Dear all,
I am very new to povray, running it in a x86_64 machine(with binary file) but I
also have glibc for i686
rpm -qa|grep glibc-2
glibc-2.14.90-24.fc16.4.i686
glibc-2.14.90-24.fc16.4.x86_64
I tried to run the first example from
http://library.thinkquest.org/3285/tutorial/simple.html (a direct copy paste of
"The first example scene" there)and the output shows:
$ povray 1.pov
povray: cannot open the user configuration file
/home/rudra/.povray/3.6/povray.conf: No such file or directory
Persistence of Vision(tm) Ray Tracer Version 3.6.1 (g++ 3.4.1 @
i686-pc-linux-gnu)
This is an official version prepared by the POV-Ray Team. See the
documentation on how to contact the authors or visit us on the
internet at http://www.povray.org/.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
Primary POV-Ray 3.5/3.6 Developers: (Alphabetically)
Chris Cason Thorsten Froehlich Nathan Kopp Ron Parker
Contributing Authors: (Alphabetically)
Steve Anger Eric Barish Dieter Bayer Steve A. Bennett
David K. Buck Nicolas Calimet Aaron A. Collins Chris Dailey
Steve Demlow Andreas Dilger Alexander Enzmann Dan Farmer
Mark Gordon Christoph Hormann Mike Hough Chris Huff
Kari Kivisalo Lutz Kretzschmar Jochen Lippert Pascal Massimino
Jim McElhiney Douglas Muir Juha Nieminen Bill Pulver
Eduard Schwan Wlodzimierz Skiba Robert Skinner Yvo Smellenbergh
Zsolt Szalavari Scott Taylor Massimo Valentini Timothy Wegner
Drew Wells Chris Young
Other contributors are listed in the documentation.
Support libraries used by POV-Ray:
ZLib 1.2.1, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
LibPNG 1.2.5, Copyright 1998-2002 Glenn Randers-Pehrson
LibJPEG 6b, Copyright 1998 Thomas G. Lane
LibTIFF 3.6.1, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Redirecting Options
All Streams to console..........On
Debug Stream to console.........On
Fatal Stream to console.........On
Render Stream to console........On
Statistics Stream to console....On
Warning Stream to console.......On
Parsing Options
Input file: 1.pov (compatible to version 3.61)
Remove bounds........On
Split unions.........Off
Library paths:
/usr/local/share/povray-3.6
/usr/local/share/povray-3.6/ini
/usr/local/share/povray-3.6/include
Output Options
Image resolution 320 by 240 (rows 1 to 240, columns 1 to 320).
Output file: /home/rudra/povray/1.png, 24 bpp PNG
Graphic display......On (gamma: 2.2)
Mosaic preview.......Off
CPU usage histogram..Off
Continued trace......Off
Tracing Options
Quality: 9
Bounding boxes.......On Bounding threshold: 3
Light Buffer.........On
Vista Buffer.........On Draw Vista Buffer....Off
Antialiasing.........Off
Clock value: 0.000 (Animation off)
0:00:00 Parsing
0:00:00 Creating bounding slabs 0K tokens
Scene Statistics
Finite objects: 1
Infinite objects: 0
Light sources: 1
Total: 2
0:00:00 Displaying
Using 24 bit TrueColor visual
Using default window background
Mapping background image
X error: BadMatch
X error: BadGC
0:00:00 Rendering line 1 of 240
X error: BadMatch
X error: BadGC
0:00:00 Done Tracing
Render Statistics
Image Resolution 320 x 240
Pixels: 76800 Samples: 76800 Smpls/Pxl: 1.00
Rays: 76800 Saved: 0 Max Level: 1/5
Ray->Shape Intersection Tests Succeeded Percentage
Sphere 76902 43671 56.79
Calls to Noise: 0 Calls to DNoise: 10
Shadow Ray Tests: 102 Succeeded: 0
Smallest Alloc: 9 bytes
Largest Alloc: 307208 bytes
Peak memory used: 463437 bytes
Total Scene Processing Times
Parse Time: 0 hours 0 minutes 0 seconds (0 seconds)
Photon Time: 0 hours 0 minutes 0 seconds (0 seconds)
Render Time: 0 hours 0 minutes 0 seconds (0 seconds)
Total Time: 0 hours 0 minutes 0 seconds (0 seconds)
The problem is, as it tells, no .povray directory is generated. so no question
of povray.conf. my 1.png is just a dark red circle.
please suggest where I went wrong.
Le 20/01/2012 17:56, bnrj.rudra nous fit lire :
> Dear all,
You might enjoy better experience by compiling it locally, as you seems
to be using linux.
> $ povray 1.pov
Not a problem, just a warning: you do not have a personal configuration,
so you will be using the system one instead.
(would you have one, the system one would be overloaded with your
setting when used by you).
You can create the missing directories & files if you want:
$ mkdir -p $HOME/.povray/3.6
$ touch $HOME/.povray/3.6/povray.conf
> Parsing Options
> Library paths:
> Output Options
> X error: BadMatch
> X error: BadGC
You need the 32 bit libraries for X11... in shared version.
$ type povray
$ ldd ......./povray
might give you the list of needed libraries.
> X error: BadMatch
> X error: BadGC
Nothing wrong, the sphere is red and dark, at the center of the image,
it looks like a disc. (a circle is the boundary of a disc... )
Thanks for your reply! I am slowly getting the points in povray.
> > Dear all,
> to be using linux.
> > $ povray 1.pov
> > Parsing Options
> > Library paths:
> > Output Options
> > X error: BadMatch
> > X error: BadGC
> $ type povray
Thank you for this explanation, but maybe someone could elaborate a bit more on
the last point? I'm having exactly the same problem as the original poster,
namely the error:
X error: BadMatch
X error: BadGC
I tried finding the libraries povray depends on, as explained by the previous
poster:
frank@werk:~/downloads/povray-3.6$ ldd /usr/local/bin/povray,
but this failed:
not a dynamically executable file
Does anyone know how to solve this? By the way, I'm running Ubuntu 12.10.
