POV-Ray : Newsgroups : povray.newusers : Height of a polygon. Server Time
15 Apr 2025 23:31:47 EDT (-0400)
  Height of a polygon. (Message 1 to 3 of 3)
Subject: Height of a polygon.
Date: 22 Jun 2013 16:40:01
Message: <web.51c60b85f9759873520168c30@news.povray.org>
I created a polygon to make a object that has rounded edges.
Its works wel apart that i cant get the height of the polygon any larger.
{code]
#declare housing_grnd =
difference {
    union {
        polygon{
            21,
            <17.925,28.575>,  <-17.925,28.575>, <-18.925,27.575>,
<-18.925,18.925>,
            <-27.575,18.925>, <-28.575,17.925>,
<-28.575,-17.925>,<-27.575,-18.925>,
<-18.925,-18.925>,<-18.925,-27.575>,<-17.925,-28.575>,<17.925,-28.575>,
            <18.925,-27.575>, <18.925,-18.925>, <27.575,-18.925>,
<28.575,-17.925>,
            <28.575,17.925>,  <27.575,18.925>,  <18.925,18.925>,
<18.925,27.575>,
            <17.925,28.575>
            pigment{ Red }
            rotate<90,0,0>
            scale<1,2,1>
        cylinder{<-27.575,.05,17.925><-27.575,-.05,17.925>1  material{ MyRedLed
        cylinder{<27.575,.05,17.925><27.575,-.05,17.925>1  material{ MyRedLed }
        cylinder{<-27.575,.05,-17.925><-27.575,-.05,-17.925>1  material{
MyRedLed } }
        cylinder{<27.575,.05,-17.925><27.575,-.05,-17.925>1  material{ MyRedLed
        cylinder{<-17.925,.05,27.575><-17.925,-.05,27.575>1  material{ MyRedLed
        cylinder{<17.925,.05,27.575><17.925,-.05,27.575>1  material{ MyRedLed }
        cylinder{<-17.925,.05,-27.575><-17.925,-.05,-27.575>1  material{
MyRedLed } }
        cylinder{<17.925,.05,-27.575><17.925,-.05,-27.575>1  material{ MyRedLed
[/code]
Looking from above the polygon looks like it should be.
From the side it looks that there is no polygon.
It needs to be as thick as the rounds at the edgd\es.
Acoording to the documentation it says:
    //scale and rotate as needed here
But the scale modifier seems not to work.
Subject: Re: Height of a polygon.
Date: 22 Jun 2013 20:14:10
Message: <51c63dd2$1@news.povray.org>
> {code]
> [/code]
The polygon object is in the same class of objects as the disc. It is
completely flat so the scale in y of 2 in your code is a scale of an
object with thickness 0.0.
You can instead use a prism :
prism {
     linear_spline
     linear_sweep
     0.0, 0.05, 21,
     <17.9250,28.5750>
     <-17.9250,28.5750>
     <-18.9250,27.5750>
     <-18.9250,18.9250>
     <-27.5750,18.9250>
     <-28.5750,17.9250>
     <-28.5750,-17.9250>
     <-27.5750,-18.9250>
     <-18.9250,-18.9250>
     <-18.9250,-27.5750>
     <-17.9250,-28.5750>
     <17.9250,-28.5750>
     <18.9250,-27.5750>
     <18.9250,-18.9250>
     <27.5750,-18.9250>
     <28.5750,-17.9250>
     <28.5750,17.9250>
     <27.5750,18.9250>
     <18.9250,18.9250>
     <18.9250,27.5750>
     <17.9250,28.5750>
     pigment { color Red }
     translate <0.0,-0.025,0.0>
     rotate <90.0,0,0>
Bill P.
Date: 24 Jun 2013 13:51:45
Message: <51c88731$1@news.povray.org>
A polygon have NO thickness at all. It all lay in a single plane. It's
strictly a 2D object. Like a triangle, it's only a flat surface, and you
don't have any normal control like you would with a smooth_triangle.
If you want a thickness, you need to use a prism object.
