POV-Ray : Newsgroups : povray.newusers : Unable to change the resolution of the rendered image Server Time
27 Jul 2024 22:31:34 EDT (-0400)
  Unable to change the resolution of the rendered image (Message 1 to 10 of 10)
Subject: Unable to change the resolution of the rendered image
Date: 8 Mar 2012 10:20:00
Message: <web.4f58ce00d4c2e65b771f88b0@news.povray.org>
When I choose another resolution from the menu under the Windows version of the
program, it doesn't take affect, the program still renderes in the 512x384 pixel
resolution.
What can be the problem?
Subject: Re: Unable to change the resolution of the rendered image
Date: 8 Mar 2012 10:33:00
Message: <4f58d12c@news.povray.org>
> resolution.
Do you use an ini file to start your render or are there any switches in
the command box?
Regards
Date: 8 Mar 2012 10:33:43
Message: <4f58d157$1@news.povray.org>
Am 08.03.2012 16:19, schrieb Silverlight2009:
> resolution.
You might have explicitly specified "+w512 +h384" in the edit box right
next to the resolution dropdown?
You might have explicitly specified a particular resolution via an INI file?
Date: 8 Mar 2012 10:45:01
Message: <web.4f58d3613f9dc1b2b771f88b0@news.povray.org>
> > resolution.
> the command box?
> Regards
>      Stephen
No, I use the "Run" button to start rendering, and the command box is empty.
Message: <web.4f58d3e43f9dc1b2b771f88b0@news.povray.org>
> > resolution.
Where should I search fot that INI files?
Date: 8 Mar 2012 11:00:30
Message: <4f58d79e@news.povray.org>
If you look in the message window of PovRay after a render you should
see something like:
Preset INI file is
'C:\Users\Stephen\Documents\POV-Ray\v3.7\ini\quickres.ini', section is
'[800x600, AA 0.3]'.
Preset source file is 'F:\Graphics\B3D
Data\Scenes\SSLT\RC4\Lucy\Lucy12_c2_.pov'.
Rendering with 8 threads.
Image Output Options
   Image resolution.....800 by 600 (rows 1 to 600, columns 1 to 800).
   Output file..........F:\Graphics\B3D
Data\Scenes\SSLT\RC4\Lucy\Lucy12_c2_.png, 24 bpp PNG
Does that tie in with what you get?
BTW When you want to see what is reported. It is often better to clear
the messages just before you start to render.
Regards
Date: 11 Mar 2012 14:08:37
Message: <4f5cea25@news.povray.org>
>>> resolution.
Usualy, in the same folder as the .pov file, and just next to it.
You may be trying to render the ini file itself.
What's the complete name of the file you try to render? If it ends with
.ini, then you are rendering the ini file that, in turn, instruct
POV-Ray to render a specific scene file (*.pov) using some specific
parameters, like the resolution. Any resolution parameters present in
the ini file will override your chosen resolution.
If you see something like this in the editor's window:
Input_File_Name=...*pov
Width=512
Height=384
You are rendering the ini file.
Date: 4 Sep 2012 11:25:01
Message: <web.50461c1c3f9dc1b2ccc37f890@news.povray.org>
I'm having a similar problem. I use a program called MolPOV to generate POV
files for rendering (Windows version). This works OK, but the resolution is
poor. When I use the drop down box to alter the resolution and re-render,
nothing changes. The message output always says image resoltuion 400 x 300, no
matter what resolution I've selected. What am I doing wrong?
MJP.
> >>> resolution.
> Width=512
> Height=384
> Alain
Date: 4 Sep 2012 16:50:09
Message: <50466981$1@news.povray.org>
Does MolPOV generate an INI file as well as a POV file?
You might find that the resolution is set there. I would imagine that
there is a setting in MolPOV to change the resolution and the AA etc.
Regards
Date: 5 Sep 2012 16:55:15
Message: <5047bc33$1@news.povray.org>
> MJP.
OK, 400x300 is correct for a quick preview, not for the final render.
Look at the *.ini file associated with your scene.
Does it contain any resolution setting? If that's the case, it will
unconditionaly override the resolution you set from the resolutions drop
list.
You only need to edit the ini file in one or another way:
1 - Change the resolution to the one you want. Change the Width and
Height values to suit you.
2 - Comment out the resolution in the ini file.
Look foor lines like this:
Input_File_Name=scene_name.pov
Width=400
Height=300
can become:
;Width=400
;Height=300
(allow you to chose any resolution you want at render time)
or
Width=1600
Height=1200
+a0.1
(unconditionaly set the resolution to 1600 by 1200 with antialiasong ON
with a threshold of 0.1)
The second solution will allow you to sellect any resolution you want.
You can also render the *.POV file that is refered to in the ini file.
Open the POV file and render that file, not the ini.
You may also do as Stephen said and look to see if MolPOV have any
resolution setting and change that setting.
