POV-Ray : Newsgroups : povray.newusers : image_map > solid object Server Time
1 Jun 2024 21:48:07 EDT (-0400)
  image_map > solid object (Message 1 to 10 of 16)
Subject: image_map > solid object
Date: 3 May 2016 07:55:00
Message: <web.5728916fbf15e33d7b8901bc0@news.povray.org>
I have a simple box with image_map pigment, transparent PNG.
light_source { <0,0,-200> White*1.5 shadowless }
camera { location <0,0,-35> look_at <0,0,0>  }
box {   <0, 0, 0>  < 50,  50,  10 >
    texture {pigment {
image_map
  png "logo2.png"
  once } } }
scale <30, 20, 1>
translate <-15,-10,0>
rotate <0,45,0>  }
The result image looks like 2 very thin sheets, just surfaces (left side, see
attachment below).
I need a solid object, the 2 surfaces joined - the transparent yellow things on
the right side.
Of course, the "joining" part should be same color (green, red) and not
transparent - that is just for demonstration purposes.
Transparent PNG: https://www.dropbox.com/s/mbsuv2ti1x9g6f6/logo2.png?dl=0
Images: https://www.dropbox.com/s/jysf8dtzcfwnqul/Image2.jpg?dl=0
Subject: Re: image_map > solid object
Date: 3 May 2016 08:56:54
Message: <5728a016$1@news.povray.org>
Am 03.05.2016 um 13:54 schrieb Paul:
> attachment below).
> the right side.
That's not an easy thing to do. You might be able to transform the image
into a function (using a so-called "function pattern"), and from that
generate an isosurface object, but that's tricky and might suffer from
artifacts.
You might be better off trying to approximate the shape with a spline
curve (bezier splines are the easiest to tame), and use three "prism"
objects.
Alternatively you can use CSG, but that'll require a bit of puzzling how
to best achieve the desired shape with intersections, differences and
unions, and it may also render slower. On the other hand, if the curved
sections are supposed to be circular arcs, it'll be more exact than what
you can achieve with splines (they can't give you exact circles).
Date: 3 May 2016 09:10:01
Message: <web.5728a2db2da27c237b8901bc0@news.povray.org>
Re-creating the image from scratch, using standard Pov-Ray objects, yes, that is
an option.
And the example image is pretty easy, simple shapes.
But I have lots of other different images, more "artistic", not simple geometric
shapes.
So I'm looking for a universal solution, for any input image.
I also used a simple 'for' to duplicate the object 10-15 times, but the quality
is not that good (there are still empty spaces between objects) and the
rendering time is too big (I'm rendring lots of frames, for animations).
But, why aren't the resulting shapes solid, as far as I understoond from Pov-Ray
help > all object are solid by default.
If I do a simple 'difference' between 2 boxes > the result is indeed solid.
Date: 3 May 2016 09:41:14
Message: <5728aa7a@news.povray.org>
>> attachment below).
>> the right side.
This is true.
I would use CSG. The way I would try it is to use heightfields.
Fortunately you have only two colours. So separate your image into green
and red images. Change the white to black and get rid of the
transparency. Then reduce the colour depth to two colours, black and white.
Create a merge of a heightfield and one of the images. That should give
you one of the shapes. Do the same with the other image.
You can use the water level in the heightfield to remove the base.
You will end up with two objects that are open. To close them place a
scaled copy (very small in one dimension to make it thin) of the merge
as an end cap.
It may sound complicated but once you have got the idea. It is quite simple.
Regards
Date: 3 May 2016 09:47:08
Message: <5728abdc$1@news.povray.org>
On 5/3/2016 2:08 PM, Paul wrote:
> But, why aren't the resulting shapes solid, as far as I understood from Pov-Ray
That is because you are using transparency. If your design was to the
edge of the image. Then you would see it projected along the sides that
are invisible.
What you are seeing (if you scaled the visible faces close together) can
be used as a billboard. A 2D image that looks 3D from one particular
angle. Before Poser it was a simple way to make human figures.
Regards
Date: 3 May 2016 09:50:00
Message: <web.5728ac632da27c237b8901bc0@news.povray.org>
> as an end cap.
> Regards
>      Stephen
Like I said, this example PNG is very simple, 2 colors indeed.
But I have others with many colors, more complicated shapes, not so easy to
separate colors/shapes.
Also, heightfield does not produce the quality I need, I used them a long time
ago and they are not very smooth and sharp.
Date: 3 May 2016 10:15:00
Message: <web.5728b1a22da27c235b7d07940@news.povray.org>
"Paul" <nomail@nomail> wrote:
> I need a solid object, the 2 surfaces joined - the transparent yellow things > on
the right side.
Where do your images come from? If they were generated by a vector drawing
program you may be able to do it another way. Inkscape (https://inkscape.org/)
can export paths as POV-Ray prism objects, which would do exactly what you want.
If you only have the images, it may still be possible to use Inkscape to trace
over the images, creating equivalent paths that could then be exported.
Bill
Date: 3 May 2016 10:27:45
Message: <5728b561$1@news.povray.org>
> an option.
> shapes.
Solid don't mean opaque. A fully transparent object is solid, but you
see through it.
In your case, I'd use a height_field using a black & white version of
your image using water_level to clip the bottom part.
Next, use that height_field in an intersection with a box and apply your
image to that. You'll need to rotate the image by 90*x or the
intersection by -90*x so that they are oriented the same way.
It's probably the easiest and fastest way to proceed.
Date: 3 May 2016 10:29:31
Message: <5728b5cb$1@news.povray.org>
Am 03.05.2016 um 15:08 schrieb Paul:
> an option.
> shapes.
There is probably a conceptual misunderstanding here.
In POV-Ray, you have to distinguish three different concepts:
- The *surface* of a geometric primitive: This set of points is defined
*exclusively* by what type of primitive it is, what the
primitive-specific parameters are set to, and how it is transformed
(translated, scaled or rotated).
- The *volume* of an geometric primitive: This set of points is also
defined *exclusively* by what type of primitive it is, what the
(translated, scaled or rotated). (Usually this is the set of points
enveloped by the surface, although there are exceptions.)
- The *texture* of an object: This function of space is defined
*exclusively* by what pigment and finish you choose, and how you
transform them.
What POV-Ray actually displays is the *texture* at any *surface* that
meets certain constraints about being inside or outside other objects'
*volume* (as determined by CSG composition).
Your texture doesn't show up as 3-dimensional because there are no
surfaces in the bulk of the object. If you do a "difference" with
another object, you introduce another surface for the texture to be
displayed at.
(This is oversimplifying the situation a bit: There is also the concept
of media, which is somewhat like texture but can show up even between
surfaces; but that's always "foggy" in nature, and doesn't introduce new
surfaces.)
There is one way to turn functions of space into actual surfaces, and
that's the isosurface primitive: It takes a scalar function of space
(i.e. a function taking three coordinates and evaluating to a single
value) and defines surface and a volume based on where the function
evaluates to a given threshold.
In order to make use of this primitive type for your purpose, you need
to know that you can turn a pigment into a scalar function suitable for
an isosurface; for that you'll need a "pigment function". You'll also
need to know that a function used in an isosurface must not have any
discontinuities, so you need to activate interpolation on it.
Date: 3 May 2016 10:30:00
Message: <web.5728b4e32da27c23a09e82530@news.povray.org>
the right side.
> Bill
Images are coming from clients.
No other formats are available, only PNG (if I'm lucky) or JPG.
I don't think tracing will work, probably not that good definition of resulting
objects.
Well, looks like this is one tricky operation, thank you for all your help.
