POV-Ray : Newsgroups : povray.newusers : difference declared mesh2 object Server Time
26 Mar 2026 04:33:23 EDT (-0400)
  difference declared mesh2 object (Message 1 to 9 of 9)
Subject: difference declared mesh2 object
Date: 27 Dec 2012 10:35:00
Message: <web.50dc6a67492ec219ed187b800@news.povray.org>
Hi all,
This is my first post. I tried searching the forum, be couldn't find what I'm
looking for ...
Can I difference the same object on itself?
I tried it and no error comes up, but the scene is empty.
Thanks, Dick
Code:
difference {
 object {
  myBox
  translate <0, 0, 0>
  scale <1, 1, 1>
 object {
  myBox
  translate <0.25, -0.01, 0.25>
  scale <0.5, 1.01, 0.5>
Subject: Re: difference declared mesh2 object
Date: 27 Dec 2012 11:11:57
Message: <50dc734d@news.povray.org>
You can, but the problem with a mesh object is that it's not solid and
therefore cannot be used in CSG as-is.
You are in luck, however, because a mesh can be made solid by using the
keyword "inside_vector" followed by a direction (something like <1, 0, 0>
will usually work just fine) and thus it should work in CSG.
Date: 27 Dec 2012 12:00:01
Message: <web.50dc7de19596b06828b22f720@news.povray.org>
Yes, warp is right completelly. You can put the inside statement immediately
before the closing bracket "}" of the mesh2-definition, the direction itself is
not important but the inside_vector must exist. Then you can use mesh2-objects
with CSG-operations like differences or intersections as with the other
POV-primitives.
Best regards,
Michael
Date: 27 Dec 2012 12:20:36
Message: <50dc8364@news.povray.org>
(One might ask that if the direction is not important, then why it has to
be specified. The direction is not important only for *closed* meshes. For
open meshes it makes a huge difference which direction you choose.)
Date: 27 Dec 2012 13:00:00
Message: <web.50dc8c069596b06828b22f720@news.povray.org>
Ah, yes, you are right. But as I understand it so far, open meshes are a problem
even with a proper inside_vector.
Michael
Date: 27 Dec 2012 18:31:30
Message: <50dcda52@news.povray.org>
> Hi all,
> looking for ...
> Thanks, Dick
> Code:
> difference {
>   object {
>    myBox
>    translate <0, 0, 0>
>    scale <1, 1, 1>
>   object {
>    myBox
If your object is a regular, solid, primitive, or union of regular
primitives, as you translate and unevenly scale the second instance, you
should see something, unless the camera is not looking in the correct
direction.
You also need some light source or it's going to be very dark.
If your object "myBox" is a regular primitive, declared like this or
similarly:
#declare myBox = box{<-1,-1,-1>,<1,1,1> rotate<1,2,3> scale<0.7,1,2>}
You should have no problem.
If your myBox object is a mesh, or composed of a collection of polygons
or any other "patch" object, you are heading for some problems.
For a mesh, take the advice of Warp, it's very good.
Just make sure that the inside_vector is not parallel to a face as it
can confuse the insideness tests.
If you use a collection of polygons, the inside_vector will not work.
Same thing apply for the bicubic_patch.
If you have an union of triangles, make it into a mesh by replacing
"union{" by "mesh{" and add an inside_vector, like "inside_vector 1".
Date: 28 Dec 2012 03:41:29
Message: <50dd5b39@news.povray.org>
How so? I don't think there are any more of a problem as eg. heightfields.
Date: 28 Jan 2013 18:05:01
Message: <web.510703889596b068c2d977c20@news.povray.org>
> > problem even with a proper inside_vector.
With a standard HF, an inside_vector of <0,-1,0> (or maybe <0,1,0>) would always
work, AFAIU. But for, say, a spherical mesh with a hole in it--i.e., not a
closed mesh-- a specially-chosen inside_vector may work *most* of the time, but
perhaps not always. I think it depends on the location of the CSG object--where
it happens to intersect the mesh.  I've run into that problem myself.
Date: 28 Jan 2013 18:34:07
Message: <51070aef@news.povray.org>
The hole would simply extend to infinity and act as an "interior" (or
"exterior" depending on which direction the inside_vector is pointing.)
It might not be the desired behavior, but it should be pretty consistent
and predictable.
