POV-Ray : Newsgroups : povray.newusers : how to render a transparent cube Server Time
22 Feb 2025 03:53:56 EST (-0500)
  how to render a transparent cube (Message 1 to 8 of 8)
Subject: how to render a transparent cube
Date: 27 Dec 2011 05:30:01
Message: <web.4ef99d082d2b0fb7e9c69f4b0@news.povray.org>
I am trying to render jello. What I get is
http://s18.postimage.org/86nwkrp4p/jello.png
There are crossing lines on the surface. I really want to get something like
http://s7.postimage.org/g4a0ahgrf/Untitled.png
I guess there's something wrong in my refraction? Could anyone help me?
Subject: Re: how to render a transparent cube
Date: 27 Dec 2011 06:00:50
Message: <4ef9a562$1@news.povray.org>
Without the code it is just guesswork but are you using union instead of
merge?
See the help 2.2.3.5 CSG Merge
Regards
Date: 27 Dec 2011 17:58:28
Message: <4efa4d94@news.povray.org>
Your image looks mostly correct as it is. The lines you see are due to
total internal reflection. They line up perfectly because you use a
simple box object, while your reference have faces caving in.
You can acheive that using a difference starting with a box and removing
bits of the faces with large spheres, with a mesh object or some other ways.
jello is mostly water. A correct ior should be between 1.33 and 1.34.
It's colouration is in the mass, not at the surface. You should use
fade_color Colour fade_distance Lenght fade_power 1 (or 1001).
The sample image seems to be using photons. Please read about it in the
ducumentation. You need a photons{} block in the global_settings and
another for the object itself.
The code for your jello should help find any eventual problem.
Date: 27 Dec 2011 19:55:01
Message: <web.4efa67f3f1937dc6e9c69f4b0@news.povray.org>
Thank you for the reply!
Here is my code, I have modified it but the result still looks weird.
#include "shapes.inc"
#include "textures.inc"
#include "glass.inc"
global_settings {
    assumed_gamma 2.2
    max_trace_level 5
    photons {
        count 20000
#declare LIGHT_FADING_DIST = 20.0;
background { Gray50 }
light_source {
    < 0, 4,  0> color Gray60
    fade_distance LIGHT_FADING_DIST fade_power 2
    photons {
        reflection on
        refraction on
light_source {
    < 10, 4,  10> color Gray60
    photons {
        reflection on
        refraction on
light_source {
    < -10, 4, 10> color Gray60
    photons {
        reflection on
        refraction on
light_source {
    < 0, 0, -20> color Gray80
    photons {
        reflection on
        refraction on
plane {
    y, -3
    pigment { color Gray50 }
    finish { reflection 0.35}
    location  <2, 1.5, -2>
    look_at   <0,0,  0>
#declare jello=
difference {
    box { <-0.5,-0.5,-0.5>, <0.5,0.5,0.5> }
    union {
        sphere {<5.47349,0,0>, 5.02349}
        sphere {<-5.47349,0,0>, 5.02349}
        sphere {<0,5.47349,0>, 5.02349}
        sphere {<0,-5.47349,0>, 5.02349}
        sphere {<0,0,5.47349>, 5.02349}
        sphere {<0,0,-5.47349>, 5.02349}
    //rotate y*45
    rotate x*45
        pigment { Red filter .98 }
        finish {
            phong 1 phong_size 30
            reflection 0.01
    interior {
        ior 1.34
        fade_color Red
        fade_distance 10
        fade_power 1001
object {
    jello
    photons {
        target
        reflection on
        refraction on
> Alain
Date: 27 Dec 2011 19:55:02
Message: <web.4efa684ff1937dc6e9c69f4b0@news.povray.org>
I'm now using a difference of a box and [4 spheres]. Please see my code. I still
cannot get the refraction effect like my referred image
> merge?
> Regards
>      Stephen
Date: 29 Dec 2011 23:53:58
Message: <4efd43e6@news.povray.org>
I added this as I use version 3.7:
#version 3.7;
MUST be the first statement.
> global_settings {
>      assumed_gamma 2.2
You should use assumed_gamma 1 to get acurate results.
Set file_gamma to 2.2 OR srgb (if using version 3.7) in povray.ini
>      max_trace_level 5
You realy need a larger value.
I used this:
max_trace_level 30
adc_bailout 0.01
and got trace level of 27/30.
Some of the lines you see are caused by reatching max_trace_level to soon.
>      photons {
>          count 20000
OK
Excessively long. I'd use something like 1 and increase the light's
intensity as needed.
Idealy, for a point light, it should be something like 1e-5 and a light
intensity in the millions. A value of 1 is a good compromise.
For an area_light, it should be the sixe of the light.
Why do you use 4 lights? Especialy in the testing phase, one light
should be enough.
