POV-Ray : Newsgroups : povray.newusers : Make part of an object transparent Server Time
16 Dec 2025 17:32:51 EST (-0500)
  Make part of an object transparent (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Make part of an object transparent
Date: 7 Nov 2012 08:29:40
Message: <509a6244$1@news.povray.org>
On 7-11-2012 14:06, Encore wrote:
> Hi guys,
> I am working on a project where I am trying to render an impossible cube. The
> final stage is to animate it but initially, I would only like to see if I can
> make a part of the cube invisible. The logic I'm following is that, every time
> part of the cube skeleton is hidden by some other part of it that's in front,
> make that part invisible so that the part on the back is still shown. this will
> give the illusion of an impossible cube. Is there any way you could suggest I
> can do this?
> Thank you in advance.
> Alex
Yes, you could use interior_texture.
Example (not tried):
box {
  -1, 1
  texture {pigment {rgbt 1}}
  interior_texture {pigment {rgb 1}}
Date: 7 Nov 2012 09:54:44
Message: <509a7634$1@news.povray.org>
On 07/11/2012 1:06 PM, Encore wrote:
> Hi guys,
> can do this?
I think that you will need to use some clever maths and use differences.
I had a quick try with that method and it might work.
Regards
Date: 7 Nov 2012 10:35:01
Message: <web.509a7f4bf48acc75eef78c9e0@news.povray.org>
> > Hi guys,
> > can do this?
> Regards
>      Stephen
The code block for my cube wireframe construction is this:
sphere{<0,0,0>,1 hollow
       texture{pigment{gradient <0,1,0>
                       color_map{[0    color Blue]
                  [0.45 color White]
                  [0.55 color White]
                  [1.0  color Blue]}
       scale 2 translate<0,-1,0>}
               finish {ambient 1 diffuse 0} }
       scale 10000}
// ground-----------------------------------------------------------
/*plane{ <0,1,0>, 0
       texture{ pigment { checker color Gray65 color Gray30}
                normal  { bumps 0.5 scale 0.05  }
                finish  { phong 0.1 }
              } // end of texture
#declare R = 0.25;   //radius of the tubes
#declare r = 0.375;  //radius of the spheres
#declare BigCube1 = merge{
sphere{<-1,-1,-1>,r}  sphere{< 1,-1,-1>,r}
sphere{<-1,-1, 1>,r}  sphere{< 1,-1, 1>,r}
sphere{<-1, 1,-1>,r}  sphere{< 1, 1,-1>,r}
sphere{<-1, 1, 1>,r}  sphere{< 1, 1, 1>,r}
cylinder {<-1,-1,-1>,< 1,-1,-1>,R}// 4 in x direction
cylinder {<-1,-1, 1>,< 1,-1, 1>,R}
cylinder {<-1, 1,-1>,< 1, 1,-1>,R}
cylinder {<-1, 1, 1>,< 1, 1, 1>,R}
cylinder {<-1,-1,-1>,<-1, 1,-1>,R}// 4 in y direction
cylinder {<-1,-1, 1>,<-1, 1, 1>,R}
cylinder {< 1,-1,-1>,< 1, 1,-1>,R}
cylinder {< 1,-1, 1>,< 1, 1, 1>,R}
cylinder {<-1,-1,-1>,<-1,-1, 1>,R}// 4 in z direction
cylinder {<-1, 1,-1>,<-1, 1, 1>,R}
cylinder {< 1,-1,-1>,< 1,-1, 1>,R}
cylinder {< 1, 1,-1>,< 1, 1, 1>,R}
       T_Gold_1B// pigment{Red filter .98}
      finish { ambient 0.2 diffuse 0.7 }
object{ BigCube1 scale 0.7
        rotate<0,60,0> translate<0,1.2,0>}
Other than that, I just can't figure out how to "scan" a piece on the back and
make the front part that's hiding it transparent. After all, I can't make a
completely automated method for this as there are several edges which should not
be hidden at all. (If you render this code with some camera settings like
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#include "textures.inc"
#include "golds.inc"
#declare Cam0 =camera {ultra_wide_angle angle 60
                       location  <0.0 , 3.0 ,-3.5>
                       look_at   <0.0 , 1.0 , 0.0>}
/*#declare Cam1 =camera {ultra_wide_angle angle 250
                       location  <0.0 , 0.5 ,-2.5>
                       look_at   <0.2 , 1.0 , 0.0>}*/
camera{Cam0}
light_source{<1500,2000,-2500> color White*0.7}
you will see exactly what I mean.)
