POV-Ray : Newsgroups : povray.newusers : Setting a scene inside a box Server Time
10 Aug 2025 09:34:27 EDT (-0400)
  Setting a scene inside a box (Message 1 to 3 of 3)
Subject: Setting a scene inside a box
Date: 16 Feb 2012 04:05:01
Message: <web.4f3cc5b44c180f1bccae74d00@news.povray.org>
I would like to set a scene inside a box, such that its faces will consist of
grid lines and will be transparent. That is, if the camera is INSIDE the box, it
will see something which is outside and vice versa.
This is the best I could get:
#include "textures.inc"
 perspective
 location < 4.0, 4.0, 12>
 right x * 1
 up y * 3/4
 angle 60
 look_at < 0.0, 0.0, 0.0>
light_source {
 < 0.0, 100, 100>
 rgb <0.999962, 1.000000, 1.000000>
box {
 < -2, -2, -2>, <2,2,2>
// no_shadow
 hollow on
// pigment {
//  rgb <0.000000, 0.202852, 1.000000>
        Tiles_Ptrn()
        color_map{
         [0.02 color rgb <1,1,1>]   // white stanchions
  [0.04 color rgbt <0,0,0,1>]  // black spaces
        rotate z*90  // rotates the pattern onto the "upper side" of the plane
sphere {
 <0.0, 0.0, 0.0>, 0.5
 material {
   normal {
    brick 0.5 //amount
   finish {
    diffuse 0.6
    brilliance 1.0
How can I finish it?
Subject: Re: Setting a scene inside a box
Date: 16 Feb 2012 07:35:01
Message: <web.4f3cf7a5bf141a6dccae74d00@news.povray.org>
This is what I managed to produce:
Bounding box's corners
#local xmin=-5;
#local ymin=-5;
#local zmin=0;
#local xmax=8;
#local ymax=9.2;
#local zmax=2*pi;
zMax grid
object{
 plane { <0,0,1>,zmax
   Tiles_Ptrn()
   color_map{
 no_shadow
 clipped_by{
  box{
   <xmin,ymin,zmin>, <xmax,ymax,zmax>
zMin grid
= floor
object{
 plane { <0,0,1>,zmin
   // Pattern color
   Tiles_Ptrn()
   color_map{
    [0.02 color rgb <0,0,0>]   // white stanchions
    [0.04 color rgbt <0,0.51,1,0.5>]  // black spaces
// Fixed Color
//   color rgbt<0,0.51,1,0.5>
//   rotate z*90  // rotates the pattern onto the "upper side" of the plane
 no_shadow
Clipping here had to be removed in order to avoid some probelm with color
rendering
// clipped_by{
//  box{
//   <xmin,ymin,zmin>,<xmax,ymax,zmax>
object{
 plane { <1,0,0>,xmax
   Tiles_Ptrn()
   color_map{
    [0.04 color rgbt <0,0,0>]  // black spaces
   rotate y*90  // rotates the pattern onto the "upper side" of the plane
 no_shadow
 clipped_by{
  box{
object{
 plane { <1,0,0>,xmin
   Tiles_Ptrn()
   color_map{
 no_shadow
 clipped_by{
  box{
object{
 plane { <0,1,0>,ymax
   Tiles_Ptrn()
   color_map{
   rotate x*90  // rotates the pattern onto the "upper side" of the plane
 no_shadow
 clipped_by{
  box{
object{
 plane { <0,1,0>,-5
   Tiles_Ptrn()
   color_map{
 no_shadow
 clipped_by{
  box{
It is not perfect, and slows down the rendering... but this is what I have. Can
anyone improve it?
Date: 17 Feb 2012 12:50:17
Message: <4f3e9359$1@news.povray.org>
Le 16/02/2012 10:00, Dror Atariah nous fit lire :
Drop the idea of painting a real box which does not exit.
Use cylinder{} objects for your lines around the virtual cube.
At worst, if you really want flat grid line, you can put the whole
collection of cylinder into a an union{} and apply a
difference/intersection{} of that union with a smaller and a bigger box
(one of them being inversed)
Have a look at #while/#for (if using povray 3.7RC3 or 4) to loop a bit.