I tested with this one replacing your first and commented out the other 3:
#declare LIGHT_FADING_DIST = 1;
light_source {
     < 0, 10,  -3>  rgb 45
> light_source {
>      photons {
>          reflection on
>          refraction on
This photons block is not needed as you use the default one for any
light_source.
> light_source {
>      photons {
>          reflection on
>          refraction on
> light_source {
>      photons {
>          reflection on
>          refraction on
> light_source {
>      photons {
>          reflection on
>          refraction on
> plane {
>      y, -3
Personaly, I prefer to use variable reflection for anything that is not
a mirror.
> camera {
>      location<2, 1.5, -2>
>      look_at<0,0,  0>
> #declare jello=
> difference {
>      box {<-0.5,-0.5,-0.5>,<0.5,0.5,0.5>  }
>      union {
>      //rotate y*45
>      rotate x*45
>      texture {
Would be beter to use pigment{rgbt 1}
pigment{rgbt 0.98} is also acceptable.
The pigment in in the mass, not at the surface.
>          finish {
>              reflection 0.01
That reflection is totaly unrealistic. You should use variable
reflection with the fresnel option:
reflection{0.01, 0.9 fresnel}
>      interior {
>          ior 1.34
>          fade_color Red
>          fade_distance 10
Shorten this to about 0.2 to 0.4
I got good looking result using 0.33
fade_distance is the key parameter to controll the intensity of fading
interior.
>          fade_power 1001
> object {
>      jello
>      photons {
>          target
>          reflection on
>          refraction on
Your original render used an area_light. Probably the one from the
include menu. It's array, at 4 by 4, is realy to sparce, and with the
use of jitter, lead to some very grainy penumbrae. Without jitter, you
get strong banding.
You should use a much higher density and add adaptive.
I commonly use this:
area_light x,z 17,17 adaptive 0 //for testing, may need adaptive 1 or 2.
I often also use circular orient to simulate a spherical light_source.
This area_light can be about as fast as the one from the include menu.
Date: 30 Dec 2011 03:30:00
Message: <web.4efd75cef1937dc6e9c69f4b0@news.povray.org>
Thank you very much!
I am using v3.6. I changed the code according to your advice. The new rendering
result has some strange white light regions on the jello surface. How can I get
rid of that? (I can see it does not appear when I change ior to 1.0).
Also, if you could please look at the sample image
(http://s7.postimage.org/g4a0ahgrf/Untitled.png) again, you can see very shiny
effect inside it. I'm also wondering how to get a photon mapping like that? I
can tell it is not a result of scattering media.
Thanks again!
Current code:
#version 3.6;
global_settings {
    assumed_gamma 1
    max_trace_level 30
    adc_bailout 0.01
    photons {
        count 20000
light_source {
     < 0, 10,  -3>  rgb 45
     area_light x,z 17,17 adaptive 2
     jitter
     circular orient
plane {
    y, -3
    location  <0, 1., -2>
    look_at   <0,0,  0>
#declare jello=
difference {
    union {
   rotate y*25
        pigment{rgbt 1}
        finish {
    interior {
        ior 1.4
        fade_color Red
        fade_distance 0.33
        fade_power 1001
object {
    jello
    photons {
        target
        reflection on
        refraction on
> #version 3.7;
> > global_settings {
> >      assumed_gamma 2.2
> >      max_trace_level 5
> I used this:
> max_trace_level 30
> adc_bailout 0.01
> >      photons {
> >          count 20000
> OK
> should be enough.
> light_source {
>      < 0, 10,  -3>  rgb 45
> > light_source {
> >      photons {
> >          reflection on
> >          refraction on
> light_source.
> > light_source {
> >      photons {
> >          reflection on
> >          refraction on
> > light_source {
> >      photons {
> >          reflection on
> >          refraction on
> > light_source {
> >      photons {
> >          reflection on
> >          refraction on
> > plane {
> >      y, -3
> a mirror.
> > camera {
> >      look_at<0,0,  0>
> > #declare jello=
> > difference {
> >      union {
> >      //rotate y*45
> >      rotate x*45
> >      texture {
> >          finish {
> >              reflection 0.01
> >      interior {
> >          ior 1.34
> >          fade_color Red
> >          fade_distance 10
> interior.
> >          fade_power 1001
> > object {
> >      jello
> >      photons {
> >          target
> >          reflection on
> >          refraction on
> get strong banding.
> Alain
Date: 30 Dec 2011 21:51:36
Message: <4efe78b8@news.povray.org>
> Thanks again!
You can reduce the transparency value of the pigment.
Example:
pigment{rgbt<1,1,1,0.7>}
You can try reducing the maximum reflection value.
Example:
reflection{0.01, 0.7 fresnel}
It's possible that the reference image use an unrealistic ior value.
It's also possible that it contains some emissive media.
It may use intside_texture with a larger reflection value and less
transmition.
It may have been post processed.