Date: 7 Nov 2012 13:54:53
Message: <509aae7d@news.povray.org>
Sorry, I am so busy in RL that it might/will take me a while to get
round to it. :-(
Most optical illusions rely on a fixed viewpoint and I think that this
would be very difficult to create in an animation.
But it would be very worthwhile if it can be done.
One of the reasons that I think that you would need differences is that
not all the surfaces that hide the back of the object are invisible. For
instances at the corners.
If I have the time at the weekend I will look into it further.
Regards
Date: 7 Nov 2012 14:45:00
Message: <web.509ab954f48acc75eef78c9e0@news.povray.org>
> round to it. :-(
> Regards
>      Stephen
Thanks Steve I really appreciate it. But put animation aside (I'll try and deal
with this later on), how can I make a fixed part of this object invisible? I
mean a way is to make a difference as you are saying, another is to trace and
return a transparent value for a specific part of an edge. Do you have any code
for achieving this in a static state like the one I'm dealing with here?
Date: 7 Nov 2012 16:07:13
Message: <509acd81$1@news.povray.org>
Okay, I did make an attempt and the code is below. But be aware that I
use a modeller (Bishop3d) and the code is not good Pov-Ray code. (I have
to put single objects in a union to get the desired effect. Nor is it
optimised. (machine written code sucks ;-) )
This I would say is more of a general or advanced topic.
#version 3.6;
background { colour rgb <0.000,0.000,0.000> }
// referenced scene items and forced visible scene items declaration begin
#declare Default_Texture0 =
       colour rgbft <1.000,0.000,1.000,0.000,0.000>
    finish {
       ambient     rgb <1.000,1.000,1.000>
       brilliance  1.000
       crand       0.000
       diffuse     0.600
       metallic    0.000
       phong       0.000
       phong_size  40.000
       specular    0.000
       roughness   0.050
#default{ texture{ Default_Texture0 } }
#declare Shadow_Clouds_Top =
    colour rgbft <0.196,0.600,0.800,0.000,0.000>
#declare Shadow_Clouds_Bot =
    bozo
    colour_map {
       [0.000 rgbft <0.850,0.850,0.850,0.000,0.000>]
       [0.100 rgbft <0.750,0.750,0.750,0.000,0.000>]
       [0.500 rgbft <1.000,1.000,1.000,0.000,1.000>]
    rotate    <0.0,0.0,90.000>
    rotate    <180.000,0.0,0.0>
    scale     <0.200,1.200,1.200>
    rotate    <-180.000,0.000,-90.000>
    rotate    <0.000,355.000,0.000>
    translate <0.000,-0.150,-0.000>
    turbulence <0.650,0.650,0.650>
    octaves 6
    lambda 2.000
    omega 0.700
#declare Shadow_Clouds_Mid =
    bozo
    colour_map {
    octaves 6
    lambda 2.000
    omega 0.700
#declare Blue_White_Tiles1 =
    checker
          colour rgbft <1.000,1.000,1.000,0.000,0.000>
       normal {
          agate, 0.100
          agate_turb 0.500
       finish {
          ambient     rgb <0.100,0.100,0.100>
          brilliance  1.000
          crand       0.000
          diffuse     0.600
          metallic    0.000
          phong       0.000
          phong_size  40.000
          specular    0.000
          roughness   0.249
          reflection {
             rgb <0.100,0.100,0.100>, rgb <0.000,0.000,0.000>
             fresnel   0
             falloff   0.000
             exponent  1.000
             metallic  0.000
          colour rgbft <0.000,0.502,1.000,0.000,0.000>
       normal {
          agate, 0.100
          agate_turb 0.500
       finish {
          brilliance  1.000
          crand       0.000
          diffuse     0.600
          metallic    0.000
          phong       0.000
          phong_size  40.000
          specular    0.000
          roughness   0.249
          reflection {
             fresnel   0
             falloff   0.000
             exponent  1.000
             metallic  0.000
    rotate    <0.0,0.0,180.000>
    rotate    <-90.000,0.0,0.0>
