POV-Ray : Newsgroups : povray.newusers : Coordinates after rotation? Server Time
28 Jun 2024 22:58:44 EDT (-0400)
  Coordinates after rotation? (Message 1 to 5 of 5)
Subject: Coordinates after rotation?
Date: 28 Jun 2011 15:20:01
Message: <web.4e0a29031deb8c0ebe377b680@news.povray.org>
I am having some difficulty connecting a few cylinders which I'm trying to make
a 3D pentagram knot with. The problem is that I'm not sure of the coordinates of
the ends of the cylinders after I have translated and rotated them.
Is there a way of doing:
Macro (<A,B,C>,
translate <0,20,-10>
rotate <20,0,10> )
etc
to return the coordinates of <A,B,C> after the transformations? I've tried to
figure out how to use vtransform but it is confusing!
Thanks in advance!!
Subject: Re: Coordinates after rotation?
Date: 28 Jun 2011 16:01:21
Message: <4e0a3311$1@news.povray.org>
> Macro (<A,B,C>,
> translate<0,20,-10>
> rotate<20,0,10>  )
> etc
> to return the coordinates of<A,B,C>  after the transformations? I've tried to
> Thanks in advance!!
maybe vaxis_rotate is what you want ... it's in 3.2.1.4.5 Functions of
the reference basically it returns a vector thats equal to some point in
space after you've rotated it ... this example will tell you where the
1st parameter (a vector) is after you've rotated it in the z direction
by 315 degrees ... the 2nd and 3rd parameters respectively.
#declare SomePoint = vaxis_rotate (<-0.295,4.29,0>, <0,0,1>, 315);
Good Luck
Date: 29 Jun 2011 03:00:01
Message: <web.4e0acc6ba88fb21c6e991f980@news.povray.org>
> Macro (<A,B,C>,
> rotate <20,0,10> )
> etc
Yes!
#declare NewABC = vrotate(<A,B,C>+<0,20,-19>, <20,0,10>)
Regards Roman
Date: 29 Jun 2011 22:55:37
Message: <4e0be5a9$1@news.povray.org>
Am 29.06.2011 08:55, schrieb Roman Reiner:
>> Macro (<A,B,C>,
>> translate<0,20,-10>
>> rotate<20,0,10>  )
>> etc
> Yes!
> #declare NewABC = vrotate(<A,B,C>+<0,20,-19>,<20,0,10>)
Or for the generic case:
#include "transforms.inc"
#declare MyTransform = transform {
   rotate <20,0,10>
#declare NewABC = vtransform(MyTransform);
Date: 29 Jun 2011 23:06:15
Message: <4e0be827$1@news.povray.org>
Am 30.06.2011 04:55, schrieb clipka:
Sorry, should be
   #declare NewABC = vtransform(<A,B,C>,MyTransform);
