POV-Ray : Newsgroups : povray.newusers : patterns + White, Black, alpha Server Time
31 May 2024 19:17:29 EDT (-0400)
  patterns + White, Black, alpha (Message 1 to 5 of 5)
Subject: patterns + White, Black, alpha
Date: 5 Sep 2014 20:55:01
Message: <web.540a5b4f68b280f25e7df57c0@news.povray.org>
I'm trying to muddle through the process of using an image file to create a
3D-ish looking ornate picture frame.
I kinda 'get' that I'll probably have to nest 1 or 2 of these
image/pigment/pattern/map(s) together in order to get this to work, but I'm
getting all twisted up.
I finally figured out how to FILL the border and center of the frame with a
transparent color in Paint.Net, so I have a frame composed of white, black, and
the transparent parts that I don't wish to be visible when rendered.
I haven't done much with these commands, but I've seen that folks reference
their use a lot, so they seem like a powerful tool.
Can someone give me a clue?
height_field {png "Frame2.png" smooth
 translate<-0.5,-0.0,-0.5>
 scale <946, 15, 799>/5
 rotate -x*90
  image_pattern { png "Frame2.png" once}
  texture_map {
    [0 MyGold]
    [1 pigment { transmit 1 } ]
Subject: Re: patterns + White, Black, alpha
Date: 6 Sep 2014 05:08:38
Message: <540acf16$1@news.povray.org>
>   rotate -x*90
> texture {
>    texture_map {
>      [0 MyGold]
   Well... you really didn't need alpha for this: the height_field
object has a "water_level" statement wich allows you to cut the
undesired parts. This way you don't need to use a texture map, just a
regular texture. For this to work, just paint the border and center with
total black, and the desired frame with a grayscale above black, then
use "water_level 0.01" or so (might need some trial&error to find the
best level).
   water_level 0.01
   texture {MyGold}
   scale <640, 15, 400>/5
   rotate -x*90
   Anyhow, on the example you posted, I guess you are missing some
transformations on the texture: if you want it to align with the object.
My prefered way would be:
    texture_map {
      [0 MyGold]
    rotate 90*x
   rotate -x*90
   Also, I guess you may want to reverse the texture map entries and
adjust the transition...
jaime
Date: 6 Sep 2014 11:25:00
Message: <web.540b26487c0a49655e7df57c0@news.povray.org>
I always have to add my trademark "unnecessary level of added complexity" to my
first go at things.  :)
> the height_field
> undesired parts.
Argh.  I was starting to look at that and consider it, but it was after a long
day of puzzling out other things.   That's obvious now - thanks!
I see.  This works well now.
Thank you for your expert assistance - I'm always amazed at your raytracings.
You have a real knack for composition, details, texturing and lighting that
always knocks my socks off.   Thanks for all of your inspirational images over
the years!
I have a few more questions related to this topic.
Because of the way POV-Ray maps the image to the primitive, it needs to be
scaled to something proportional to the image's original aspect ratio.  Is there
a way to pull this value from the file with POV-Ray?  I'm assuming the
information is readily available, since Windows displays it when I mouse-over
the filename, and POV-Ray has to be able to determine this to correctly read the
file format.
This would be super handy for evaluating a lot of different images, especially
with an array of filenames and invoking POV-Ray's animation features.
Suppose I DID use the alpha channel.
Is there a way to use that for a second texture, so that I can use water-level
to get rid of the perimeter, and put the second texture inside the frame?
Thanks for your prompt reply!
(I had a late night, so I'm just resuming work on this now.)
Date: 6 Sep 2014 14:50:37
Message: <540b577d@news.povray.org>
>> the height_field
>> undesired parts.
> the years!
> file format.
You may try max_extent(Your_Image)
As of version 3.7, it's suposed to return the dimentions of an image
when the provided object is an image.
Date: 6 Sep 2014 15:50:01
Message: <web.540b64e97c0a49655e7df57c0@news.povray.org>
It's supposed to, and it DOES!
The documentation even provides immediately useful SDL example code. /HAPPY/
Thank you Alain, that's exactly what I was looking for.
As always, you are an endless font of information.  :)
