POV-Ray : Newsgroups : povray.newusers : How to refract light sources properly? Server Time
21 Feb 2025 13:25:46 EST (-0500)
  How to refract light sources properly? (Message 1 to 2 of 2)
Subject: How to refract light sources properly?
Date: 3 Feb 2013 16:00:01
Message: <web.510ece923fdcbd685dcec4c10@news.povray.org>
Hello,
I am quite new to Pov-ray, so maybe my question is a bit basic.
I am trying to model a LED torch and would like to add a lense. However, the
lense I managed to create distorts the physical objects depneding on the
refraction index -- but apparently not the light sources?!
i.e., the light sources are placed at the bases of seven cones (placed in the
main element) and shine towards a plane (just for testing). But the lense I
place above does not change the light path. But it 'works' to distort the
physical objects.
I switched photons on, assuming that they will find the right path through the
lense, but without success
The test code is available at:
https://gist.github.com/e63f56363ace292c6534#file-ledlense-pov
Cheers and many thanks for ideas,
Subject: Re: How to refract light sources properly?
Date: 3 Feb 2013 17:33:36
Message: <510ee5c0@news.povray.org>
Am 03.02.2013 21:55, schrieb Chuck:
> Hello,
> physical objects.
So far you have only designated a light source that should take part in
caustics computations, but no "optically active" objects that you'd like
to interact with that light.
You'll need to designate the lens as a "photon target". Do this using
object {
   Linse
   translate <0,50,0>
   texture{ T_Glass3 }
   interior{ I_Glass }
   photons {
     target
     refraction on
     reflection on
     collect off
You should also do the same for the reflector.
This is done because in normal scenes the objects that cause caustics
are comparatively small and far away from the light source: A glass of
wine, a crystal ball, a vase, a precious stone - that sort of stuff. In
such a scene, if POV-Ray would always shoot photons in all directions to
see where they end up it would take ages to complete where classic
backward raytracing would take just a few moments; so POV-Ray will only
shoot photons in the direction of those objects which you tell it to
(via the "target" keyword), and all other regions in the image will be
computed with classic backward raytracing.
I'm not perfectly sure whether you also need a
global_settings{photons{...}} block.
