POV-Ray : Newsgroups : povray.newusers : How to make the dish look like a mesh Server Time
16 Dec 2025 00:50:40 EST (-0500)
  How to make the dish look like a mesh (Message 1 to 4 of 4)
Subject: How to make the dish look like a mesh
Date: 16 Jun 2013 16:10:01
Message: <web.51be1a90f61a7d1a520168c30@news.povray.org>
Having completed the contruction of a satelite dish using this code.
The scene code looks like this:
[code]
// Create a dish width a diameter of 120cM
#declare dish_radius = 600;
#declare dish_depht = 15;
#declare BasicDish =
union {
    intersection {
        object { Paraboloid_Y scale <dish_radius, dish_depht, dish_radius> }
        object { Paraboloid_Y scale <dish_radius-1, dish_depht-1, dish_radius-1>
        plane  { y,dish_depht }
        texture{ clear_al }
        finish {
            ambient 0.2
            diffuse 0.8
            phong 1.0
            phong_size 10
#declare Rim =
union {
    difference {
        cylinder{<0,0,0><0,2,0>dish_radius }
        cylinder{<0,-.5,0><0,2.5,0>dish_radius-2.5 }
    } texture{ Brushed_Aluminum }
#declare MountingPlate =
union {
    difference {
        cylinder{<0,0,0><0,-4,0>100 }
        cylinder{<0,.5,0><0,-4.5,0>7.5 }
    } texture{ vero_green }
#declare SatDish =
union {
    union {
        difference {
            object{ BasicDish }
            cylinder{<0,-.5,0><0,dish_depht+1,0>2.25 }
        object{ Rim translate<0,dish_depht,0> }
        object{ MountingPlate }
    } rotate<90,0,0>
}[/code]
But the question is how make i the dish look like its made out of mesh
It should look somthing like this
http://www.harry-arends.nl/werkgroep/images/schotelKL.jpg
Subject: Re: How to make the dish look like a mesh
Date: 16 Jun 2013 17:45:00
Message: <web.51be3160155ef9c978641e0c0@news.povray.org>
Try a patterned texture with transparent holes, such as this:
[code]
#declare clear_al = texture
{ gradient z texture_map
  { [0.1 Aluminum]
    [0.1 gradient x texture_map
      { [0.1 Aluminum]
        [0.1 pigment { rgbt 1 }]
  scale 60
[/code]
You would have to remove the finish statement from the BasicDish declaration, or
else you will get a parse error.  If you like, you can redefine texture Aluminum
to include that finish:
[code]
#include "textures.inc"
#declare Aluminum = texture
{ Aluminum
  finish
  { ambient 0.2
    diffuse 0.8
    phong 1.0
    phong_size 10
[/code]
Date: 17 Jun 2013 03:15:06
Message: <web.51beb6e6155ef9c9520168c30@news.povray.org>
I got i working now but with a strange result as can be seen here:
http://www.harry-arends.nl/werkgroep/images/ParabolicDishVersion1.png
It looks that the plane is playing havoc or is this normal behaivior?
> [code]
>   { [0.1 Aluminum]
>       { [0.1 Aluminum]
>   scale 60
> [/code]
> [code]
> { Aluminum
>   finish
>   { ambient 0.2
>     diffuse 0.8
>     phong 1.0
>     phong_size 10
> [/code]
Date: 17 Jun 2013 16:53:07
Message: <51bf7733$1@news.povray.org>
Normal behaviour.
In fact, the transparent areas allow you to see the inside of the object.
You see the pattern applied to both the plane and the sphere part.
What you can do, is to apply the texture specificaly to the sphere and
pigment{rgbt 1} to the plane.
