POV-Ray : Newsgroups : povray.newusers : Reflected light doesn't light surface Server Time
22 Feb 2025 11:41:43 EST (-0500)
  Reflected light doesn't light surface (Message 1 to 3 of 3)
Subject: Reflected light doesn't light surface
Date: 21 Oct 2011 12:30:00
Message: <web.4ea19ce9929ace0fdf323a20@news.povray.org>
I have a light source in a hollow cylinder which throws a circle on a sheet
placed above it. The cylinder prevents light to fall directly on the Y plane.
The sheet is reflective, so I would expect reflected light on the plane around
the light source. But the plane remains dark. Any idea how to fix it? I'm trying
to emulate a white fabric with the sheet: partly reflective and partly
transparent.
..pov file and rendered image can be found on http://nenya1.net/temp/20111021/
TIA
Steven
Subject: Re: Reflected light doesn't light surface
Date: 21 Oct 2011 12:36:58
Message: <4ea19faa@news.povray.org>
  It depends on whether you want diffuse reflection or mirror reflection.
In the former case you need this:
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.7#Radiosity
  In the latter case you need this:
http://wiki.povray.org/content/Documentation:Reference_Section_6.1#Photons
Date: 21 Oct 2011 13:00:00
Message: <web.4ea1a4cb71de4adcdf323a20@news.povray.org>
Thanks Warp, solved with photons.
