POV-Ray : Newsgroups : povray.newusers : installing POV-Ray Server Time
16 Dec 2025 08:11:29 EST (-0500)
  installing POV-Ray (Message 1 to 2 of 2)
Subject: installing POV-Ray
Date: 17 May 2012 07:15:01
Message: <web.4fb4dd93bf4b435ce069fe00@news.povray.org>
I am trying to install POV-Ray for Linux x86.
My OS is Ubuntu 12.04 x86_64.
I have done step by step the instructions on POV-Ray download site and just at
root to finish installation I get the message "permission denied".
Is it due to some kind of difference  between x86 and x86_64?
What other reason must it due?
Regards
Subject: Re: installing POV-Ray
Date: 17 May 2012 09:48:08
Message: <4fb50198$1@news.povray.org>
Le 17/05/2012 13:14, EscRiMer nous fit lire :
> Regards
Which version of povray are you trying to install ?
If it is the 3.6 in Linux Binary format (povlinux-3.6.tgz),
you might need to install the ia32-libs (and ia32-libs-multiarch:i386)
Usual installation on Linux is best done via sources.
And x86 is 32 bits, x86_64 is 64 bits... the instruction set is not the
same, nor are the system libraries (hence the need for ia32-libs)
Dump/copy-paste of command line and replies might have helped.
