite old and it is not free.
I use Bishop3D which is dead but supports Pov Ver 3.6
I use it to generate pov files that I can run in Pov 3.7 for the speed
of using all my CPUs
Although not supported now. There are a couple of uses here who could help.
Regards
Date: 22 Sep 2016 03:58:57
Message: <57e38f41$1@news.povray.org>
>> Hi all,
>> converts to
And I am stubborn: I still would like to hear (maybe see an example in
p.b.i.?) from SecondCup how he fares with a proper pov-ray mesh2{}
export in Poseray.
