POV-Ray : Newsgroups : povray.newusers : color_map Server Time
3 Jul 2025 20:51:48 EDT (-0400)
  color_map (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: color_map
Date: 21 Aug 2012 23:00:00
Message: <web.50344a32f6ca84721cd19dea0@news.povray.org>
> Am 17.08.2012 17:04, schrieb Warp:
> > What happens when you apply it to an object is that the surface of the
> > object gets colored by this universe-filling pigment at the places where
> > this surface is located. (It's a bit like the object's surface "intersects"
> > with the pigment, and you see the color of the pigment at those places.)
> Or, to take an analogy, POV-Ray's standard way of handling pigments is
> like carving an object out of a given solid material, such as a piece of
> wood.
> This is very much unlike UV-mapping (as frequently used by other 3D
> renderers), which is more akin to wrapping the object in patterned paper.
Thanks, Warp and clipka!
What I'm trying now is to get some light beams, for example, a focused Gaussian
laser beam. I first create an object of the shape of a Gaussian beam using
difference {box, torus} or sth like that. Then I try to create the light effect
using a color_map inside pigment_interior_media_density, which I learned from
web. However, i couldn't find any build-in patterns for a Gaussian beam, in
which the intensity is the highest in the center and attenuates gradually to the
edges, it has a gradient along the axis as well. Any suggestions for such a
pattern? Or maybe alternative way to achieve it?
Also, I still do not understand it quite well. According to what Warp says, it
is surface of an object that gets colored, so only those x,y,z on the surface
would be useful to create the color map? Then is it possible to use color_map
create colors inside a "hollowed" object?
Date: 22 Aug 2012 07:11:22
Message: <5034be5a$1@news.povray.org>
Am 22.08.2012 04:55, schrieb ltong:
I would suggest trying the function pattern, which (as the name
suggests) allows you to plug in arbitrary functions.
I guess for a Gaussian beam, the function will be based on the Gauss
function in some way (don't ask me about details there, I'm not familiar
with laser beams :-) Wikipedia might know something helpful). The
gradient along the axis is most likely an exponential falloff:
   // the basic functions for the beam brightness
   #declare FALLOFF  = 0.99; // just an example, toy with it
   #declare FnRadial = function(r) { /* ask Wikipedia */ }
   #declare FnAxial  = function(z) { pow(FALLOFF,z) }
   // helper function to compute radius from x,y
   #declare FnR = function(x,y) { sqrt(x*x+y*y) }
   // the resulting 3D function
   #declare Fn = function(x,y,z) { FnRadial(FnR(x,y)) * FnAxial(z) }
What Warp said applies to the pigment of opqaue objects, but you're
working with media now, where you'll get the full 3D structure.
Date: 22 Aug 2012 23:25:00
Message: <web.5035a239f6ca84721cd19dea0@news.povray.org>
Great, now I can get something pretty close :)
It is Fn(x,z,y) that I used for color_map, btw.
Maybe the last question: in a user-defined pattern, does the output variable (Fn
in this example) give value_n [0,1] for color_map? I experimented with it a bit,
got somewhat unexpected results...
   #declare FALLOFF  = 1; // just an example, toy with it
   #declare a = 0.35;
   #declare b = 0;
   #declare c = 1;
   #declare FnRadial = function(r) {a*exp(-(r-b)*(r-b)/2/c/c)}
object {gauss
  hollow
  pigment { color rgbf<1, 1, 1, 1> }
  interior {
    media {
      emission    color rgb < 1.0, 0.0, 0.0>*5
      density{ function {Fn(x,z,y)}
                color_map {
                  [0 color rgb <0.0, 0.0, 0.0>]
                  [0.15 color rgb <0.1, 0.05, 0.0>]
                  [0.32 color rgb <0.3, 0.05, 0.0>]
                  [0.42 color rgb <0.5, 0.05, 0.0>]
                  [0.52 color rgb <0.7, 0.05, 0.0>]
                  [0.67 color rgb <0.9, 0.05, 0.0>]
                  [1.0 color rgb <1.0, 0.05, 0.0>]
             } // end density
     }//end media
    } //end interior
   scale <1,1.5,1>*0.5
   translate<0,2.0,0.0>
Date: 23 Aug 2012 21:03:07
Message: <5036d2cb$1@news.povray.org>
>     #declare a = 0.35;
>     #declare b = 0;
>     #declare c = 1;
> object {gauss
>    hollow
>    interior {
>      media {
>                  color_map {
>               } // end density
>       }//end media
>      } //end interior
>     scale <1,1.5,1>*0.5
Your FnAxial function have a value of zero along the Z axis that climb
to 1 at a radius of 1. It's similar to the wood pattern.
Make sure that your Gauss object extend along the Z axis.
As your map stand now, it's black on the axis and return rgb<1,0.05,0>
on the edge.
To get a bright spot in the center fading to black at the edge, you
should invert the colours of your map.
As your emission colour is pure red, the green component of your map
have absolutely no effect. Mabe it would be beter to use emission rgb 5.
The final colour is the product of the value of emission and the entry
of the color_map.
Another alternative don't use media nor any function. You can use a
plain light_source with the cylindrical attribute.
You now control the bright spot using "radius", the overall width with
"falloff" and the curve with "tightness"
radius and falloff are expressed in degree.