    scale     <-300.000,-300.000,-1000.000>
    rotate    <90.000,0.000,-180.000>
    rotate    <0.000,-180.000,0.000>
    scale     <0.010,0.010,0.010>
#declare Maple =
material{
       #declare BISHOP3D_TEMPORARY_IDENTIFIER =
                wood
                colour_map {
                   [0.000 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.133 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [0.230 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.336 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [0.442 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.549 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [0.646 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.743 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [0.850 rgbft <0.796,0.796,0.384,0.000,0.000>]
                   [0.947 rgbft <0.706,0.518,0.235,0.000,0.000>]
                   [1.000 rgbft <0.796,0.796,0.384,0.000,0.000>]
                frequency 1.000
                phase 0.000
                ramp_wave
                noise_generator 1
                scale     <2.000,2.000,15.000>
                rotate    <0.000,0.000,-180.000>
                rotate    <0.000,0.000,90.000>
                translate <-8.000,80.000,0.000>
                turbulence <0.100,0.100,0.100>
                octaves 6
                lambda 2.000
                omega 0.500
             finish {
                ambient     rgb <0.200,0.200,0.200>
                brilliance  1.000
                crand       0.000
                diffuse     0.800
                metallic    0.000
                phong       0.000
                phong_size  40.000
                specular    0.000
                roughness   0.050
                bozo
                colour_map {
                   [0.000 rgbft <1.000,1.000,0.439,1.000,0.000>]
                   [0.008 rgbft <1.000,1.000,0.439,1.000,0.000>]
                   [0.508 rgbft <1.000,1.000,0.439,0.400,0.000>]
                   [1.000 rgbft <1.000,1.000,0.439,1.000,0.000>]
                scale     <1.500,1.500,0.375>
             finish {
                brilliance  1.000
                crand       0.000
                diffuse     0.800
                metallic    0.000
                phong       0.000
                phong_size  40.000
                specular    0.000
                roughness   0.050
       ;// the semicolon is necessary or POV-Ray will not figure out
that the declarations has ended
#declare Camera0 =
    perspective
    location <18.112,45.490,-94.622>
    up y
    right 1.333*x
    angle 33.000
    sky <-0.061,0.944,0.325>
    look_at < 0.334, 11.721, -0.011 >
}  // end Camera0
#declare Box5 =
box {
    < -0.5000000, -0.5000000, -0.5000000 >, < 0.5000000, 0.5000000,
0.5000000 >
    material{ Maple }
    scale     <12.000000,2.000000,2.000000>
}  // end Box5
// referenced scene items and forced visible scene items declaration end
union {  // Lights
    light_source {  // Shadowless_Light_Source0
       < 0.000000, 0.000000, 0.000000 >, colour rgb <1.000,1.000,1.000>
       fade_power 0.000
       fade_distance 100.000
       media_attenuation off
       media_interaction on
       shadowless
       translate <15.811000,100.000000,-200.977356>
    }  // end Shadowless_Light_Source0
    light_source {  // Light_Source0
       fade_power 0.000
       translate <-24.636320,55.859425,-195.075000>
    }  // end Light_Source0
}  // end Lights
sky_sphere {  // SkySphere1
    pigment{ Shadow_Clouds_Top }
    pigment{ Shadow_Clouds_Mid }
    pigment{ Shadow_Clouds_Bot }
}  // end SkySphere1
plane {  // Plane1
    y , 0
    texture{ Blue_White_Tiles1 }
}  // end Plane1
union {  // Centre_0
    difference {  // CSG12
       union {  // Front0
          union {  // CSG3
             box {  // Box3
0.5000000, 0.5000000 >
