POV-Ray : Newsgroups : povray.newusers : the direction_length calculation Server Time
18 Nov 2025 11:30:43 EST (-0500)
  the direction_length calculation (Message 1 to 3 of 3)
Subject: the direction_length calculation
Date: 29 Mar 2016 08:45:00
Message: <web.56fa77e419d34c693fdf54d50@news.povray.org>
Hi,about the following codes,I have some questions:
   location <10.0, 20.0, -100.0>
   angle 65
Question:The formula used is direction_length = 0.5 * right_length / tan(angle /
2) where right_length is the length of the right vector. How can I get the right
vector in this case or there is a default right vector?
   angle 65
   look_at <10.0, 20.0, 0.0>
Question:the help file says,"The look_at modifier changes both the up and right
vectors." And the direction_length calculation depends on the right vector.In
such a situation,how to compute the direction_length? And I think that the
direction vector is parallel to look_at vector,is it right?
Thank for your help!
Subject: Re: the direction_length calculation
Date: 29 Mar 2016 10:51:08
Message: <56fa965c$1@news.povray.org>
Am 29.03.2016 um 14:42 schrieb Lsq:
> camera {
>    angle 65
In the above case, you have specified the "right" vector as
<image_width/image_height,0,0> yourself (because x is a constant equal
to <1,0,0>), so I fail to see what your question is.
The default "right" vector is x*1.33 (_not_ exactly 4/3).
> camera {
>    angle 65
As look_at only rotates the up, right and direction vectors, but leaves
their length unchanged, direction_length is also unaffected.
As for the direction vector's orientation, it will be parallel to the
look_at vector _minus_ the camera location (becasue "look_at" does not
actually specify a direction but a point).
Date: 29 Mar 2016 20:15:00
Message: <web.56fb1a77c56b3e183fdf54d50@news.povray.org>
> > camera {
> >    angle 65
> > camera {
> >    angle 65
Thanks a lot! I got it.
