POV-Ray : Newsgroups : povray.newusers : Simulate a camera with no lens Server Time
14 Dec 2025 16:50:50 EST (-0500)
  Simulate a camera with no lens (Message 1 to 7 of 7)
Subject: Simulate a camera with no lens
Date: 26 May 2011 18:20:00
Message: <web.4dded11b6317d989bf90049a0@news.povray.org>
I've only just downloaded pov-ray so sorry if this is a really stupid
question...
I understand that the camera model in pov-ray is that of an ideal pin hole
camera, and that the field of view of the camera is set which essentially
defines the properties of the 'lens' in front of the camera.
What I'd really like to be able to do is model what a focal plane array (FPA)
would see when a camera has no lens to focus the rays. In this 'no-lens'
scenario I'd like to define an approximate field of view by placing the FPA at
the back face of a cylinder, with an aperture in the front face.
Is this possible in pov-ray?
any thoughts/advice greatly appreciated!
Stu
Subject: Re: Simulate a camera with no lens
Date: 26 May 2011 20:33:57
Message: <4ddef175$1@news.povray.org>
> Hi,
> question...
> Stu
Having no lense can be approximated by a focal point placed extremely close.
A possibility:
Use focal blur with a focal plane very close to the camera location.
Keep the aperture relatively small.
Sample camera:
camera{location Cam_Location look_at Subject aperture 0.01 focal_point
Cam_Location + (Cam_Location - Subject)/100 blur_samples 10, 200}
Try this and compare with a real photography taken without any lense to
see if it's going the right way.
Adjust aperture as you see fit.
If you place an open cylinder in front of the camera, it's radius is the
upper limit for your aperture. Otherwize, you'll get some samples taken
outside of it.
Date: 26 May 2011 21:01:10
Message: <4ddef7d6$1@news.povray.org>
Am 27.05.2011 00:15, schrieb Crippso:
> Hi,
> question...
Possibly the most realistic way to model this would be as follows:
- Build your "camera" using scene geometry, including a placeholder
dummy for the FPA, which should be a plain white diffuse slab (pigment {
rgb 1.0 } finish { ambient 0 diffuse 1.0 specular 0 }).
- Turn on radiosity (you may need very high-quality settings, especially
a high "count" value). This will effectively project the scene onto the
FPA dummy slab (very blurry).
- Use an orthographic camera placed just a tiny bit in front of the FPA
dummy, oriented to look at the FPA dummy, to capture the pattern of
light projected onto the dummy. (Note that you may actually get a
mirrored image.)
Date: 1 Jun 2011 18:45:01
Message: <web.4de6c03377af101ebf90049a0@news.povray.org>
> > Hi,
> > question...
> mirrored image.)
Thanks, thats very helpful. I've given it a try and am getting some good results
by playing around with the radiosity settings.
I'd like to place a flat disc in front of my FPA that is acting as a lambertian
emitter. The FPA will see part of this emitter through the aperture in the
cylinder. Is it possible to include such surfaces in povray by setting their
ambient value to a number representing the radiance of the surface?
Much advice on radiosity suggests ambient should always be set to zero so I
wasn't sure if using ambient was a good way of generating a lambertian emitter
when using radiosity.
Ultimately I would like to be able to use the pixel values I obtain when looking
at the diffuse slab that represents the FPA and convert these to Watts (or
photons per second) based on the amount of light emission from the flat disc.
Any advice on the best way to acheive this would be very helpful too (I have
already set gamma to 1.0)
Thanks
Stuart
Date: 2 Jun 2011 05:56:56
Message: <4de75e68@news.povray.org>
Am 02.06.2011 00:41, schrieb Crippso:
As of POV-Ray 3.7, Lambertian emission is officially supported via the
"emission" finish term. As to be expected, a value of 1.0 corresponds to
the same brightness as an ideal Lambertian reflector illuminated
vertically by a light source of unity brightness.
With POV-Ray 3.6x or earlier, the same effect can indeed be emulated via
the "ambient" finish term; however, the value must be divided by
whatever the global value "ambient_light" is set to (which defaults to
1.0). Obviously, you'll need a non-zero ambient_light value for this to
work.
My suggestion in that respect is to use POV-Ray 3.7 and use the
If for some reason you are stuck with POV-Ray 3.6x or earlier, a
feasible workaround is to set ambient_light to some very low value (such
as 0.001), and increase the ambient finish term accordingly (e.g.