This would give you a nice smooth illumination:
light_source{10*y rgb<5,0,0> cylindrical
	point_at 0
	radius 0 //no notable "hot spot"
	falloff 1 // total width angle
	tightness 4 // gives a nice curve
// range from 1 to 100
The actual diameter og the beam is dictated by falloff and the lenght of
the location to point_at vector.
Now, you can use some scattering media to make the beam visible if you
want or need.
Date: 24 Aug 2012 02:00:11
Message: <web.50371771f6ca84721cd19dea0@news.povray.org>
> >     #declare a = 0.35;
> >     #declare b = 0;
> >     #declare c = 1;
> > object {gauss
> >    hollow
> >    interior {
> >      media {
> >                  color_map {
> >               } // end density
> >       }//end media
> >      } //end interior
> >     scale <1,1.5,1>*0.5
> on the edge.
Thanks! Seems I misunderstood the function pow. Anyway, it produces somehow
acceptable results. I reversed the colormap, but do not see a dramatic change,
so still wondering how value_n is computed here... Guess it's FnRadial*FnAxial?
> of the color_map.
Thanks! A cylindrical light_source is a good idea, but it doesn't have a
"focused" effect - the smallest in the beam waist and expands along z.
>  point_at 0
> want or need.
> Alain
Date: 28 Aug 2012 01:35:07
Message: <web.503c57dff6ca84721cd19dea0@news.povray.org>
ok, after some experimentation, the result looks much better. seems value_n is
defined as 1-min(1,Fn). Don't know how to attach a pic here, below follows the
code.
   #declare FALLOFF  = 1.3; // just an example, toy with it
   #declare a = 0.7;
   #declare b = 0;
   #declare c = 0.44;
   #declare FnAxial  = function(z) {1/(1+(FALLOFF*z*FALLOFF*z))}
object {gauss
  hollow
  pigment { color rgbt<1, 1, 1, 1> }
  interior {
    media {
               color_map {
                  [1.0 color rgb <1.0, 0.0, 0.0>*1.2]
             } // end density
     }//end of media
    } //end interior
   scale <1,1,1>*1.5
} //end object
Date: 12 Sep 2012 11:35:00
Message: <web.5050ab67f6ca84724538451a0@news.povray.org>
> code.
>    #declare a = 0.7;
>    #declare b = 0;
>    #declare c = 0.44;
> object {gauss
>   hollow
>   interior {
>     media {
>                color_map {
>              } // end density
>      }//end of media
>     } //end interior
>    scale <1,1,1>*1.5
> } //end object
Hey, this is a great example! I have been trying to do this with Pov-Ray for a
while. I tried a direct copy and paste of this code into Pov-Ray but got (on
line "object {gauss"
Parse Error: Expected 'object', undeclared identifier 'gauss' found instead
I did a quick search for gauss and it doesn't seem to be an internal function.
Was this just a helper file or was there more to this example that I am missing?
I am relatively inexperienced...
Thanks in advance!!!!
Date: 12 Sep 2012 16:25:34
Message: <5050efbe$1@news.povray.org>
>> code.
>>     #declare a = 0.7;
>>     #declare b = 0;
>>     #declare c = 0.44;
>> object {gauss
>>    hollow
>>    interior {
>>      media {
>>                 color_map {
>>               } // end density
>>       }//end of media
>>      } //end interior
>>     scale <1,1,1>*1.5
>> } //end object
This is a snippet from a larger scene.
Here, "gauss" is an object previously defined by the author in a
#declare directive.
It /could/ look like:
#declare gauss= cylinder{<0,0,10><0,0,-10>,2}
Beter writing:
#declare Gauss= cylinder{<0,0,10><0,0,-10>,2}
The primitive used can be any ot the available ones, but should be built
around the origin. In this case, it also should be longer along the Z axis.
Anyway, it's always beter to always use at least one UPER case leter in
any user defined identifier, and leave all lower case ones for the
reserved words.
There have been cases where scenes got broken by not following that
guide line and used some variable that got used as key word in a later
version.
Date: 14 Sep 2012 10:10:00
Message: <web.50533a32f6ca84724538451a0@news.povray.org>
> code.
>    #declare a = 0.7;
>    #declare b = 0;
>    #declare c = 0.44;
> object {gauss
>   hollow
>   interior {
>     media {
>                color_map {
>              } // end density
>      }//end of media
>     } //end interior
>    scale <1,1,1>*1.5
> } //end object
This is a really great example! I tried just a simple copy-paste into POV-Ray
and I keep getting the error
 on the "object {gauss" line. I did a quick search to see if 'gauss' was an
internal POV-Ray command but it appears that it isn't. Is this the full example?
Are there additional dependencies missing? I'm a little new at POV-Ray so please
excuse my inability to troubleshoot this for myself.
Thanks for your time!
Date: 14 Sep 2012 10:15:01
Message: <web.50533b6af6ca84724538451a0@news.povray.org>
> > code.
> >    #declare a = 0.7;
> >    #declare b = 0;
> >    #declare c = 0.44;
> > object {gauss
> >   hollow
> >   interior {
> >     media {
> >                color_map {
> >              } // end density
> >      }//end of media
> >     } //end interior
> >    scale <1,1,1>*1.5
> > } //end object
Sorry for the double post. Thank you for answering Alain, that worked perfectly.
