POV-Ray : Newsgroups : povray.newusers : Calling a #macro gives error Server Time
18 Nov 2025 15:17:09 EST (-0500)
  Calling a #macro gives error (Message 1 to 3 of 3)
Subject: Calling a #macro gives error
Date: 16 Jun 2013 07:30:01
Message: <web.51bda10dec77e24c520168c30@news.povray.org>
For a scene i would like to include a floor.
Therefore is modified the superellipsoid  example.
Running this whitout the #macro and #end the schene renders perfect
[code]
#macro Floor(MaxTile, MaxRow)
#declare Offset = 2.1;
  #declare Tile = superellipsoid { <0.5, 0.1>
    scale <1, .05, 1>
#declare Row = union {
    object { Tile }
#declare index =-MaxTile;
#while(index <= MaxTile)
    object { Tile translate z*Offset*index }
#declare index = index + 1;
#declare index = -MaxRow;
  union{
    object { Row }
#while(index <= MaxRow)
    object { Row translate x*Offset*index }
    pigment { White_Marble }
    finish { phong 1 phong_size 50 reflection .35 }
  plane {
    y, 0  //this is the grout
    pigment { color White }
    finish { ambient .4 diffuse .7 }
[/code]
But if i call it as a macro like object{Floor(10,10) } it produces a error at
the plane command. It puzzles me how this is possible. Anny help is welcome.
Subject: Re: Calling a #macro gives error
Date: 16 Jun 2013 10:20:00
Message: <web.51bdc8e91f7bf73a11b13fda0@news.povray.org>
> [code]
>   union{
>     object { Row }
> #end
>   plane {
> #end
> [/code]
This is because you have two separate objects, the union{} and the plane{}, in
the macro.  When you are calling it inside your object{} wrapper, it is looking
for only one, so when it reaches the second, it returns an error.
Try calling it union{Floor(10,10) } instead, or put the plane and union together
in a union{} wrapper inside the macro.
-tgq
Date: 16 Jun 2013 13:00:01
Message: <web.51bdee271f7bf73a520168c30@news.povray.org>
I did the last solution. Thnx
> > [code]
> >   union{
> >     object { Row }
> > #end
> >   plane {
> > #end
> > [/code]
> -tgq
