POV-Ray : Newsgroups : povray.newusers : Point lights and simulation with radiosity Server Time
3 Aug 2025 12:12:27 EDT (-0400)
  Point lights and simulation with radiosity (Message 1 to 7 of 7)
Subject: Point lights and simulation with radiosity
Date: 11 Jul 2016 11:05:00
Message: <web.5783b5118163353cbec14beb0@news.povray.org>
Hellow,
I've recently begun using povray and although I'm finding solutions for a lot of
problems at the documentation and the newsgroups, there is something I'm finding
difficult to understand: If I use radiosity and as light source a sphere of 1 mm
of diameter, at a distance of 10 mm I obtain the brightness predicted by physics
(or that I think): 1% of the original , but if I use a pointlight with
fade_distance=1 and fade_power=2 deactivating radiosity, the brightness doubles,
while it should be the same.
I'm using Imagej to measure the brightness in a 16 bits gray scaled image
without gamma correction.
The code:
#version 3.7;
global_settings {ambient_light 0
   //radiosity {count 100000  max_sample -1 gray_threshold 0.0 brightness 1
normal
on media on}
    assumed_gamma 1.0
camera {orthographic location <5,0,0>  look_at <10,0,0> angle 90}
//Source (2 options)
//sphere {<0,0,0> 1 texture {pigment {color rgb<1,1,1>} finish {emission 1
ambient 0 reflection 0 diffuse 0} } }
light_source { <0,0,0> color rgb <1,1,1> fade_distance 1 fade_power 2}
//Surface
plane {<1,0,0> 10
    texture {pigment {color rgb<1,1,1>} finish {emission 0 ambient 0 reflection
0 diffuse 1 } }
Thanks
Subject: Re: Point lights and simulation with radiosity
Date: 11 Jul 2016 12:10:01
Message: <web.5783c42c2fcd94eab488d9aa0@news.povray.org>
I'll just say that your sphere has a radius, and the point source doesn't.
So it's 1 radius closer than the point light.
Move the sphere 1 radius further away from your surface and see what happens.
Work from there.
Date: 11 Jul 2016 12:55:01
Message: <web.5783ceea2fcd94eabec14beb0@news.povray.org>
> Work from there.
No, that's not the problem. The sphere gives 1/2 of the brightness of the point
light.
Now I've reviewed the attenuation law of light at
http://www.povray.org/documentation/view/3.6.2/317/ and the trick is that I
should divide the intensity of the point light by 2 according to the formula at
that page if I want to reproduce the behaviour I obtain with the sphere.
Many thanks for your help anyway.
Date: 11 Jul 2016 18:32:33
Message: <57841e81$1@news.povray.org>
>> Work from there.
> light.
your code example indicated that you're using v3.7, but the link you
referenced is for v3.6.2
check out:
http://wiki.povray.org/content/Reference:Light_Source#Light_Fading
there's some additional information ... /maybe/ it's relevant
Date: 12 Jul 2016 02:20:01
Message: <web.57848b0e2fcd94ea991518c30@news.povray.org>
Yes, there seems to be more useful information. I'll read it.
Thanks.
Date: 12 Jul 2016 03:48:55
Message: <5784a0e7@news.povray.org>
Am 11.07.2016 um 17:03 schrieb fsv2712:
You're probably seeing the effect of a decades-long legacy quirk of
POV-Ray's light intensity handling.
The original effective calibration of any brightness-ish properties was
such that unity values would give unity results in the output images:
- A light source with unity brightness, shining vertically on a white
surface with unity pigment and unity `diffuse` setting (at a distance of
`fade_distance` if applicable), would give a 100% white pixel in the
resulting image (presuming all other finish properties would be set to 0).
- Similarly, a surface with unity pigment and unity `ambient` setting
would also give a 100% white pixel in the resulting image (again
This was all that could originally be said about the calibration of
light intensity.
- With the introduction of radiosity, the calibration of the `diffuse`
property was effectively formalized such that a material with unity
pigment and unity `diffuse` setting corresponds to unity _hemispherical
reflectance_.
- The faily new `emission` setting uses the same calibration as the
`ambient` setting (presuming the global `ambient_light` setting is left
at its default of 1.0), for ease of transition between the two mechanisms.
The result is that the calibrations for light source brightness and the
`emission` setting are such that the radiant flux of a light source with
unity brightness and fade_distance R does /not/ match the radiant flux
of a sphere with radius R and both unity pigment and unity `emission`
setting.
Date: 12 Jul 2016 11:30:00
Message: <web.57850c8a2fcd94eabec14beb0@news.povray.org>
Many thanks for the explanation, clipka.
I'm not sure I have fully understand what you are trying to tell, but even if
that was the case, this has helped me understand why this behaviour appears.