                material{ Maple }
             }  // end Box3
             rotate    <1.000000,0.000000,90.000000>
             translate <7.000000,0.000000,0.000000>
          }  // end CSG3
          union {  // CSG2
             box {  // Box2
                material{ Maple }
             }  // end Box2
             translate <-7.000000,0.000000,0.000000>
          }  // end CSG2
          union {  // CSG1
             box {  // Box1
                material{ Maple }
                scale     <16.000000,2.000000,2.000000>
             }  // end Box1
             translate <0.000000,7.000000,0.000000>
          }  // end CSG1
          union {  // CSG0
             box {  // Box0
                material{ Maple }
             }  // end Box0
             translate <0.000000,-7.000000,0.000000>
          }  // end CSG0
          translate <0.000000,0.000000,-7.000000>
       }  // end Front0
       union {  // CSG13
          object {  // Reference0
             Box5
             scale     <1.052000,1.300000,13.719000>
             rotate    <-34.824000,0.000000,90.000000>
             translate <5.262000,1.848000,-7.674000>
          }  // end Reference0
          rotate    <0.000000,-1.223000,0.000000>
          translate <-6.886000,0.000000,7.050000>
       }  // end CSG13
    }  // end CSG12
    union {  // Side1
       union {  // CSG10
          box {  // Box10
             material{ Maple }
          }  // end Box10
       }  // end CSG10
       union {  // CSG11
          box {  // Box11
             material{ Maple }
          }  // end Box11
       }  // end CSG11
       rotate    <90.000000,0.000000,0.000000>
    }  // end Side1
    union {  // Side0
       union {  // CSG8
          box {  // Box8
             material{ Maple }
          }  // end Box8
       }  // end CSG8
       union {  // CSG9
          box {  // Box9
             material{ Maple }
          }  // end Box9
       }  // end CSG9
    }  // end Side0
    union {  // Back0
       union {  // CSG4
          box {  // Box4
             material{ Maple }
          }  // end Box4
       }  // end CSG4
       union {  // CSG5
          object{ Box5 }
       }  // end CSG5
       union {  // CSG6
          box {  // Box6
             material{ Maple }
          }  // end Box6
       }  // end CSG6
       union {  // CSG7
          box {  // Box7
             material{ Maple }
          }  // end Box7
       }  // end CSG7
       translate <0.000000,0.000000,7.000000>
    }  // end Back0
    rotate    <0.000000,24.200000,0.000000>
    translate <0.000000,8.000000,0.000000>
}  // end Centre_0
camera{ Camera0 }
Regards
Date: 7 Nov 2012 17:00:00
Message: <web.509ad972f48acc75eef78c9e0@news.povray.org>
Wow man this looks really awesome for an initial state of what I'm trying to
achieve! A few modification needed to be made in the rotation and scale values
for the difference box (and still having a small gap there that's visible), but
other than that this looks great! Thanks a lot
Date: 7 Nov 2012 18:15:01
Message: <web.509aeb17f48acc75eef78c9e0@news.povray.org>
Date: 8 Nov 2012 14:25:29
Message: <509c0729@news.povray.org>
Encore wrote:
> Hi guys,
> The final stage is to animate it but initially, I would only like to see
> if I can make a part of the cube invisible. The logic I'm following is
> that, every time part of the cube skeleton is hidden by some other part of
> it that's in front, make that part invisible so that the part on the back
> is still shown. this will give the illusion of an impossible cube. Is
> there any way you could suggest I can do this?
> Alex
Check out p.b.images.
I still need to clean up the code before I can post it.
Ger
Date: 10 Nov 2012 02:26:12
Message: <509e0194$1@news.povray.org>
Encore wrote:
> Hi guys,
> Alex
Animation in p.b.animations
Source in p.t.scene-files
Enjoy
Ger
