POV-Ray : Newsgroups : povray.newusers : Strange shadows under figure Server Time
2 May 2025 07:29:14 EDT (-0400)
  Strange shadows under figure (Message 1 to 7 of 7)
Subject: Strange shadows under figure
Date: 22 Jun 2016 06:30:01
Message: <web.576a6845100836ac3e67ba860@news.povray.org>
Hi, I'm trying to render a surface I exported from a VTK visualisation software,
but there are some strange lights under the surface
The bottom part of my figure is here:
https://s32.postimg.org/7y35aegp1/sample.png
I'm using this settings at the beginning of my POV file
#include "rad_def.inc"
// For the mesh2 textures:
#declare my_texture = finish { phong 1 phong_size 20 ambient 0
                                   reflection{metallic 0}
global_settings {
      max_trace_level 30
      assumed_gamma 1.5
      radiosity { Rad_Settings( Radiosity_Fast, on, on ) }
      photons { spacing 0.005 }
background { color rgb <1.000000, 1.000000, 1.000000>}
 perspective
 location <8.196152, 8.196152, 8.196152>
 sky <0.000000, 0.000000, 1.000000>
 right <-1, 0, 0>
 angle 30.000000
 look_at <0.000000, 0.000000, -0.000000>
light_source { <-3, -3, 4.>
               color White
               area_light <6, 0, 0>, <0, 6, 0>, 6, 6
               area_illumination on
               photons {area_light}
               jitter
               // adaptive 1
plane
    <0, 0, 1>, -1
    texture{ pigment { color rgb < 1, 1, 1 > }
             finish{ ambient 0 diffuse 0.5 }
Is there a way to fix that? I tried increasing the max_trace_level but it
doesn't change, neither with the photons although I didn't specify photons in
the main figure (it gets too slow)
Subject: Re: Strange shadows under figure
Date: 22 Jun 2016 07:36:08
Message: <576a7828$1@news.povray.org>
I'd guess the first issue is the area_light is very near your object for
the vectors you have specified(1). Probably the low quality radiosity
settings play a part too. Changing the max_trace_level is unlikely to
affect anything.
Suggest:
- Comment out all the photon stuff.
- Change the first line of your light source to say :
light_source { <-3, -3, 4.>*100
- Change your radiosity settings to:
radiosity { Rad_Settings( Radiosity_Final, on, on ) }
Aside: If the triangle count on your mesh is low you might also be
seeing sharp edges in the base mesh - smoothing the mesh might help.
Bill P.
(1) - There is a circular / auto-orient area light option which is
useful too.
Date: 22 Jun 2016 07:51:05
Message: <576a7ba9$1@news.povray.org>
On 22-6-2016 12:28, aradan.d wrote:
> global_settings {
>       max_trace_level 30
>       assumed_gamma 1.5
Most probably the splotchiness come from the radiosity settings. You
should try at least these parameters:
error_bound 1.0 //start here and decrease slowly until splotchiness
disappears
nearest_count 10 //or higher, up to 20
recursion_limit 2 //should be fine for this
You can increase count substantially without problems. If you use the
Rad_Settings, set the two on's to off as you have no normals (have you?)
nor media to take care of.
A smaller pretrace_end is also to be recommended: 0.01 or 0.005 for
instance.
Take out the photons altogether.
The preset values are fine but generally you get better results with
your own settings, adapted to your particular scene.
Date: 22 Jun 2016 08:55:01
Message: <web.576a8977e30423da49882bdf0@news.povray.org>
Thanks, the radiosity settings were the ones that caused the weird shadows.
Using an error bound of 1.5 makes it look really nice. I will also check the
other suggestions and see how they work.
Date: 22 Jun 2016 09:34:28
Message: <576a93e4$1@news.povray.org>
Wondering if maybe the near area light (like 36 discrete lights being
placed so near) would still more or less work out OK because of jitter.
In other words, now wondering if the jitter is in the area light to
light space and not the pixel AA space(1).
It is! 15+ years using POV-Ray and I'm still getting my head around
fundamental things...
The result in my local test was still noisy so suppose it might still
affect radiosity. Increasing the area light count might help if true.
Bill P.
(1) For what it is worth, the following from the Making animation
section of the documentation is what confused me about how jitter really
works. "Jitter is a very small amount of random ray perturbation
designed to diffuse tiny aliasing errors...". The jitter being in the
area light to light space I believe means the ray to light perturbation
can be any magnitude from really tiny to really large.
Date: 23 Jun 2016 00:15:25
Message: <576b625d$1@news.povray.org>
Looking at your image, it realy look like radiosity artefacts.
Things that can help:
Increasing the count value and add the second parameter. Set that second
parameter to about 10 to 20 times your count value. It set a pool of
sampling directions that are used in rotation.
Try to use a smaller value for minimum_reuse. Don't go overboard,
something like 0.001 should be enough. Default at 0.0015.
Use a smaller pretrace_end. You can go as low as 0.00125 for a large image.
Reducing error_bound may help, as reducing low_error_factor from the 0.5
default value. Note that the value for that parameter are larger than
that in rad_def.inc as they are based on the older default of 0.8 from
version 3.5.
It don't look like your area light have problems.
You can increase the sampling a lot if you use the adaptive option.
using adaptive 0 turn it ON and start sampling using only the 4 corners
points. adaptive 1 start sampling with an array of 3*3, adaptive 2 start
at 5*5 and adaptive 3 at 9*9. Using adaptive, you can use arrays of
65*65 with almost no slowdown over a 9*9 one.
If you want to use the orient option, you also must use a square array
and use the circular option.
Date: 23 Jun 2016 03:19:00
Message: <576b8d64$1@news.povray.org>
Alain's suggestions are very sound.
Something you may consider, even in a wip, is to use a micronormal on
the ground plane. It will not necessarily decrease radiosity artefacts
but it improves the view without to much additional render time.
Something like normal {granite 0.5 scale 0.001} for example.
