POV-Ray : Newsgroups : povray.newusers : .pov files Server Time
28 Sep 2024 08:08:18 EDT (-0400)
  .pov files (Message 1 to 4 of 4)
Subject: .pov files
Date: 20 Jun 2011 11:55:00
Message: <web.4dff6c803757db48238c2be0@news.povray.org>
hello!!
i am new to dialux and povray and i have a problem! when i try to render my
project with povray, it doesn't open and creates only .ppm files! i don't know
what i have to do. . .
sorry for my english and send me if you want furter information about my
problem!thanks in advance
Subject: Re: .pov files
Date: 20 Jun 2011 14:30:45
Message: <4dff91d5@news.povray.org>
natasha_i <nomail@nomail> wrote:
> hello!!
  If the problem is that dialux is not running povray correctly, you will
probably find more help in a dialux support forum, unless someone here has
first-hand experience on dialux.
  Anyways, it could be helpful if you could describe in more detail how
you are trying to run povray in your situation.
Date: 20 Jun 2011 15:35:01
Message: <web.4dff9fcf9c7f5bca503bb9b70@news.povray.org>
> > hello!!
thanks for your answer! ;-) i open my projecti with dialux and then i go
file->export->raytrace with povray. the problem is that it appears to load
povray and then it suddenly stops. and i cannot find .pov files, only .ppm
Date: 21 Jun 2011 05:39:03
Message: <4e0066b7$1@news.povray.org>
Note that ppm is a (rather exotic) image format supported by
povray so maybe everything is working as it was once intended.
If dialux generates ini files or a command line, look for
"Output_File_Type=P" or +FP and change P to N to get PNG,
or use a viewer that can show/convert ppm.
