POV-Ray : Newsgroups : povray.newusers : Random Access inside a file. Server Time
14 Dec 2025 16:50:52 EST (-0500)
  Random Access inside a file. (Message 1 to 3 of 3)
Subject: Random Access inside a file.
Date: 15 Aug 2011 18:15:01
Message: <web.4e4999a27447280bd0dbfa270@news.povray.org>
Hi all,
I am trying to read a frame_data_file which has data of frames to be animated.
This file has the following data
"Frame",<framenumber>,<number of bytes of data realted to this frame>
<framedata>
"Frame",<framenumber>,<number of bytes of data related to this frame>
<framedata>
I am reading this from a scene file(.pov) to generate a each frame. To generate
each image in the scene, I use the "clock" to get the frame I am generating.
Then I want to jump through my frame_data_file to that particular frame parse
the data pertinent to that. I am not able to find a way to randomly jump through
the frame_data_file using pov-ray file handling capabilities.
Is there some way I can achieve my functionality? The only other way I see is to
generate separate file for each frame which would be a lot.
Any help with this would be great.
Thanks,
pH
Subject: Re: Random Access inside a file.
Date: 16 Aug 2011 12:59:38
Message: <4e4aa1fa$1@news.povray.org>
> Hi all,
> <framedata>
> <framedata>
> Thanks,
> pH
There is no true random access of files.
You should use the "frame_number" internal variable.
Using that value, you sequentialy read through your file untill you find
the coresponding <framenumber> entry, discarting unneeded frame
informations. This will cause the parsing of your scene to get longer
for later frames. For that reason, you should probably make some data
files, maybe one per 100 frames.
Beter yet, reconstruct your data file as an .inc file and use
#switch(frame_number) #case(Value) <frame_specific_code> #break ...
#else ... #end
Using one #case(..)... #break statement per frame.
For your animation, if the first frame have less than 3 objects, it's
advisable to create enough dummy objects to get about 4 objects uniquely
for that frame. They can be zero radius spheres, of any object placed
behind the camera, of having no_image no_reflection and no_shadow, or
pigment{ rgbt 1} to make them invisible.
This will ensure that the bounding is done for all frames. There is no
bounding done if there is less than 3 objects in the scene, and, in an
animation, the flag is only set during the first frame.
Date: 16 Aug 2011 15:15:01
Message: <web.4e4ac0a1874b3d7d2fab58380@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Hi all,
> > <framedata>
> > <framedata>
> > Thanks,
> > pH
> #else ... #end
> Alain
Thanks Alian. I will look at the .inc option if it helps.