1000.0) to compensate.
POV-Ray doesn't prescribe a particular unit of measurement for
brightness, so you could define an "emission" finish setting of 1.0 to
correspond to a Lambertian emission of 1.0 Watts per square unit. In
that case, a 100% white pixel value would correspond to a light input to
the sensor of 1.0 Watts per square unit (provided it doesn't happen to
be clipped of course).
As for gamma, be sure to set both the assumed_gamma global setting in
the scene file as well as File_Gamma in the INI file to 1.0 for your
purposes. I recommend PNG output (as it can still be viewed accurately
with contemporary sotware, despite the linear gamma settings) or, even
better yet, HDR or OpenEXR (as they prevent clipping and are linear
anyway). The latter two require POV-Ray 3.7.
Date: 8 Jun 2011 17:40:00
Message: <web.4defebe177af101ebf90049a0@news.povray.org>
Thanks,
I've installed v3.7 and the emission term works nicely. Thanks for the advice
too about setting the file gamma to 1.
The only thing I'm struggling with now are the radiosity settings. At first I
had quite blotchy images but I've played around with the settings a bit and have
got a pretty smooth output now. However the brightness across the image is not
perfectly symmetric as it should be. (I'm using Scilab to open up my 16 bit png
files so i can inspect the rgb values carefully)
If anyone has advice on what the problem might be that would be great. I have
attached my code below:
Thanks
Stuart
#local p_start  = 64/image_width;
#local p_end_tune = 8/image_width;
#local p_end_final = 8/image_width;
#local final_eb  = 1.8;
#local final_count = 1600;
global_settings{
assumed_gamma 1.0
radiosity
    pretrace_start p_start
    pretrace_end   p_end_final
    count final_count
    low_error_factor .05
    nearest_count 20
    error_bound final_eb
    recursion_limit 1
    minimum_reuse 0.01
    gray_threshold 0.0
    normal on
#include "textures.inc"
#declare h=20; // cylinder height
#declare d=10; // aperture diameter
#declare R=200; // distance of emitting disc to focal plane array (FPA)
#declare ahor=12.8; // width of FPA
#declare aver=ahor/1.33; // height of FPA
#declare e=2; // distance from edge of array to cylinder edge
#declare c=ahor+2*e; // diameter of cylinder
#declare m=(R/(2*h))*(d+ahor)+ahor/2; //radius of emitting disc
#declare p=h/2; // position of camera in front of array
#declare FoVortho =  degrees(2*atan(ahor/(2*p)));       // FoV of orthographic
cam used to view FPA
#declare radianceScene = 5;  // brightness (radiance) of emitting disc
#declare radianceRS = 0;  // brightness (radiance) of emitting cylinder
camera {orthographic location <0,0,p> look_at <0,0,0> angle FoVortho*1.0}
// diffuse slab representing FPA (set no_radiosity with the intention that
reflected rays do not
// get used in the radiosity calculation)
polygon {
    5,
    <-ahor/2,-aver/2,0>, <ahor/2,-aver/2,0>, <ahor/2,aver/2,0>,
<-ahor/2,aver/2,0>, <-ahor/2,-aver/2,0>
      finish { emission 0 ambient 0 diffuse 1 specular 0 conserve_energy}
pigment {color rgb<1,1,1>}
    scale 1.0 rotate <0,0,0> no_radiosity
// emitting disc
disc {<0,0,0>,<0,0,2>, m, rotate <0,0,0> translate <0,0,R> pigment {color
rgb<1,1,1>} finish {emission radianceScene ambient 0.0 diffuse 0.0 specular
0.0}}
// cylinder shielding the FPA
cylinder {<0,0,0>,<0,0,h>,c/2 open pigment {color rgb<1,1,1>} finish {emission
radianceRS ambient 0 diffuse 0} }
// disc with hole acting as aperture between scene (the disc) and the FPA
disc {<0,0,h>,<0,0,1>, c/2, d/2 pigment {color rgb<1,1,1>} finish {emission
radianceRS ambient 0 diffuse 0}}
Date: 9 Jun 2011 06:43:09
Message: <4df0a3bd@news.povray.org>
Am 08.06.2011 23:38, schrieb Crippso:
As POV-Ray's radiosity algorithm is not an exact solution to the problem
of global illumination (it computes some integrals using a monte carlo
approach), it will not be possible to achieve perfect symmetry, no
matter how hard you try.
