POV-Ray : Newsgroups : povray.newusers : Very big time difference of a render Server Time
7 Apr 2026 11:10:09 EDT (-0400)
  Very big time difference of a render (Message 21 to 24 of 24)
Subject: Re: Very big time difference of a render
Date: 27 Jun 2013 20:32:03
Message: <51ccd983$1@news.povray.org>
> "Mr" <nomail@nomail> wrote:
>>> My version of the exporter is based on the official version, I didn't write a
>>> code from a blank sheet, but... the official version seeks to tie the Povray
>>> parameters to the Blender parameters that absolutely irrationally and doesn't
>>> allow to use all capacity or Povray force
>> The current implementation tied to blender parameters is only the first step,
>> what you are trying to do is the second step of what is planned for the exporter
>> development. the two steps are supposed to remain, just like you could convert
>> Blender Internal Material for Luxrender with its exporter AND also do native Lux
>> textures.
>> For this to work, the current "translation" code needs not to be broken, so more
>> features would stay available. Your discarding all that was previously done to
>> make your version from scratch makes us do double work instead of teaming up.
>> However I do understand that you want to be free to make your own workflow, I
>> hope you'll get everything in place soon so that maybe I can stop developing and
>> focus at last on creating nice images.
>> Note that the idea of the current exporter is not only to get access to all
>> POV-Ray's features, but also to use blender interface and workflow as a shortcut
>> to some advanced cases that would be cumbersome to code in POV-Ray such as
>> specular mapping, or try using blender's presets for subsurface scattering with
>> POV and you'll see what I mean as well.
>> In any case, thanks for keeping up the good work.
> I not against cooperation with you.
> I do this work quicker to receive full-function addon.
> Therefore I ask questions on this site.
> It is important to me to know that can achieve and that it is impossible.
> Nobody prompted to me how to bypass defect: long time with bad quality when
> using media scattering with mesh2.
> I am inclined to replace mesh with povray object "superellipsoid"
> I will involve for this purpose the Blender boolean modifier
> When I learn the potential, we will be able to talk about cooperation.
> But, I support creation of the separate interface for Povray in Blender.
> Otherwise many parameters remain unused. They will prevent the user to be guided
> and find the necessary.
> You don't need to stop the work, I always watch development of the official
> version.
> Ahead still there is a lot of work
> Due to the problem of media scattering with photons there is a new question.
>  From a floor on a wall light which color is reflected is set by the reflection
> parameter, but really the floor can have multi-color reflection which as I
> understood, it is impossible to set.
Often, when using photons with media, you get "fringes" effects that may
look like interference patterns. It's the most visible when the
direction of the photons is perpendicular to the viewing direction.
This have nothing to do with any mesh or mesh2: It can apens for all
primitives used as container. A simple workaround is to add jitter with
a value between 0.5 and 1 to the photons block in the glabal_settings
section.
Whenever you use any mesh/mesh2 with media, you need to make sure that
it's totaly closed. Any opening can cause some problems.
(internaly, mesh and mesh2 are absolutely identical as they differ
/only/ in the way they are represented in the source code)
If a mesh object is surrounded by media, is totaly or partialy
transparent AND you don't want any media inside, you need to use version
3.7 RC7 or later and add "inside_vector" followed by a direction vector.
This also allow the mesh to be used in a difference or intersection by
making it "solid".
If a mesh have an inside_vector and need to contain some media, it need
the "hollow" option.
Only if your mesh shape reflect that of a superellipsoid, it can be a
possible substitution.
If you want to have reflected photons that change according to the
colour of what it reflect uppon, you can add "metallic", optionaly
follower by a float ranging from 0 to 1.
This will tint the reflection by the colour of the surface. It will
affect ALL reflection from that surface, not just that of photons.
Strictly speaking, reflection demand a colour vector. If you only
provide a single float, it get internaly promoted to a gray RGB vector.
If you use a texture_map for something, each individual textures used
can have a reflection of a different colour that is independent from
that of the pigment.
For reflection, it's encouraged to use the new syntaxe:
reflection{Min_Value [Max_Value] [fresnel] [metallic [float]] [falloff
float] [exponent float] }
The parameters in square brackets are all optionals.
Min_Value and Max_Value allows for variable reflection.
fresnel activate the fresnel equation for variable reflection. If
fresnel is used with only a single value, Min_Value is set to zero. It
works with the ior provided in an interior block.
With metallic, the pigment influence the colour of the reflection. The
optional float controll the pigment contribution.
Date: 28 Jun 2013 14:30:00
Message: <web.51cdd54991e1715f7a3e03fe0@news.povray.org>
Alain, thanks!
I assume that I understood about what you wrote
Not clearly here it:
> making it "solid".
"inside_vector" - What is it? It is necessary to develop normals in comparison
with RC6?
I would be very grateful to you for very small example of a code: mesh(not
mesh2!)-room with window, mirror floor with texture image and metallic, media
scattering and photons(pass_through).
I am inclined to pass from mesh2 to mesh. It will allow to apply a separate
material to each triangle. Probably, I didn't see how to do it with mesh2.
It very much would help me and Mr with acceleration of creation of the exporter
Blender to Povray.
Thank you!
Date: 28 Jun 2013 18:46:31
Message: <51ce1247$1@news.povray.org>
> Alain, thanks!
>> making it "solid".
> with RC6?
The inside_vctor is a tool that enable a mesh object to be used as a
solid primitive. Otherwise, it's just a shell that can't be used in a
difference or intersection.
It can be added to any mesh. Just add:
inside_vector<1,0,0>
AFTER all other components of the mesh and before any other modifier and
transform.
The exact direction of the inside_vector is not crutial as long as it's
not parallel with a face.
A difference of a box and a mesh normaly return the box with an
invisible thickness less cut. With a mesh with an inside_vector, the
mesh can actualy remove parts of the other object.
A difference of a mesh without an inside_vector only return the surface
of the mesh inside the other object. With inside_vector, you get some
actual volume.
It have nothing to do with the normals.
It's only an added attribute for the mesh.
If I remember correctly, it was introduced in the earlyest RC releases,
or one of the last beta.
Sample:
mesh{ Body_Of_The_Mesh
  material{Some_Material}
  transform Transform
Whatever you can do with a mesh can be done with a mesh2.
With both, you can apply a texture on a vertice per vertice level.
A mesh2 can optionaly have a texture list similar to that of the vertice
and normal lists.
With both, a single triangle can have 3 textures, one associated with
each vertices.
The main difference is that a mesh can, with time and patience, be
codded by hand, while a mesh2 is best suited for an automated process by
a programm.
> Blender to Povray.
> Thank you!
I invite you to read the online documentation here:
2.4.2.3 Mesh
http://www.povray.org/documentation/view/3.6.1/292/
2.4.2.3.1 Solid Mesh DON'T apply to version 3.6.1.
2.4.2.4 Mesh2
http://www.povray.org/documentation/view/3.6.1/293/
Date: 29 Jun 2013 00:45:05
Message: <web.51ce652691e1715f7a3e03fe0@news.povray.org>
> transform.
> actual volume.
> Sample:
>   transform Transform
Thanks!
> a programm.
Understand
I am not going to use version 3.6.1.
Alain, thank you!
LanuHum
